Old 08-27-08, 08:10 PM   #1 (permalink)
Car 1: 1991 Acura Legend LS
!!Legendracer needs help!!
Alright,
today i was driving home and my legend just instantly overheated. so i turned it off in the middle of the road while drivin. got out and looked under the hood, nothin seems bad. although, underneath is leaking horribly. just between the differential and oilpan, just pourin out...i dont know what it is or why it all of a sudden starting leaking horribly.
the only info i can think of that could possibly be it is between motor swaps last year my differential coolant line was clogged that leads to the oil cooler. nothin comes out and nothin will go in. i ran coolant lines anyway and it drove fine.
i dont know if there is if theres any lines inbetween the motor and differential but its leaking right in between there
Can anyone help me figure this out????
thanks,
max
-1991 Acura Legend-
JDM swapped Type I
Telion Chiped
18" Rays G-Games
Wabro 255lhp-hp Fuel Pump
Custom Intake
EGR Blocked off
Lowered by oldage
Pioneer System
Legendracer is offline
Old 08-27-08, 08:18 PM   #2 (permalink)
bump bump bumpy bump!!!!!!!!!!!!!!!1
-1991 Acura Legend-
JDM swapped Type I
Telion Chiped
18" Rays G-Games
Custom Intake
EGR Blocked off
Lowered by oldage
Pioneer System
Old 08-27-08, 08:29 PM   #3 (permalink)
Kenso's Avatar
Car 1: 91 L Coupe 6 spd
Car 2: 95 FZJ 80
Car 3: ITR 00-106
Sounds like the upper diff. cooler hose from what you describe. Leaking from above and running down between the diff and pan.
ITR 00-106
91 6spd coupe
95 FZJ-80
Kenso is offline
Old 08-27-08, 09:12 PM   #4 (permalink)
where does that hose run to....and would you know how difficult it would be to replace
-1991 Acura Legend-
JDM swapped Type I
Telion Chiped
18" Rays G-Games
Custom Intake
EGR Blocked off
Lowered by oldage
Pioneer System
Old 08-27-08, 10:31 PM   #5 (permalink)
bump..................................
ive read that RL's do not have a differential cooler lines. if i were to re-route that coolant line away from the differential would it be fine....or could possibly blocking it off work just as well???
-1991 Acura Legend-
JDM swapped Type I
Telion Chiped
18" Rays G-Games
Custom Intake
EGR Blocked off
Lowered by oldage
Pioneer System
Old 08-27-08, 10:35 PM   #6 (permalink)
Type II King
Forevralegend's Avatar
Car 1: 94 Legend Gs type II
that line i believe runs to the front of the engine, there is a disk like thing bolted to the engine block that also has lines from the water pump going into it.
mods-
Forevralegend is offline
Old 08-27-08, 10:36 PM   #7 (permalink)
Type II King
you should try taking pictures because its pretty hard giving you a good answer without it
edit:: dont reroute the line..you want it
mods-
Old 08-27-08, 10:40 PM   #8 (permalink)
yea i know of that line...i dont have a oil cooler on this engine....and the coolant line on the differential is clogged....its the other coolant hose that is possibly busted and leaking(the one above the differential or where ever its at).
-1991 Acura Legend-
JDM swapped Type I
Telion Chiped
18" Rays G-Games
Custom Intake
EGR Blocked off
Lowered by oldage
Pioneer System
Old 08-28-08, 12:19 AM   #9 (permalink)
Kenso's Avatar
Car 2: 95 FZJ 80
Car 3: ITR 00-106
It runs from the side of the block to the diff. cooler. Kind of a pain to get to. Bypassing the cooler won't really make the job easier, you still have to get into a tight area. #7 in this pic. Best educated guess I can make based on the info provided.
ITR 00-106
91 6spd coupe
95 FZJ-80
Kenso is offline
Old 08-28-08, 12:36 AM   #10 (permalink)
thanks, that does help.....the pic is slightly confusing at first but i see what im workin with now.....all the lines leading to the water pump + oil cooler are gone and not on my motor...there are actually no lines going into my water pump(#3 and#4).
all i really have is the waterpump and differential in that pic and where hose #8 goes into the defferential is what is clogged.
Originally Posted by Kenso View Post
thankyou again
-1991 Acura Legend-
JDM swapped Type I
Telion Chiped
18" Rays G-Games
Custom Intake
EGR Blocked off
Lowered by oldage
Pioneer System
