Old 04-02-08, 11:33 PM   #1 (permalink)
Car 1: 1991 Gold Legend L
Car 2: 1991 Gray Legend L
Left Rear Window won't go up!!!
My left rear window won't go up and it is stuck in the down position...wife doesn't like it. Friend thinks it is the window switch. The drivers control for the left rear window does not work as well. Are these switches in series? Need help to just get the window up!
mystican is offline
Old 04-03-08, 12:03 AM   #2 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
I'm assuming the other windows work! If neither the master or the door's own switch don't work, it is usually either the motor is gone or there is a problem with the connection either in the door or where it plugs into the main left side wire harness (in the center post).
ari_one is offline
Old 04-03-08, 12:28 AM   #3 (permalink)
IvAn_120's Avatar
Car 1: legend
man i have that problem all the time it happed today dont worry just play with both front and the back swatch and it will go up
and it is not the swatches it is the wire connection in the door
if u lessen carefully u will hear the motor working when u bring it down but it does not work when u move it up
*^*^*^*^ go hart, or go home ^*^*^*^*^*
IVAN_120
1991 LeGeNd
black
*** 5 speed** loving it
with 7" tuch screen in dash tv
13 1/2" LCD over head tv
18" (215/35/18r)
and other small things
~~~ They all start hating cause you got a Legend but it doesn't matter cause they are just jealous~~~
IvAn_120 is offline
Old 04-03-08, 12:42 AM   #4 (permalink)
Car 1: 95 Acura Legend Coupe LS Type 2 (currently own 2)
Car 2: 89 nissan 240sx HB
Car 3: 73 Dodge Charger
if you have a volt meter unplug motor pigtail and check for 12v between both wires when switch is depressed. if you have power the motor is at fault. if not wiring/fuses/switches are at fault. track voltage backwards towards source
phyrexia19 is offline
Old 04-03-08, 03:27 AM   #5 (permalink)
the motor is not at fault...I took apart the left rear window panel and using two paper clips, I extended the male connecter for the window motor and flipped it. Using the extended prongs made by the paper clips, I flipped the female connector and connected it to my paper clips and simultaneously pushed down on the window switch. The window went up! So I dont think it is the window motor. I think it is the left rear window switch.
mystican is offline
Old 04-03-08, 05:43 AM   #6 (permalink)
FIXER
My problem was in the connector thats in the center post.
Jetdoc is offline
Old 04-03-08, 01:36 PM   #7 (permalink)
What was wrong with your B pillar connector? I dont think it is the window switch anymore b/c I took the opposite door switch off and tested on the left rear door and it didnt work. The master door switch (only the left rear switch in particular) also doesnt operate correctly. Can you elaborate on your B pillar connector issue?
mystican is offline
Old 04-03-08, 02:41 PM   #8 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
Sometimes you just end up getting water etc over time into the connector (via the rubber piece in pic if it breaks) or one of the pins gets loose. Some have been able to fix by just cleaning and adding some dielectric grease.
ari_one is offline
Old 04-07-08, 07:09 PM   #9 (permalink)
OK so I took apart the B pillar connector and cleaned it. The let rear window will go down, but not back up. The master control switch controlling the left rear window still does not work. I am starting to think the problem lies with the the drivers master control switch. Any ideas?
EDIT
I got a used master switch. I plugged it in and it did not change to situation. The left rear window will go down, but not go up. I have checked the B pillar connector, the left rear window connector, and changed the driver's master power switch. Anybody with some ideas?
mystican is offline
Old 05-09-08, 04:12 PM   #10 (permalink)
Car 1: 1994 White 4 door L sedan
short term solution
I have the same problem. The window goes down, but not up. My temporary solution was to reverse the up and down wires off the switch on the door. That enabled me to raise the window. Its disconnected now, but if I can't get the switch to work both ways, I am going to replace it.
Markus is offline
Old 05-09-08, 06:53 PM   #11 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
If both of you have done the following:
1. swapped another window switch
2. reversed the wires to the motor can get the motor to go up by reversing wires
3. swapped master switches
and the symptoms are still the same then you must have a problem with either:
a) the wiring between the switch and the b-pillar connector
b) the wiring between the b-pillar and fuse box.
Easy option, pick up a rear door wire harness and test it out without installing inside door to find eliminate that wire harness.
ari_one is offline
Old 05-31-08, 05:37 PM   #12 (permalink)
Fall 08' rebirth!
Car 2: 92' Acura Legend SDN
Someone needs to explain this better. I hear "reverse wires" with no detail as to the dozen or so wires in the door. Be specific.
Dethred is offline
Old 05-31-08, 07:26 PM   #13 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
There are only two wires that go to the motor itself, so if you reverse those two then the switch will work in the opposite direction.
ari_one is offline
Old 06-02-08, 12:05 PM   #14 (permalink)
Car 1: Honda Legend
Hi, I've got exactly the same problem. My window roll down, but not up, I checked voltage, I have +12 when rolling down, but -6 when rolling up, which is not enough. I Jumped the wires to get my window up and it works. I'd like to check the wire between door and B Pillar, but I don't know how. Should I Remove the door entirely ? I can't find it in the service manual. Thanks
Nekkro-Kvlt is offline
Old 06-02-08, 12:35 PM   #15 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
Check out the TSB linked below:
http://www.acuraworld.com/tsb/1993/B93-021.pdf
ari_one is offline
