Old 03-26-08, 06:49 PM   #1 (permalink)
Car 1: 1994 legend gs
moonroof stuck
Hi, 94 legend gs. When i attempt to open m/r, passenger side is stuck. Dealer wants major $$$ to fix cable assembly. Is this the prob. or am I getting fleeced. Any help appreciated. Thanks.
bwickes is offline
Old 03-26-08, 07:00 PM   #2 (permalink)
Type 2ed
nino418's Avatar
Car 1: Green 1992 Acura Legend LS Coupe 5 speed MT type II swapped
Car 2: 2002 Honda CR-V EX
Did you close it manually yet? There should be a crank rod in the trunk with the tool kit. Just pop of the lens for the rear passinger dome light and there should be a place to insert the crank. crank it home and.... bingo! closed sunroof. This may also free up the jammed part.
nino418 is offline
Old 03-26-08, 07:05 PM   #3 (permalink)
Thanks Nino. M/r is closed. With the manual tool, do you think I should cycle the roof a few times to hopefully remove debris? Thanks
bwickes is offline
Old 03-26-08, 07:07 PM   #4 (permalink)
Type 2ed
nino418's Avatar
its worth a try, anything that might save you some $$$$ is.
nino418 is offline
Old 03-28-08, 10:22 AM   #5 (permalink)
n8s94ls's Avatar
Car 1: 94 legend ls
Car 2: 89 saab spg
Car 3: 01 navigator
bitter
sounds like a problem i had on a mazda 929 that i had a while back. one of the cables broke, and it wouldn't retract correctly. the dealer wanted about $1200 to repair it and i found a guy parting out his 929 and bought his m/r assembly for $80. it probally took me about 5 hrs to replace it on a sat afternoon. not sure if it's your problem but i hope it helps.
n8s94ls is offline
