Old 01-26-04, 05:59 PM   #1 (permalink)
Blk/BlkGS6
Car 1: '94 Black/Black Legend GS Sedan 6 Speed
Car 2: '92 Silver LS Coupe
Car 3: '94 Cashmere L Sedan
Send a message via ICQ to legend4life Send a message via AIM to legend4life Send a message via MSN to legend4life Send a message via Yahoo to legend4life
Mls Bar And Kms Bar Both Installed Together !
Ok guys,
I just installed my MLS Copy bar, along with my KMS strut bar, along with my stock strut bar. So I now have all three bars installed on my car at the same time!
I think this is the first time (that I know of) that anybody has done this.......I believe someone said before that they would not fit? I did not have any problem getting them all to fit together. The MLS bar was a BlATCH to install though.
This is a post qouted from ChrisK:
"The two bars are slightly different IMHO. They both end up pretty much doing similar things, but in different ways.
You can kind of see the difference just by looking at the design.
The KMS links to the strut tower chassis were the OEM strut brace mounts. Together with the OEM brace it makes for a triangular chassis brace.
The MLS mounts directly to the shock struc bolts. This prevents any movement from the strut assemble itself.
IMHO, the KMS is more of a chassis brace while the MLS is more of a strut brace. The KMS will not do as good a job stiffening the struts and keeping the front struts in its proper geometry, however, the MLS will not do as good a job stiffening the chassis flex. I believe both will feel like the entire end is stiffer and more planted, however, one is working via the suspension while the other is via the chassis.
PS. As far as durability and strength, I believe both will outlast the vehicle. The MLS is a tubular design, so generelly it is a stronger design. The MLS is powder coated black so the finish is first rate. The KMS is polished, so it has a better show look to it. Each will appeal to different people. I liked the MLS for its OEM like look."
Best of both worlds? Worth it to keep them all on? Will it really make a difference or improvement in handling/feel over having just one of them?
I haven't driven it yet, and we are expecting snow for the next few days, so I don't think I will be able to push the handling hard or anything. But I will keep you guys updated with what I think of it, and also pics of course.
legend4life is offline
Old 01-26-04, 08:06 PM   #2 (permalink)
Car 1: '93 Aegean Blue Evolution Exclusive KA7
Send a message via AIM to Sprung17
cool. how much for the mls copy? Where can we get the MLS copy?
Aegean Blue KA7 w/ an Evolution Exclusive body kit
Custom crystalized JDM one piece headlight
Carbon fiber hood
Type II engine
2 1/4 mandrel bent cat back exhaust.
Type I Bayou stage II ECU - A'PEXi S-AFC II
Walbro 255lph Fuel Pump
17" Enkei CDR9 on Fuzion ZRi
Eibach Pro-Kit/Koni Special Struts, front & rear
KMS Front Tower Bar
Addco Rear Sway Bar
Front STS Cross drilled/Slotted rotors
Goodridge Steel Braided Brake Lines
Sprung17 is offline
Old 01-26-04, 11:05 PM   #3 (permalink)
acuralegend.com's Avatar
Car 1: .
Send a message via ICQ to acuralegend.com Send a message via AIM to acuralegend.com
overkill?
acuralegend.com is offline
Old 01-27-04, 12:15 AM   #4 (permalink)
Pedobear is watching you
tnelson's Avatar
Car 1: 2002 TL-S, white
Car 2: 1992 Corvette
nah, they both go about it different ways. with both of them, you would have a very sturdy front end, and handle well
tnelson is offline
Old 01-27-04, 01:45 AM   #5 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
Pics?
Mike Diaz is offline
Old 01-27-04, 01:53 AM   #6 (permalink)
K L E A N M O D™
Thai.95LCoupe's Avatar
Car 1: 1995 KA8 *R.I.P*
Car 2: 1997 S14 *SOLD*
Car 3: Millenia S & S14
Originally posted by Mike Diaz
Pics?
Wont beleive untill I see pics...
-1995 KA8 MODIFIED-R.I.P
-1997 S14a-SOLD
-2000 Millenia S
-1995.8 S14a
-Holy Rollerz CCC Member-
-Inspiration™-
Thai.95LCoupe is offline
Old 01-27-04, 05:21 AM   #7 (permalink)
Car 1: 1993 Legend LS sedan, 2002 3.2TL
Send a message via AIM to PerzianKabob
http://www.safetygears.net
PerzianKabob is offline
Old 01-27-04, 07:43 AM   #8 (permalink)
0000$$$$0000####0000
Car 1: Acura
I think it would look cool but it is a bit overkill. As I implied in that posts that you quoted me in, both end up doing basically the same thing in different ways IMHO. Having both is ending up accomplishing similar results. When it comes to chassis stiffness and reduced flex in the suspension I don't think you can go too stiff so you should be more than fine. You just may have more bracing than is needed. However, if we are talking about anti roll bars (Sway bars) I do think you can go too stiff.
