Old 06-03-07, 03:38 PM   #1 (permalink)
lgnd4u2nv's Avatar
Car 1: 1991 Acura Legend
Send a message via AIM to lgnd4u2nv
Need insight on if my alternator or starter is bad please
ok so last night when i was driving home i was listening to my system and when the bass hit the lights would dim...this usually doesnt happen. so i got the idea that my battery might be going bad. i parked it over night, and this morning when i went to go to work, i stuck the key in and turned it and NOTHING happend.
no dash lights, no anything.
so i tried to jump it off of my friends car. while the cars were connected, i tried to start it, and the dash lights came on, but all it did was click. it click repeatedly while i was holding the key in the start position, but i saw no sign of power going to the engine.
i pulled the battery out, and took it to autozone and it tested as a good battery.
what could it be alternator? or starter?
thanks
MAY 10TH CHARLOTTE NC LEGEND MEET! CLICK HERE
Winter NC meet picture and discussion thread!
lgnd4u2nv is offline
Old 06-03-07, 05:15 PM   #2 (permalink)
IAmLegend's Avatar
Car 1: 93 LS Sedan
Car 2: 90 Camry DX
sounds like the starter. if the alternator is bad it doesnt effect your start up (provided the battery is charged). the alternator is only in effect once the engine is started.
the fact that you mentioned headlights dimming sounds to me like the battery. so does the click. i would just to be sure, jump your car thru a good car, but instead of putting the jumper cables to your car battery, connect the cables directly to your battery cable. if still nothing, you could have bad battery terminals/cables! this happened to me before and i thought it was my battery, but it turned out i just had old brittle cables and chewed up terminals.
if you still get nothing doing a jump like i mentioned, try hitting the starter with something. a lot of times if u hit it, it will revive temporarily. if hitting the starter at least makes it crank or somethin, you know its the starter.
worst comes to worst, take out the starter, take it down to autozone, and have them bench test it to double check
IAmLegend is offline
Old 06-03-07, 05:25 PM   #3 (permalink)
DrDave's Avatar
Car 1: 94 LS Coupe'
Car 2: 91 NSX
Car 3: various cars & bikes
Hi:
I think you can rule the starter out. Your problem occurs during running not just starting. You need to check a couple of things. First, all testing must be done with a fully charged battery. Read the last sentence again out loud.
Here is a quick diagnostic test procedure.
1. Charge the battery;
2. check the resting voltage. it should be ~12.5-13 volts.
2a. Check for bad/loose/dirty battery connections.
3. Have the battery load tested. Weak battery or dead cell - replace battery.
4. If good, start the car and check the battery voltage with no load. It should be 14.2 volts.
5. Turn on the lights and fan. Rev the engine to 1500 rpm. The alternator should keep up with the load. If voltage is below ~13.8, we have a charge problem.
6. Turn on your stereo and check the voltage. If everything checks okay you need to look for a drain on the system.
7. Report back the results for the above and I will direct your next diagnostic plan.
I have to go work on my motorcycle. I will check back later. Don't worry, we will work through this together.
Dave
DrDave is offline
Old 06-04-07, 02:22 AM   #4 (permalink)
IAmLegend's Avatar
Car 1: 93 LS Sedan
Car 2: 90 Camry DX
Originally Posted by DrDave View Post
Hi:
Dave
he has a good battery. autozones tester should load test it for CCA's and voltage. i work at Kragens i know what the testers test. hes got a good battery and its still not starting, so he has a starting problem, not a running problem.
btw lgnd4u2nv, if you do get the car started and running, as DrDave said you want to have the whole electrical tested out to make sure everything is good. taking it to an auto parts store that does free testing will be able to test all of your components while they are in the car as long as the car will start.
Old 06-04-07, 03:08 AM   #5 (permalink)
DrDave's Avatar
Car 1: 94 LS Coupe'
Car 2: 91 NSX
Iam legend:
How did you determine that he had a good battery?
Dave
DrDave is offline
Old 06-04-07, 03:09 AM   #6 (permalink)
DrDave's Avatar
Car 1: 94 LS Coupe'
Car 2: 91 NSX
Iamlegend:
Please tell me what meter you use to identify a cold cranking amp vs. any other kind of amp?
