legend 93 Factory Auto Alarm Disable - The Acura Legend & Acura RL Forum
Old 10-28-07, 09:10 PM   #1 (permalink)
Hello
I got problem to locate the wire for Factory Alarm Shutdown. Anyone know where it is can tell me please.
Thank in advance
winflower is offline   Reply With Quote
Old 12-03-07, 12:17 AM   #2 (permalink)
Car 1: 1991 Acura Legend LS
search "OEM alarm"...click on "OEM alarm hell".....read last post by me.....i figured it out just last week and posted how to do it
it may be different on a 93, but but remember to ground out the wire be fore you cut it...dont wanna cut the rong one, getts messy
jus ask what ever other questions on that forum i rote and i will answer what ever i can
Legendracer is offline   Reply With Quote
Old 12-03-07, 12:34 AM   #3 (permalink)
IAmLegend's Avatar
Car 1: 93 LS Sedan
Car 2: 90 Camry DX
iTrader Score: 7 reviews
i found out that part of the factory alarm on my 91 included a hood sensor because the hood must be closed for the alarm to engage. there is a hood sensor and a harness attached to it on the radiator support underneath the bumper where that vertical bar goes down the middle of the radiator. you can unpulug your harness there (if equipped on the 93) and the factory alarm will be disabled just because of one sensor, and you can always plug it in later. hope this helps
IAmLegend is offline   Reply With Quote
Old 06-25-09, 06:28 PM   #4 (permalink)
Car 1: 1991 Legend
Alarm disable
Regarding disabling the alarm by disconnecting the hood sensor:
Great idea on the hood sensor, however - I have a 1991 Legend and found that just unplugging the hood sensor did not work. I was able to disable the alarm by cutting the wires to the sensor and wiring them together. When the hood is open the sensor contacts are closed and allowing current to flow. To fool the car into thinking the hood is open (and preventing the alarm from activating) the wires must be connected together.
Just saw on another thread that an easy solution is to bend the small lever so that the closed hood does not push on the lever. Have not tried it but that seems like it would work and be easy.
swmasters is offline   Reply With Quote
Old 06-26-09, 07:37 AM   #5 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
Car 3: 93LS 6spdgraycpe 3.5
Link to same topic:
paperclip trick to disable the alarm pictures?
Old 06-27-09, 10:01 AM   #6 (permalink)
Flash Poker Champion, Fucking Killer Champion
Blingting's Avatar
Car 1: 1993 Acura Legend Sedan LS
iTrader Score: 33 reviews
Send a message via AIM to Blingting Send a message via MSN to Blingting Send a message via Skype™ to Blingting
paperclip trick ftmfw
Blingting is offline   Reply With Quote
Old 09-23-09, 12:33 PM   #7 (permalink)
fraser34's Avatar
Car 1: Acura Legend LS Coupe 1992
There is OEM disable output
Originally Posted by JUTYCUS View Post
... most aftermarket alarm/remote starts have an OEM disable output to disarm the OEM alarm when you remote start the vehicle. This way, you don't have to go thru the trouble of removing the OEM alarm...
Exactly!
I've just installed mine - ProStart CT-3400TW Remote Starter.
Used this "Disarm OEM Alarm" output. Connected it to GREEN/RED (-) wire @ ANTI-THEFT MODULE.
Everything works just great!
DIY - My New Leather Seats
fraser34 is offline   Reply With Quote
how to disable factory alarm? bikejumpr20 Second Generation Legend (1991-1995) 6 08-06-07 01:04 PM
Disable Factory Alarm? Audio, Video, & Electronics 4 04-17-06 01:07 PM
how to disable factory alarm Legend_Elite First Generation Legend (1986-1990) 4 06-25-03 05:40 PM
Disable Factory Alarm? Second Generation Legend (1991-1995) 0 08-16-02 03:56 AM
Disable Factory Alarm Kurizma Audio, Video, & Electronics 10 07-20-02 02:16 AM
