Old 10-04-05, 02:44 PM   #16 (permalink)
Car 1: '92 ls sedan forest green
Have you checked to see if the heater control valve is shutting like it's supposed too? 220 degrees is very hot!!!
http://img209.imageshack.us/img209/6665/92ls8io.th.jpg
My Baby!!
1992 Legend LS Sedan - 104k Miles:Aftermarket spoiler: GS rims: Factory block heater
Soon to come:
Projectors W/ 6000k HIDs - Anti-sway bars - LSD - LED turn signals in side view mirrors
logic is offline
Old 10-06-05, 04:04 AM   #17 (permalink)
could be the cat heat coming up, or it could be the heater is on and a duct is loose. Make sure the temperature is set to the cooler side. Also, when a cat heats up, it is usually from unburned gas. You might want to look at it in the dark and see if it is glowing cherry red. If so then you may have a fouled plug or bad cylinder. If it sat in the sun all day in 100 degree weather it would be hot to touch for awhile, but not just from running the car.
Best Wishes
Steve
Merlin the Wrench is offline
Old 10-06-05, 09:34 AM   #18 (permalink)
Car 2: 1994 green LS coupe
Send a message via AIM to Dreams94coup
yea im goin to check out the cat first thing tonite and see if the starts glowing...also i smell fumes in my car after driving for about 45min and to me is smell like gas and im also loosing coolant from the resivoir but i dont know where? my passenger side carpet is dry and there is no residue in the winshield
Dreams94coup is offline
Old 08-06-07, 10:11 PM   #19 (permalink)
92Legendcoupe
bravo659's Avatar
Car 1: 1992 ACURA LEGEND
I was wondering if someone could tell me of my problem with a 1992 Legend.
The other day I was driving and step on it to pass another car and made a right turn. Thereafter, I parked the car and smelled an odor like gasoline. There is no sign of overheating, the gauges are working fine. I open the trunk of my car and smell gasoline. The center console is warm. I opened the hood to find if there is any leak, which there is none. The reason I checked for leaks because I discovered when i arrived at work that somewhere in the engine smoke was emitting then it stopped and noticed a streak of anti freeze. I let the car cool and checked the reservoir for anti freeze, which it was empty. I also checked the radiator and it has anti freeze. I also checked the hoses and they are fine. Later today coming home from work parked my car no sign of leaks. But I still get the gasoline odor in my car and the trunk as well and the center console warm, I also felt the shifter it was warm. Could some one tell what is the problem?
bravo659 is offline
Old 08-06-07, 10:31 PM   #20 (permalink)
Obsessive Enthusiast
antik's Avatar
Car 1: 98.5 BMW M3 Coupe 5MT
Car 2: 95 L Sedan
Car 3: 95 6MT Coupe (Dad's)
Why not start a new thread instead of bumping a 2 year old thread that's totally irrelevant to your problem?
~Ben
antik is offline
Old 08-10-07, 06:46 PM   #21 (permalink)
95typeII's Avatar
Car 1: '95 Legend Coupe LS
Regarding the hot center console... i agree with the others. Check the whole exhaust system to make sure all teh heat shield are still in place. Secondly, check the tranny fluid. Perhaps if its too low the tranny is heating up due to lack of lubrication. If so, you can grind out the gears. I actually added extra heat matting all through the lower center console and shift plate area to reduce the heat.
As for "bravo659" issue... You should start a new thread, although I suggest u search thru because there are old threads that cover this. The gas smell from inside the cabin and the trunk can most likely be due to a leak at the fuel pump, which is located behind the back seat on the floorpan under the cross members that hold the stock amp and other computers.
95typeII is offline
Old 08-10-07, 06:57 PM   #22 (permalink)
Ganja smokes
Car 1: 93 champagne Sedan
kid needs a new tranny.
93gold_legend is offline
Old 08-11-07, 04:12 PM   #23 (permalink)
bjcolema's Avatar
Car 1: 91 Acura Legend LS
Car 2: 02 Nissan Quest
Originally Posted by tgcattle View Post
cat may be clogged
I had a clogged cat on my old Grand Am, and it did the same thing. Sounds like you should not drive it much til you figure it out. I had a Lumina that caught fire for another reason, but it is still not fun. Too hot to touch is getting to the point of combustion...
On my Grand Am, I had a bad coil pack causing unburnt gas to go out the exhaust, which clogged the cat. In other words, you probably have a bad cat, and a spark problem.
bjcolema is offline
Custom Video Installation pics in center console (56K Unfriendly) PoweredbyMe91 Second Generation Legend (1991-1995) 15 01-10-05 05:43 PM
Center Console Monitor project? Anyone? PoweredbyMe91 Second Generation Legend (1991-1995) 6 08-20-04 05:03 AM
Need pix of G2 black center console Volk Racing All-Legend and RL Gallery 1 04-06-04 03:03 PM
center console installation questions matt472 Second Generation Legend (1991-1995) 5 04-05-04 03:49 PM
Question about center console pop-out cup holder? tomas Second Generation Legend (1991-1995) 5 06-04-02 01:16 PM
