Old 04-28-07, 04:03 PM   #1 (permalink)
Car 1: Acura Legend L (1993)
New To Legend, Please Help!
Good day, everyone.
I'm new to these forums, and I really like the advice that everyone has to offer here. I'm also new to the Legend, and was hoping that someone could help me out.
I just got a Canterbury Green 1993 Acura Legend L with 192,000 miles on it. A week ago, I noticed that there was smoke coming out of the engine. Opening the hood, I find antifreezing flooding all over the place! It looked like there was a small hole coming from one of the hoses connecting the radiator to the engine.
My dad and I cut that hose and re-fit it, but a day later antifreeze starts to leak again. There was a hole coming from one of the hoses on the bottom of the car, so we replace that too. The next day, a leak happens from somewhere else!
This was all happening after we replaced the OEM radiator for some other one (probably cheap; I guess that may have not been a good idea). Was this all because of the radiator swap? Sorry for the long post, but I am really new at this.
Thanks!
trackfire1987 is offline
Old 04-28-07, 04:13 PM   #2 (permalink)
I'd shit on you for free.
BUSINESSMAN07's Avatar
I doubt it was because of the radiator swap, you just need to change all your hoses. If the car has overheated Before then the hoses needed to be replaced then. when the hoses get too hot they start to warp and are more prone to leaks.
Originally Posted by DandDEE View Post
you should teach her to make u some eggs like "bitch make me some eggs" ...
Originally Posted by ymisoqt
this forum is pretty cool though. Unless you are talking about politics
BUSINESSMAN07 is offline
Old 04-28-07, 04:26 PM   #3 (permalink)
Assman
quanaman's Avatar
Car 1: 1994 Honda Accord EX VTEC
Car 2: Missing my GS :(
Send a message via AIM to quanaman
I concur.
I'm Parting out TWO Black/Black Sedans. MANY MANY Parts available. PM me.
Sold MY 94' GS:
http://www.acura-legend.com/vbulleti...legend-129270/
94' Acura Legend GS
-158k Miles, Timing Belt DONE, Head Gasket: DONE, Tail Light Red-Out: DONE, Tint (35%): DONE, Viper Remote Start/Keyless Entry DONE
Progress Thread
quanaman is offline
Old 04-28-07, 04:28 PM   #4 (permalink)
Spiral descent
telafonic's Avatar
Car 2: KA7_8 SWP 6-speed
Car 3: 1996 A6
The hoses probably needed to be changed anyway.
When you did the swap, either the hoses weren't retightened well enough, or more likely the hoses are just old and won't seal very well anymore. They sealed well on the OEM radiator because they've probably been there since new.
telafonic is offline
Old 04-28-07, 06:07 PM   #5 (permalink)
Welcome to my head
Socol's Avatar
Car 1: CL-S (Daily Driver)
Car 2: ObsidianBlack KA8
Maybe the hoses popped because there is too much pressure in the cooling system; make sure you bleed all the air out.
Socol's Basic Website
Socol is offline
Old 04-28-07, 07:44 PM   #6 (permalink)
Thank you for all of your kind replies; this forum is already of much help.
Is there any way to detect which hoses are in need of replacement; or must I drive the car and find the defective hoses "the hard way?" So far, I have been doing test drives with the car in all sort of situations that would cause lots of coolant activity, and I'm not sure if this is the best way to do it.
Old 04-28-07, 08:15 PM   #7 (permalink)
B**k F***er
NickD's Avatar
Car 1: 1991 Frost White L Sedan
Car 2: 1999 BMW 328i 5speed
Send a message via ICQ to NickD Send a message via AIM to NickD Send a message via Yahoo to NickD
There are only two main hoses that carry all the pressure. The upper and lower hoses. You can replace both of those for <$30 in parts. However, make certain you bleed the system. Do a quick search on here for bleeding the cooling system. It is a very crucial and exact procedure to scavange all the air from the cooling system in our cars.
NickD is offline
Old 04-28-07, 08:40 PM   #8 (permalink)
RALPHS HANDS ARE CLEAN!
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
+794,965,986,794,655,979,456,123,560
blkonblkcpe is offline
Old 04-28-07, 09:25 PM   #9 (permalink)
I would Just take it in and let mechanics replace all what? 24 of them. that may be a bit of a large investment, but I promise it will be worth it.
I've replaced Just the two main hoses Before and the car ran fine, but when I replaced all hoses I actually say a temperature drop by a whole bar, I checked the smaller tubes and they were full of gunk. the mechanic that replaced them said that wasnt good and was putting stress on my water pump
also a word of advice, Dont use the radiator plug crap if you have a leak, yes it may fill the whole but it fills everything else... = Blockage = more heat = eventually bhg.
Old 04-28-07, 10:13 PM   #10 (permalink)
Car 1: 91 blk on blk legend
I bled the hell out of my system and couldnt figure out where the air was coming from after i bought this new radiator. I later found out it wasnt the air bleeding thing...... it was a missing thermosensor. So make sure u have a thermosensor/rad. switch in ur radiator( located at btm right next lwr rad. hose)cuz i bought and returned 2 radiators b4 i found out bought this thermosensor thing. 3 diff. brands of radiators and NONE of them came with thr rad. switch. had to get 1 from advance auto for $4x.xx . They usually put a dummy plastic peice in place of it.
vgeezy31885 is offline
Old 04-29-07, 09:20 AM   #11 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
No aftermarket radiator will include a thermosensor. The only time I bought a radiator with one already installed was a new OEM Nissan.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
LPB is offline
Old 04-29-07, 09:26 AM   #12 (permalink)
LPB
Originally Posted by trackfire1987 View Post
Good day, everyone.
Thanks!
You have an old car which will require constant maintenance simply because it is old and parts are reaching or have reached the end of their service life. This is the trade-off between old vs new. You need to replace all of the coolant hoses ASAP. You don't need another hose break miles from home in the dead of night.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Clear Corner Lens
Clear Bumper Lens
Gold Pkg
LPB is offline
Old 04-29-07, 04:20 PM   #13 (permalink)
You don't Not fun... Good thing I had connections from this forum, Or I would still Be there...
Old 04-29-07, 05:10 PM   #14 (permalink)
FIXER
You may not have the correct radiator cap on the new radiator or you have a bad cap. The cap should relieve the pressure inside the system if it gets higher than 16 psi. If the cap doesn't relieve the high pressure something will blow, hose, radiator, ect...
Jetdoc is offline
how many legends? ndhduong Second Generation Legend (1991-1995) 42 08-24-08 11:30 PM
New Legend Owner...lots to say/ask ALoneR Second Generation Legend (1991-1995) 28 10-30-06 02:45 AM
91 Couple L auto clean title $2000.00 Vintagecarman Legend 2 12-01-05 08:49 PM
Legend vs. kitted out Legend vs. riced out Civic ThaAcStangSwerver Track Racing 7 09-06-02 07:51 PM
Guess who's back in the Legend Family??? SammyD Second Generation Legend (1991-1995) 46 08-27-02 09:15 PM
