my rear suspension is sagging a tiny bit! is it due to weak springs or shocks?
I have stock springs and shocks. They feel good and make NO noise whatsoever.
but I noticed that the rear end is just a bit lower than your normal legend coupe. Would this sag be due to the shocks going bad or the springs goiing bad? or both? |
S K / L L Z
mine did this too, before I lowered. I think it is from metal fatigue on the springs.
Peace, Legendary Legendz CC LegendaryLegendz.com http://images.snapfish.com/342%3A%3B...449%3A53ot1lsi INSPIRATION |
#3 (permalink) | |
Re: my rear suspension is sagging a tiny bit! is it due to weak springs or shocks?
legend fana***
so what is the cost difference between using oem shocks and springs vs. aftermarket, I'm thinking about doing the same thing. My legend is 11 years old and I know the suspension is not what it used to be.
I love this board...
Two days after I come accross a problem and somebody will ask the same question. So I get the answers and save myself the typing
![]() My 91 4D LS has the same sagging in the back. In my opinion it hurts the otherwise awesome stance of the car. Is replacing the springs the only solution to this? If I were to do it is it a do-it-yourselfer or is it for a mechanic? Thanks! |
S K / L L Z
It's a definate do it yourself, if your somewhat mechanically inclined. Me and a friend just replaced all my springs. If your looking for new springs or shocks, go with aftermarket. The OEM parts are more expensive and don't perform as well as say koni's or eibachs.
let's just say I wanna even it out.
If sagging is the case, what would be the cause of it? bad shocks or bad springs? You see, I don't really wanna drop it right now. It looks good just the way it is. I just wanna isolate the problem (whether it be the strut or spring) and replace the strut or spring. I don't want to have to replace both the strut and springs when I only need to replace the struts. |
Thanks LeoLegendATL!
Do the koni's or eibachs preserve the luxury ride of the car though? I don't really want to go the performance route with the Legend (I do that with my CRX ) The Legend I just want to keep in good shape. 91LegendCoupe, I am pretty sure the sagging is due to bad springs. Bad shocks would create dinamic problems (when the suspension is in motion: wabling ride, understeer etc). Somebody correct me if I am wrong, please! |
Sleek And Low
You are correct ikata, Springs control ride-height, shocks and struts control the movement. If your car is sagging then the springs are worn. If your car bounces too much then the struts/shocks are bad.
The koni struts are fully adjustable for ride stiffness, but are a waste of money if you want a stock ride. They are designed to be used in conjunction with lowering springs because their spring-rate requires more aggressive dampening. For example, a car that's been dropped with 1.75" drop springs will bounce too much with a stock strut. A stiffer strut setting will calm the bounce. The setup together will provide a stiffer ride. That's the compromise. Lower=better looks (IMO), better handeling, and a firm to harsh ride depending on how extreme the drop. The Eibach spring has the least amount of drop (1.1") out of the aftermarket spring bunch. The ride is "sporty" compared to stock, but not harsh. You could run an Eibach spring with stock struts. But since your only concern is the ride-height being too low already, you can purchase hard rubber spacers from the dealership to shim up the sagging springs. Much cheaper than replacing a stock spring with another stock spring.
+++Yellow Ducati 996+++ +++1971 Scout II+++ +++2001 BMW 750iL Sport+++ +++1986 BMW 325+++ |
Hmmmmmm. VERY pleased to hear of those hard rubber spacers, Bread!!! Is this a standard treatment for aging springs (i.e. would the dealer know what I am talking about) or is this something that you guys have figured out on your own and the dealer happens to carry them. I assume, since it was already mentioned that replacing the springs is a do-it-yourselfer, that I can do the rubber spacers as well, correct? Now here is a good weekend project... I would love to get the rear of the car a little higher as it seems it was intended to be. Thanks for the good info!
502MotorSports.com
In additiono to what Bread said, you can actually get those rubber spacers from your local Pep-BOys, Advance or Auto Zone for like $4-$5.
Mount them in the same position on each coil...i.e. coil 1, coil 2 coil 3 each have one at 3 o'clock, and then another 3 at 9 o'clock. I hope you get the gist of what I am saying...if you can imagine your spring here -----> [] 3 o'clock is the right, 9 o'clock is the left side. You do this on both sides of the car, which means you need a total of 3 packs of spacers (4 per pack). Good luck
The Hotness! Elevate Your Standards.... Legend Mod Money! Jasmyn | Final e39 Pics | 502MotorSports MySpace |
#13 (permalink) | |
Antother option may the OEM springs and The Koni shox on the upper perch and soft setting. I believe Chris K has this setup. I seriously doubt if the springs are bad, sounds like the shox are going out. |
#15 (permalink) |
Sleek And Low
CakeDaddy is referring to the fact that the Koni struts have an adjustable spring perch mount. There are three notches cut into the strut where you can adjust the ride-height by about an inch up or down. This is not the option for you because as I mentioned earlier, Koni struts are a waste of money if you're looking for a stock ride, and that notch will lift the car much higher than you want to go. Forget this option.
Leon, the spacers at the auto parts store are not the ones I'm talking about. Those Pep Boys spacers are wedged in-between the springs and could potentially fall out when going over large bumps. The spacers I'm referring to are rubber rings that are the diameter of the spring. You pull the strut apart, remove the cap and place the spacer on top of the entire spring, then put it back together. I originally purchased these from a Chevy dealer for my S-10. The factory had stamped the control arm a bit off on one side causing it to sit un-even, so this spacer was the fix for it. The ring looked like it was cut out of an old tire-tread.
