Old 05-20-07, 12:21 PM   #1 (permalink)
Gangster Legend Owner
LEgEND-FEiGN's Avatar
Car 1: 1992 Legend L Sedan 270k
Car 2: 2000 infiniti i30
Send a message via AIM to LEgEND-FEiGN Send a message via MSN to LEgEND-FEiGN
no air in the system...a good thing?
a few times my needle moved but then went right back down...we bled it and there was a lot of air in the system and then it was fine for a few days...then it moved again just a little...but this time no air when i open the bleeder or when i take the cap off...also the reservoir is low and theres a little coolant dripping on the right side underneath the overflow tank...sometimes i smell coolant and sometimes i dont...i bled it again and left the bleeder open while i added coolant, the needle hasnt moved since..but is it a good thing that theres no air?
LEgEND-FEiGN is offline
Old 05-20-07, 01:28 PM   #2 (permalink)
no ideas?
Old 05-20-07, 03:28 PM   #3 (permalink)
AKA Nicco Bellic
Car 2: 1966 Mustang
Car 3: 06 GTI 2.0 turbo
I wouldn't really say theres anything "good" about your situation. Get that leak checked out asap or the problem will get alot worse and more expensive to fix.
DevanTheDude is offline
Old 05-20-07, 03:30 PM   #4 (permalink)
pro_foundac91's Avatar
Car 1: 91 GOLD GLOW PEARL LEGEND SEDAN L
yea. what he said, get that leak fixed FAST.
pro_foundac91 is offline
Old 05-20-07, 03:45 PM   #5 (permalink)
it goes up every know and then and it seems to be pushing it up out of the overflow tank..but theres no air in the system when i open up the bleeder
Old 05-20-07, 05:28 PM   #6 (permalink)
it will only get worse..trust me on this one.
Old 05-20-07, 07:15 PM   #7 (permalink)
how would i know if i have a bad thermostat?...my upper hose has no pressure in it at all. even after running for a while..
Old 05-20-07, 08:43 PM   #8 (permalink)
Terminal Psychotic
SickRick's Avatar
Car 1: 95 LS Black on Black 6 speed, 93 LS Black and Tan (Guinness) 6 speed
Car 2: 75XB MadMax sedan
Car 3: 75XB MadMax Coupe
There IS air in there if there is a leak.It might be ONE bubble...seen that before. It can take a awhile to get the air out, even when you think your done...your not. Park it on a hill and bleed it. Sometimes air gets "trapped", so turn on your heat and twist the knob all the way...only way to really bleed it all....Hurry it up too, before it gets worse, or else...
Also, I was feeling pretty good today so I didn't say anything, but you should do a search...It's all there
SickRick is offline
Old 05-20-07, 08:47 PM   #9 (permalink)
im kinda tryion to rule out a bhg..i have plenty of heat and it doesnt go to the H when the needle moves. i have tried searchin but couldnt find anything about the thermostat,, thanx for the help tho. y would my upper hose not have pressure in it tho?..and how come i can go for a 30 minute frive and still be able to just open my cap? also ive lost about half a gallon of coolant this weekend
Old 05-20-07, 08:52 PM   #10 (permalink)
MAD DOG!
dgandul's Avatar
Car 2: 92 LEGEND LS
if you keep running your car like that youll end up with a blown head gasket... just change the tstat with a oem one, and get a overflow tank from a yard. bleed it like 4-5 times before you call it a day. if the temp gauge moved you gotta get something fixed... when did you do a wp/tb change???
dgandul is offline
Old 05-20-07, 08:56 PM   #11 (permalink)
the car has 267k on it and the last time it was changed was at 190..it says on the engine its due at 280 so its gettin close..i dont wanna drive it like it is caus ei really dont feel like doin the hg but i will if i have to..
Old 05-20-07, 11:07 PM   #12 (permalink)
Obsessive Enthusiast
antik's Avatar
Car 1: 98.5 BMW M3 Coupe 5MT
Car 2: 95 L Sedan
Car 3: 95 6MT Coupe (Dad's)
If the needle is moving, you've got issues, as everyone has mentioned.
If the needle goes up while the car is idling but accelerating or applying throttle corrects it back to normal position, your thermostat is stuck closed and is sprung open when you accelerate. Replace the thermostat with an OEM part immediately.
Reading the BHG thread might prove to be a big help. It could be something so simple as a bad temp sender unit but I'd rule everything else out before blaming the sensor.
And like everyone says, don't drive it around while it's like that!
might be selling: pm me if you're interested in a well cared for, well running, high mileage sedan
antik is offline
Old 05-20-07, 11:23 PM   #13 (permalink)
thanx for the help everyone...im goin to acura tomorrow to get a cap and thermostat and im gonna flush all the cooland too as well as clean out the overflow bottle...wish me luck..thanx again
Old 05-21-07, 04:55 AM   #14 (permalink)
MAD DOG!
dgandul's Avatar
Car 2: 92 LEGEND LS
lol its like catching car cancer early, have to stop it before it gets into the bone. death to the car.
dgandul is offline
Old 05-21-07, 05:21 AM   #15 (permalink)
legend mechanic
I've had numerous leaks on my Legend before, from cracked endtanks, bad radiator seal, to freeze plugs loosing. I lost up to four liters of fluid from my cooling system. None of those caused overheating or air entering into the system. Well, that's my case.
Recently, it started having the exact symptoms as described by LEgEND-FEiGN. It was surely the heasgasket. The coolant had a hint of gasoline fragrance. A very slight hint, like the vanillia in Chanel No. 5. Again, that's my case.
The last thing I want to be in is BHG denial.
the_invisible is offline
Air in cooling system fatjoe216 Second Generation Legend (1991-1995) 1 08-10-06 10:50 PM
heather core causing air in cooling system. DJPolak Second Generation Legend (1991-1995) 10 12-20-04 02:57 AM
Bleeding out air wrong? (Attn. BHG/Coolant guru's) Plopper Second Generation Legend (1991-1995) 24 09-01-04 12:18 AM
Air leak into the Coolant System Ninjakal Second Generation Legend (1991-1995) 3 06-14-04 08:26 PM
Cooling System, Air Conditioning Problems volksowner First Generation Legend (1986-1990) 33 08-07-03 01:50 PM
