Old 07-09-08, 12:25 AM   #1 (permalink)
im a dippidy do-er
foolonrampage's Avatar
Car 1: '91 Acura Legend L
Send a message via AIM to foolonrampage Send a message via Skype™ to foolonrampage
Unhappy light smoking from the engine bay!
hey all,
havent posted in QUITE A WHILE!! sorry. hoping to get some money to be more into it again. haha. BUUUTTT my problem is a light gray smoke coming from my engine bay. its the first time it has happened. here is what could have led to the current situation.
1. got on it kinda hard this morning for a good 5 minutes, no more than usual
2. ran my AC pretty hard all day.
3. about 200 miles past my oil change
4. havent changed spark plugs...EVER! (145k+miles)
i have a 91 Legend Coupe. any help is great help. Thanks all. Hopefully its just a belt or some spilt oil or SOMETHING. even though this has never happened. Thanks again for everything guys!!
foolonrampage is offline
Old 07-09-08, 12:41 AM   #2 (permalink)
FRISCO LEGEND BABY!!!!
l4zy415's Avatar
Hows the valve seals on the valve cover? See any oil on there?
l4zy415 is offline
Old 07-09-08, 01:08 AM   #3 (permalink)
Why So Serious???
-=DBS=-'s Avatar
Car 1: 1988 Acura Legend Coupe (BMW Alpine White) 5pd
Car 2: 91 Legend Coupe
Send a message via ICQ to -=DBS=- Send a message via MSN to -=DBS=-
+1... More then likely it's the valve cover gaskets which need to be replaced.
Also you should really think about changing the plugs and doing a tune up. It'll only help you all around. Your car will definately run better and be more fuel efficient!
The White Knight - The Machine, the Myth, the F'n LEGEND!
-=DBS=- is offline
Old 07-09-08, 02:24 AM   #4 (permalink)
im a dippidy do-er
MORE FUEL EFFICIENT?!! im doing it!! what sort of "tune up" would it be? what would i need to replace/how much?
Old 07-09-08, 02:25 AM   #5 (permalink)
im a dippidy do-er
really have no idea. havent been IN IT yet. just asking before i start poking around.
Old 07-09-08, 02:32 AM   #6 (permalink)
l4zy415's Avatar
Tune-up pretty much is spark plugs, distributor and wires, rotor inside distributor, fuel pump if its responding weak, oil changes, oil filter, air filter, PCV valve cleaning. I think there's more, but mostly worry about the spark plugs related. But, like I said, check your valve covers for any oil leakage.
l4zy415 is offline
Old 07-09-08, 03:59 AM   #7 (permalink)
im a dippidy do-er
jesus...what would the price be on that?!
Old 07-09-08, 07:22 AM   #8 (permalink)
Factory Freak!
92drls's Avatar
Car 1: JDM KA8 5sp
Car 2: Lincoln LS8 RIP
Lol not as bad as you think. You say you've NEVER changed a spark plug tho so I would recommend the works. Plugs, gaskets, oil, oil filter, maybe send in your injectors for a late Spring clean.. All of the above done, less than 200 but well needed and deserved, you love your Legend right?
92drls is offline
Old 07-09-08, 09:28 AM   #9 (permalink)
Why So Serious???
-=DBS=-'s Avatar
If you haven't done it..
I would replace the following
Spark Plugs
Spark Plug Wires with the cap/rotor
Fuel Filter
PCV Valve
Air Filter
As for the oil, it's prob just leaking onto the exhaust and burning off.. do you smell anything odd when you see that smoke?
-=DBS=- is offline
Old 07-09-08, 09:30 AM   #10 (permalink)
Why So Serious???
-=DBS=-'s Avatar
Ok my bad.. I didn't see that the information I just posted was posted above.. so +1 to what was said!!
-=DBS=- is offline
Old 07-09-08, 05:35 PM   #11 (permalink)
difficult to kill
brynosaur's Avatar
Car 1: 1995 L coupe
smoke from engine bay makes me think valve cover seals too. possibly a few drops of oil got on your exhaust manifolds and burned up. hard to say for sure though. check oil levels first off, then run it a bit in park or neutral and have a look around for leaks or where the smoke is coming from.
www.myspace.com/thebestbryan
BHG free since 2003
95 L coupe 4AT in cashmere silver
60a urethane mounts
FL tie bars (newly installed)
sr5guy stage III ecu
GB Xdrilled/slotted front n rear
rebuilt top end (~20k on it so far)
weapon r + cold air extension
5wire 4awg ground kit
brynosaur is offline
Old 07-09-08, 11:56 PM   #12 (permalink)
im a dippidy do-er
well it hasnt smoked at all in the past 2 days and i havent ran my AC and i HAVE ran it somewhat hard. around town and its doing good. im thinking it was just my AC belt?? and thank you for all your help guys. YES i love the legend. looks like im gonna start saving up for the tune ups. WISH ME LUCK!! ill keep an update. no doubt.
Old 07-10-08, 12:13 AM   #13 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
Since you have a G2 ignore the comments about distributor, rotor, and wires as you don't have any of those.
ari_one is offline
Old 07-10-08, 06:28 PM   #14 (permalink)
/==IIII==/
Bowtie's Avatar
Car 1: 94 GS sedan
Car 2: Chevrolet Truck
Car 3: KTM 625 SMC
I posted on here about smoke and stink from under my hood awhile back. It stopped though after dripping and smoking just once. I think it was a inner axle boot and havent addressed it as I will just slap in a new axle sometime soon.
is it possible you have maybe experienced the same???
/==IIII==/
Bowtie is offline
