Old 01-24-07, 10:36 AM   #1 (permalink)
legendcrazy's Avatar
Car 1: Legend Sedan
OEM Keyless Entry Brain
Can any body tell me where the OEM Keyless Entry Brain is it the part where you stick your key into?
legendcrazy is offline
Old 01-24-07, 10:51 AM   #2 (permalink)
Not one to mess with
Litho's Avatar
Car 1: 1994 Acura Legend GS
Car 2: 1995 Toyota T100
Car 3: '63 Austin He/sprite
Send a message via AIM to Litho Send a message via Yahoo to Litho
The OEM keyless entry brain is under the dash on the drivers side. It is in the lower plastic piece that comes off (it has the ignition key hole in it and the strip of optional buttons). If you remove that piece you will see the keyless entry inside of it.
Litho is offline
Old 01-24-07, 11:23 AM   #3 (permalink)
Proud FORMER Legend Owner
Shaar's Avatar
Car 1: 97 Accord Wagon (SiR)
Car 2: 92 Lexus SC400
Send a message via AIM to Shaar
are you needing one or just want to remove yours? and how Litho described it is correct. Remove the lower panel on the driver side, and if you have one it should be under there, i think a somewhat shiny box, with green plugs or the 'female' end of where plugs would go. Good luck!
Shaar is offline
Old 01-24-07, 12:27 PM   #4 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
The opening which you stick your key into is a reset for the service reminder which will change from Green to Red every 7,500 miles. Has nothing to do with the keyless entry system.
Before you remove the panel under the steering wheel, why don't you first determine whether you have an OEM keyless entry system installed? The easiest method is to look at the very bottom edge of the panel on the LT side and see if there are two screws or two plastic screw caps (mine are black in color) about 1.5 inches apart. These screws mount the OEM keyless receiver to the back of the panel. No screws; no OEM keyless.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
LPB is offline
Old 01-24-07, 12:31 PM   #5 (permalink)
Car 1: Legend Sedan
I was trying to find a ground for my dash kit But I got it Thanks.
HELP: Problem with Keyless Entry Installation in G2 (DEI Valet 712T) S4gunn Audio, Video, & Electronics 3 12-03-05 01:38 AM
fs: OEM Keyless entry brain, remote, harness kit! maxt OEM Parts 9 07-21-05 09:11 PM
FS: OEM Factory Keyless entry system WhiteLegend OEM Parts 4 08-02-04 12:25 PM
Keyless Entry Brain and OEM Alarm Votinh Second Generation Legend (1991-1995) 5 10-29-03 03:20 PM
Disecting OEM keyless entry... Second Generation Legend (1991-1995) 3 02-05-03 01:17 PM
