Old 07-23-08, 12:48 PM   #1 (permalink)
MR. KA8
Question Need Help with Dash
I have a 92 Legend KA8. And when i purchased it a couple days ago I discovered that the dash doesn't work as good as it should. The speedometer doesn't work properly and the ABS warning never goes off and the brake warning light stays on. What should i do?
tj93KA8 is offline
Old 07-23-08, 12:55 PM   #2 (permalink)
Ac N Up
95AcLegendOwner's Avatar
Car 1: 1995 Acura Legend Sedan
Car 2: MARC Train
That's kinda weird. Try disconnecting the negative battery cable for 1 min. I don't know if it'll work but its worth a try. Also, check your brake fluid level. That could be the reason your brake light is on. (unless you talking about the brake lamp light. if that is on then you either have a blown brake light bulb or one of the sensors are bad.) Hope this helps.
This is not my KA9. Just had to take this picture.
95AcLegendOwner is offline
Old 07-23-08, 01:41 PM   #3 (permalink)
CAP CAP M* F*R!
sam o nela's Avatar
Car 1: '87L, 5 speed Sedan
Car 2: '71 Datsun PL521
Does your ABS pump make funny humming or clicking-type noises? Your speed sensor may have issues, and your brake fluid may be low OR the E-brake wiring is grounding out....
Also, does your Check Engine light light up at least during start up?? If not, I hope some unscrupulous seller didnt remove the bulb before selling you the car
sam o nela is offline
