Old 02-10-05, 05:39 PM   #1 (permalink)
Car 1: 1992 LS Sedan
Leaking coolant, near thermostat, help?
So I changed the thermostat on my fiancee's Legend a few weeks back. Since then she has had a coolant leak. I've double checked the thermostat housing and I'm 99% sure it isn't coming from there. Hotstartup said to double check the lower radiator hose where it connects to the thermostat housing, which I'm going to check next time....
My question is, is there anything else near the thermostat that I could have knocked loose while changing it out? The coolant appears to be dripping just below where the thermostat is, but the bottom of the thermostat is dry, so I think it is ok.
Thanks for the help.
-James
James92LS is offline
Old 02-10-05, 06:08 PM   #2 (permalink)
Car 1: 1993 Tan Sedan L
There is also a rubber gasket between the thermostat and waterpump. This gasket is supposed to be replaced if the two parts ever gets separated.
Legend93 is offline
Old 02-11-05, 03:13 AM   #3 (permalink)
Yes, I replaced the gasket that goes in the housing with the thermostat - but I can't take out the waterpump to replace that huge seal.
Although in that picture I see the two copper connections coming out of the water pump - is it possible one of these could be loose?
-James
EXPERT HELP NEEDED--regarding cooling system!!! drk9ght Second Generation Legend (1991-1995) 17 08-02-05 05:32 AM
Headgasket -- permanent fix? SLICK40 Second Generation Legend (1991-1995) 30 10-14-04 02:06 PM
Coolant Importance Danny Second Generation Legend (1991-1995) 0 12-24-03 02:36 PM
Honda Coolant!!!! Phireant Second Generation Legend (1991-1995) 3 09-30-03 02:48 PM
Why you should use Honda Brand Antifreeze Avarice DIYs 3 02-28-03 08:36 AM
