Old 02-07-07, 12:17 PM   #1 (permalink)
Car 1: 1991 Acura Legend 4dr.
key wont turn HELP!!!
I have a 91 L sedan i jumped in it this morning to goto work, and it wont let me turn the key. Yes i moved the wheel back and forth and also played with the gear selector. Nothing seems to be working, does anyone know whats going on with my car? I think it might just be the cold, but i still need to fix it cause i can't just borrow my dads car all winter long.
ritzsupra98 is offline
Old 02-07-07, 12:25 PM   #2 (permalink)
barely a legend
FiveSpeed's Avatar
Car 1: 93 Legend L Sedan 5 spd
try a different key if the key you are trying is worn too much but also the ignition switches are pron to go bad on legends
if a good key will physically not turn, sounds like something jamming the mechanism maybe spray electronics cleaner (do not spray WD40 or anything oiley it will gum it up)
If you clean it a little with electronics cleaner, then put a little lock graphite to lubricate, then try
FiveSpeed is offline
Old 02-07-07, 12:27 PM   #3 (permalink)
i have tryed 5 differant keys now and none of them are working
Old 02-07-07, 12:40 PM   #4 (permalink)
it also looks like my ignition might be screwed. i just talked to my dad and he thought that he would take it upon himself to put penetrating oil in my ignition. can i fix that anymore or should i just replace it. i think that might be little too pricy to do.
Old 02-07-07, 12:44 PM   #5 (permalink)
barely a legend
FiveSpeed's Avatar
there is a little pin inside the lock that gets pushed up by the key. This tells the system the key is there so it can do the chime thingey etc....
So another idea would be that pin is stuck or jammed, broke whatever which means you may need a new lock switch if spraying cleaner does not help...
Old 02-07-07, 12:49 PM   #6 (permalink)
its still chiming, so i dont think thats it. I did just go look at it and the silver part that you put you key into is now iced over. I also seen a lot of oil on the key itself when i pulled it out
Old 02-07-07, 12:53 PM   #7 (permalink)
barely a legend
FiveSpeed's Avatar
the pin used to stick so the car would chime even after I took the key out of the ignition. Spraying with solvent (not oil) ie. electronics cleaner helped but eventually it got to the point that the car would not turn on even though the lock was turning. In your case, if the lock won't turn at all, it sounds like something jamming either that PIN thing or the actual lock cylinder. If the PIN is the problem, changing out the switch fixes this. It cost me $56 for the switch and is fiddely to get to but not impossible to do yourself.
If it is the lock tumblers inside the cylinder that are jamming, I still think electronics spary solvent might just free it up unless there is some foreign object lodged in there.
If you have to change the actual lock cylinder, yes pricey because you need all new keys.
Old 02-07-07, 12:57 PM   #8 (permalink)
do you think silicon would be good to use?
Old 02-07-07, 01:00 PM   #9 (permalink)
barely a legend
FiveSpeed's Avatar
a locksmith taught me never spray oil of any kind into a lock. It gums it up. They use graphite powder if they use anything at all. Electronics cleaner is a solvent and evaporates quickly. It will not harm your finishes if you keep a rag around to contol overspray and catch the run off.
Most other cleaners sprays are oiley. and also brake part cleaner is too caustic to spray around inside the car.
Old 02-07-07, 01:02 PM   #10 (permalink)
barely a legend
FiveSpeed's Avatar
silicon spray i.e. wd40 ... is basically viscous --- oiley. It will gum it up. How is your lock "frozen" is there water or condensation inside the car? Are you saying the lock may literally be frozen with water?
auto parts stores and electronic supply places sell electronics cleaners. I found graphite lock lube tubes I think at Home depot
Old 02-07-07, 01:05 PM   #11 (permalink)
no my dad put penetrating oil in and on the switch while i was at work. and the oil is now frezeeing.
Old 02-07-07, 01:09 PM   #12 (permalink)
barely a legend
FiveSpeed's Avatar
so no doubt its bloody freakin cold in Michigan
Old 02-07-07, 01:18 PM   #13 (permalink)
only about 4 degrees outside. I threw the car in nuetrel and rocked the car back and forth, jumped in and started turning the wheel back and forth as hard as i could and got the dang thing started. the swich is really gummy tough so im trying to find the elec. spray and lock graphite. thanks for the help that you did provide, but in the end it came down to my being pissed off and physically getting it done.
Old 02-07-07, 01:20 PM   #14 (permalink)
barely a legend
FiveSpeed's Avatar
awesome, good to hear she's running
Old 02-07-07, 01:29 PM   #15 (permalink)
Car 1: 1991 Legend L Sedan Wrecked!
Car 2: 95 Legend "L" Sedan
Same thing happened to my 91. It would intermittently lock up at different times. I tried all the things mentioned but the fix was having the lock cylinder replaced. I think it was like about $140 and came with 2 keys.
91boz
91boz is offline
I cannot turn the key to start my car hung_143hungs Second Generation Legend (1991-1995) 22 06-21-06 12:05 PM
HELP! check engine and oil lights on dash stay on after key is out! weird silko82ny Second Generation Legend (1991-1995) 2 01-20-06 10:48 PM
i need a key unit khmer209racer OEM Parts 3 02-27-03 01:19 PM
Problem with the driver side door key, please help!!! mocca Second Generation Legend (1991-1995) 13 02-26-03 06:57 PM
Ignition Key got stuck CALegend Second Generation Legend (1991-1995) 0 10-29-02 05:09 AM
