last night i just drove home and when i turned my car off i forgot to roll up the window. when i went to turn the aux on the key would not turn. the auto telliscoping worked when i put the key in but nothing else. anyone know or have had this problem and do i have a easy fix or will this be costly?
These cars have pot metal at the back of the lock cylinder. After repeated pushing in on the key it wears the key and dents the back of the lock cylinder, so the key and tumblers no longer match. I put a new tumbler in the first time not knowing...the dealer sent it out to a local locksmith (so don't take it to the dealer) and about three years later it happened again.
The lock tumbler system is about like 275.00 for the part 'plus' install it seems like 125.00 more. The second time I took it to a real good locksmith that works on those type of things (had to have it towed though because i couldn't get the key to turn or come out). He adjusted the tumblers and recut the key into a new configuration and said this should last you for a while. Cost me like 50.00. It's been over a year and a half and no problem so far. |
B.K.A Runa
i have the same problem. i usually take my key out. place my finger on the key hole push oe wiggle it a few times and try it again and it starts right up. or just take the heel of ur palm and tap right below the ignition. either way works for me.
I also wish I had caught a knee cap with him facing me, just to send a message to faggot ass theives that like 2 steal. "NO EASY TARGET HERE. ATTEMPT THEFT AT UR OWN WAGER, BUT WHEN THE HOUSE WINS U MAY LOSE MORE THAN UR CHIPS. i.e. UR LIFE." G2BMC "It's still Big Iggy... B!+(H" |
Tristate Committee Member
you need to wiggle around the steering wheel a bit. hondas have that kind of issue. my honda sometimes does that. its just something is up with the lock mechanism.
Yeah, I did the shake the key and move it around thing for a while, but when it finally locks up where the ignition won't turn or even release the key, it's probably going to be in the worse place possible, raining and at night (it was).
I'd take it to a locksmith that can work on it and reset the tumblers and rekey. Not just all of them can do it or are willing to, or you can put it off for a while like I did, but I wouldn't recommend it. |
#7 (permalink) | |
yea mines did that once, i was because the shifter wasent all the way in park.
GSG737
Yeah it happens on every Legend, its how u have the wheel when you park...just wiggle it and pull the key in and out..it will work eventually
CHICAGO LEGENDS! Custom CAI magnaflow catback exhaust 2 12" kicker cvr12's with a 2253 watt (751 rms)rockford amp w/ Cap Pioneer head unit w/ pioneer ipod adapter Rial 16" rims w/ goodyear triple tread tires 3 gauge pillar w/ autometer cobalt gauges.oil pressure, water temp, and air/fuel GTS Smoke headlight covers Venom 400 performance chip Clear Corners Mod Express 6000k HID kit Addco rear sway bar Blackened Engine Damper 20% tint |
| key wont turn | RIP94H22PRELUDE | Second Generation Legend (1991-1995) | 11 | 05-07-07 11:46 AM |
| key wont turn HELP!!! | ritzsupra98 | Second Generation Legend (1991-1995) | 14 | 02-07-07 01:29 PM |
| Key wont turn | LegendFanInCanada | Second Generation Legend (1991-1995) | 12 | 11-05-06 04:45 AM |
| ignition key will not turn | emmydotnet | Second Generation Legend (1991-1995) | 16 | 11-17-03 08:56 AM |
| Key won't turn | ChippsAChoi | Second Generation Legend (1991-1995) | 16 | 12-19-02 11:49 PM |
