Need help on Diff removal
I need to replace the oil pan on my 91 and I'm having some trouble getting the differential off. I have the axles and intermediate shaft out already but I can't get the extension shaft to budge out of the tranny.
I don't have the puller tool and I'm using an 8mm bolt with some washers on it. The thing just won't move and I'm afraid I'm going to break the bolt off in the shaft if I put any more pressure on it. What I would like to know is how much pressure it should take to pull that shaft out. Also, is there any way to pull the oil pan without removing the diff? Another thing, I'm not sure if it makes any difference but after the battery was pulled I I needed to move the car so I used the key to put the shifter in nuetral without power. I put the car back in park, but without power. Thanks in advance. |
Legend owner
i believe that you have to loosen the tranny up from the back of the engine a little bit to give it just enough room for the diff to slip off of that shaft.
mods: - Auto to manual tranny conversion - intake - exhaust setup - Bayou stage 2 - Throttle body coolant bypass - 17" wheels - Tint - Pillar gauges - lowering - clear bumper lights - Jdm headlights - Short shifter mods to come: - y-pipe and hi-flo cat - engine rebuild with performance parts - SAFC-II - Turbo if it comes out... - Koni struts - LSD - Stage II clutch - carbon fiber hood and spoiler - Slotted/cross drilled rotors |
#3 (permalink) | |
![]() The Haynes manual says the extension shaft should pull out of the back of the tranny far enough to remove the set ring which locks the shaft into the tranny. My problem is that the shaft won't budge so I can't get to the ring. |
Car 1: 95 Legend GS (Main Baby in Garage) & 94 LS Cpe 6 Speed (Main Driver & Fun) Car 2: 93 Legend LS 2dr 6sp iTrader: (2)
Mine slid out by hand.
Mine only required fingers to pull it out and disengauge the splines. Put your trans into neutral and that should take some of the pressure off. You may already have moved it back. Try pushing it forward.
I'm the one with the Limited Slip Differentials (LSD). We can build what you need!Users of LSDs: Newest Customer - sr79labrat Third - Me!! Second Customer - Kenso First Customer - LEgEnD4LiFe 95 Legend GS w/Koni shocks, all else stock 94 Legend LS Cpe 6-Speed w/Konis, Race Brakes, braided lines, AND the 3rd LSD built by us but the first to be installed!!!!! *New* - 86 CRX w/D16A Conversion Now with TURBO!! |
#8 (permalink) | |
take the cap off then screw in a 12mm bolt(m10 or m8, 1.25 or 1.50 pitch) in with a big washer on the end then use a ball joint(like a wish bone) seperator with an pipe extention to pop it out. Helms service manual is a big help. ~TRu Hybrid
#9 (permalink) | |
Let me know if you have any other questions. -James |
VIP alllll the way
dont forget this step!!!
http://www.directimagehost.com/is.ph...ial-mod-si.jpg Throttle Body Coolant Bypass General F.A.Q. 2nd Generation F.A.Q. People I trust to buy items from: bboarder711 | legendarysleeper | Chauffeur First | SmartJay28 |
You can't pull the pan without pulling the diff, you can't pull the diff without pulling the extension shaft. If the shaft will not come out you'll have to pull the trans first. The only time I've seen one get that stuck was when the splines filled up with rust. That took a 4 lb hammer and a large punch to drive it out from the inside.
PSA |
| Differential Removal Question | James92LS | Second Generation Legend (1991-1995) | 5 | 05-27-05 02:03 PM |
| Who Knows the REAL Diff on the Diffs? | canook2u | Second Generation Legend (1991-1995) | 3 | 11-04-04 05:16 PM |
| Diff Oil/Motor Oil Question. | thesmoothone | Second Generation Legend (1991-1995) | 8 | 08-24-04 04:10 PM |
| Thought diff was leaking but must be engine oil. | PoodleHead | Second Generation Legend (1991-1995) | 0 | 03-05-04 02:03 PM |
| Tranny & Diff Fluid | Mtnduey | Second Generation Legend (1991-1995) | 12 | 08-24-02 06:33 AM |