Dave
DrDave is offline
Old 06-04-07, 11:09 AM   #7 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
Car 2: 93 Coupe LS 6SPD :(
Car 3: 99 2.3CL 5spd
I'm with dave. its NOT the starter.
If his battery was completely drained. there is no way you'll start on a jump alone. you'll need the battery to charge up a little b4 it'll start.
sounds like u have a alt issue+ and light battery drain (common on our cars, and most cars, aftermarket alarm, amps, stuff like that, a uncharged battery will die quickly)
~Alex
94 GS
Alperovich is offline
Old 06-04-07, 12:12 PM   #8 (permalink)
FIXER
Sounds like a bad connection at the battery. Clean them and make sure they are tight. Start it up then check the voltage at the battery. It should be around 14 volts when running.
Jetdoc is offline
Old 06-04-07, 02:50 PM   #9 (permalink)
IAmLegend's Avatar
Car 1: 93 LS Sedan
Car 2: 90 Camry DX
Iamlegend:
Dave
the reason i determined he had a good battery was he said he got it tested at auto zone. they have testers that put a load on the battery and measure the CCAs and voltage. therefore, if they said he has a good battery, it should be good.
im not sure what meter the tester uses or how it works, but i know that they have devices for testing batteries that are supposed to be accurate.
Old 06-04-07, 07:40 PM   #10 (permalink)
Kenso's Avatar
Car 1: 91 L Coupe 6 spd
Car 2: 95 FZJ 80
Car 3: ITR 00-106
Personally I don't trust Autozone or the people that work there for shit. Wouldn't surprise me if the battery was in fact bad.
ITR 00-106
91 6spd coupe
95 FZJ-80
Kenso is offline
Old 06-04-07, 09:01 PM   #11 (permalink)
lgnd4u2nv's Avatar
ok, well what happened was i got the battery tested, so i called a friend to come help me pull the alternator out to have that tested.
so when he got to my house i put the battery back in and connected the terminals....i turned the key to show him the clicking sound.....but what do ya know....IT STARTED RIGHT UP
i dont know if i should be happy or mad.
im gonna take it to my regular shop and have them inspect the whole electrical system.
Old 06-04-07, 09:40 PM   #12 (permalink)
On a Mission.
Philendrick's Avatar
Car 1: 2001 Acura CL-S
Car 2: 94 Legend L Coupe
Send a message via ICQ to Philendrick Send a message via AIM to Philendrick Send a message via Yahoo to Philendrick
Sounds like a bad connection at the terminals, or bad terminal wires.
Philip
2001 CL-S
94 Legend L Coupe (To Be Restored)
94 Legend LS Coupe (Sold & Missed)
"Remain respectable in everything that you do, to earn the respect of others, and to learn to respect yourself."
Philendrick is offline
Old 06-04-07, 10:22 PM   #13 (permalink)
I'm the Stig!
Alperovich's Avatar
Car 1: 94 DM GS
that or autozone charged the battery b4 testing it. OR the jumper pack gave it enough boost to start.
~Alex
94 GS
Old 06-04-07, 10:31 PM   #14 (permalink)
DrDave's Avatar
Car 1: 94 LS Coupe'
Car 2: 91 NSX
lgnd4u2nv:
It sounds like you are on step "2a." Now continue and don't skip anything. You will feel better about this whole deal if you follow the procedure and find the problem.
Dave
DrDave is offline
Old 06-05-07, 02:39 AM   #15 (permalink)
IAmLegend's Avatar
Car 1: 93 LS Sedan
Car 2: 90 Camry DX
doesnt surprise me. ive had batteries do that to me before. just know that there is a possibility that something could happen in the future. A) you could have a bad battery. they go in and out sometimes. if it looks old and is old, it might be time for a new one
but i bet theres also a really good chance you had a loose battery terminal and when you re-installed it, you fixed that problem
Problems...is this the alternator, ignition starter, or the battery DarkLegendZ Second Generation Legend (1991-1995) 24 09-16-06 04:42 PM