I can't wait to see the pics. It would look really nice if you could somehow get the stock bar to match the KMS polished look.
ChrisK is offline
Old 03-11-04, 11:27 AM   #9 (permalink)
Car 1: 1993 blk/blk LS Coupe, 6-spd..... 2001 Honda Civic EX 5spd coupe
There is no such thing as overkill. The stiffer the better.
Quite frankly, I'm getting all stiff about it.
Anyways, we still don't see any pixxx. This would be a lot better with visuals.
Former ride sold to judensacrua :
'93 Legend LS coupe blk/blk 6spd
mods:
-S2000 K&N cone Filter
-Koni red's
-Homemade polyurethane rear tranny mount
9000 is offline
Old 03-11-04, 01:14 PM   #10 (permalink)
Type I King
Car 1: 92 LS Sedan
Car 2: 91 LS Coupe 5 spd
still no pix... LMAO
Hotstartup is offline
Old 03-11-04, 07:26 PM   #11 (permalink)
502MotorSports.com
502 MotorSports's Avatar
Car 1: e39 540i
Car 2: e46 325xi | e46 330i
Car 3: S430
As an FYI, the bar may *feel* light to you, but please note that is has 1- saved a car from being totalled, and 2 - sustained itself in a HIGH speed crash (over
100mph).
Here is supporting proof:
wtnLegend's mishap
dyno at nopi
Jrock7791's old Legend and two punk kids:
[RIP To the car ]
ThaAcSwerver, here's the play by play................................
They were speeding, the rear end slid out and they side swipped a truck. It then shot off the truck like a pinball and hit a concrete "highway" wall!!! The driver shattered his right leg, the passenger sustained very massive head trauma and had to be "cut" from the car with the jaws. 3 people in the back basically walked away, one had a lacerated hand!
The front passenger was put into a medically induced coma for 4 days. They pulled him out of it and monitored his situation. At first we thought he would end up a "vegatable" but he pulled out of it and recouped well as the brain swelling decreased. He will be coming back to work in June!!!!
I would say hitting anything @ 100mph is pretty hardcore, and exponentially detrimental. These guys walked away. That bar helped.
Remember me?? JROCK
not to take this thread off topic, just wanted facts t0 be known ....just because it is not 50 pounds does not mean it does not do the job. One requirement I had was keep it lightweight, but strong. There you have it. I mean, you are not trying to add weight to this car are you?
502 MotorSports is offline
Old 03-11-04, 08:27 PM   #12 (permalink)
JROO
Car 1: 1991 Legend 4dr LS, 2001 Jetta vr6 GLX 5 speed, 2002 Lexus IS 300 5 speed, 2003 Infiniti M45
Send a message via AIM to Chauffeur First
Uh yea....that car is wholly crap.. WOW
J
Chauffeur First is offline
Old 03-11-04, 08:51 PM   #13 (permalink)
Car 1: 1995 CDM Honda Legend Sedan
Send a message via Yahoo to takemorepills
100mph).
Not to be rude, but I don't buy that at all. That strut bar is weak, I can bend it in half with my bare hands. I have actually toyed around with that bar before, flimsy, basically the intake manifold cutouts do it in. I have worked in bodyshops before, you can not even try to give that bar props for some guys being lucky in a car accident. The OEM bar would be much more effective in increasing crash worthiness.
"Sneek-E Honda DA6" "2001 Infiniti QX4 AWD+LSD"
http://www.imagestation.com/picture/...1/f617b751.jpg
Transition to the Darkside
takemorepills is offline
Old 03-11-04, 09:26 PM   #14 (permalink)
502MotorSports.com
Car 1: e39 540i
Car 3: S430
well if you say so....I refuse to get into a flame war with you. The proof was provided in the threads I posted. If it was so weak, and you are He-Man, I wonder why it didn't snap into three thousand pieces at 100mph. Fact of the matter is, when installed, it DOES the job. That is why so many were sold.
end of story
Old 03-11-04, 09:42 PM   #15 (permalink)
I love hot girls.
Car 1: 96 Infiniti I30
Car 2: 03 BMW Z4
Car 3: 04 Bentley GT
Send a message via ICQ to JizJizJiz Send a message via AIM to JizJizJiz Send a message via MSN to JizJizJiz Send a message via Yahoo to JizJizJiz
Wow. Just wow.
-Zack
95 Garnet Red Sedan, L - My most loyal girl, my first love. 02/03/04.
JizJizJiz is offline
