Old 07-05-08, 02:10 PM   #1 (permalink)
m3456y's Avatar
last request for help...
Before I change out the differential.
I have a rumbling/growling sound coming from the front end only when turning left on my 6-speed Coupe. So far I've replaced the axles...and thinking I may have gotten a bad one... replaced the right side axle again with a raxle. I replaced the right hub bearing. I've checked the balljoints. Today, I replaced the intermediate shaft bearing. The noise is still there - it sounds like a bad inner cv joint or some type of bearing going bad.
Before I go through the thrash of replacing the differential, I thought I try one more time to see if anyone has experienced this sound and solved it. I may replace the left side axle again - as I have heard of non- OEM axles being bad from the start.
1993 Legend 6-speed coupe, 4cruizin is my hero
1992 NSX all Comptech 362 RWHP short gears, etc.
2004 Mini Cooper - MC40 John Cooper Works
1975 914 Porsche 6,500 actual miles
m3456y is offline
Old 07-05-08, 02:40 PM   #2 (permalink)
RALPHS HANDS ARE CLEAN!
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
stupid question, but does it make the noise when the car is sitting stll, and turning the steering wheel?
blkonblkcpe is offline
Old 07-05-08, 02:58 PM   #3 (permalink)
m3456y's Avatar
Nope. just driving and turning to the left - as in turning a corner. I even hooked up a wireless microphone to various parts of the suspension and listened with headphones to see if I could isolate the sound...no luck. I'm running out of ideas.
m3456y is offline
Old 07-05-08, 03:27 PM   #4 (permalink)
Welcome to my head
Socol's Avatar
Car 1: CL-S (Daily Driver)
Car 2: ObsidianBlack KA8
Just for kicks, check your rear transmission mount.
Socol's Basic Website
Socol is offline
Old 07-05-08, 04:17 PM   #5 (permalink)
m3456y's Avatar
I replaced both side motor mounts, the front mount, and checked the rear mount which looked fine.
m3456y is offline
Old 07-05-08, 04:25 PM   #6 (permalink)
Welcome to my head
Socol's Avatar
Had a very, very similar problem; changed the axles and it fixed nothing. Coincidently enough, the problem only showed itself when making a left turn. The (6-speed) tranny mount appeared fine until it was taken off, turns out it was in two pieces.
Socol is offline
Old 07-05-08, 04:31 PM   #7 (permalink)
m3456y's Avatar
Interesting...well I happen to have a new rear tranny mount I can install. I'll throw that in there and see what happens before I go any further.
m3456y is offline
Old 07-05-08, 04:33 PM   #8 (permalink)
chapman89's Avatar
Car 1: 1993 Acura Legend LS
Good luck with your search for the problem, I hope it's as simple as the rear tranny mount.
I had a weird sound the other day coming from the front end. Thankfully it was only the passenger side axle, which happened to be completely dry from the lack of grease. $200 later I have a new axle and no more weird sounds.
chapman89 is offline
Old 07-06-08, 07:47 AM   #9 (permalink)
m3456y's Avatar
I should have the new mount in this AM. I hope you are correct. The old one was not "in two pieces" but was in pretty poor shape.
m3456y is offline
Old 07-12-08, 12:10 PM   #10 (permalink)
KA8 Legend Killer
91sedan's Avatar
Car 1: 91 Acura Legend BHG
Car 2: 88 LS Sedan-SOLD
Car 3: 93 Ranger R.I.P
I have a similar problem i'll try doing what was stated earlier. one more thing, I also have a sound coming from the passenger side front wheel area it makes a squeaking sound and a metal to metal rubbing sound up to about 20mph. Can anyone give me a general idea on what that might be?
Mods: Short Ram Intake with K&N Air Filter, Custom Exhaust, Telion Chipped ECU, Type II Manifold (added 12 peak hp and cracked on 7-30-08), Type II Cluster,Throttle Body Coolant Bypass 15.35@91.6mph
Future Mods: OBX Headers,Custom Y-Pipe,Magnaflow hi-flow cat,Stromung B-Pipe,Remus Exhaust,Ported and polished heads and manifold,Web Cam regrinds, 6spd swap All after I Do the 3.5 Swap!! Hoping for a healthy 200whp N/A beast
91sedan is offline
Old 07-12-08, 12:30 PM   #11 (permalink)
94legendcpe's Avatar
Car 1: 1994 Taffeta White LS Coupe
Car 2: 1993 GBP 6sp L Coupe
Car 3: 08 Lexus RX350
^^ How are the brake pads on the front right looking? Could be the contact pieces letting you know the pad is getting low.
1994 Tafetta White LS Coupe
JDM one pieces
JDM grille
Minty fresh GS rims
15% all the way around
94legendcpe is offline
Old 07-12-08, 12:35 PM   #12 (permalink)
Wrench
Billyjack187's Avatar
Car 1: 1995 Chevy K2500 Turbo Diesel
Car 2: 1992 Honda Accord LX
Car 3: 1993 Acura Legend T2
Have you checked the steering knuckle the cv is connected to? Sometimes they get worn out, wheel bearings??? I know you said you did, but recheck it. As a wrench you gotta assume you messed up first..LOL sad but true. Then blame the parts. Howling comes from bad bearings, no doubt.
Billyjack187 is offline
Old 07-12-08, 12:44 PM   #13 (permalink)
KA8 Legend Killer
91sedan's Avatar
The front rims get alot of brake dust on them in just a few hours
91sedan is offline
