Old 09-11-05, 03:13 PM   #1 (permalink)
Hi
Send a message via AIM to Herb
OEM Shocks Vs. Konis
I need new shocks.
OEMs are $162
Konis are $133
The price difference is negligable.
I will be using the existing springs as I do not wish to lower the car. Is there any real reason to replace the springs as well at this time ($110/ea??)..
I'm wondering if the Konis offer any real benefits. Is the handiling actually improved? I have been extremely happy with the stock ride, especially at high speeds. (95% of my time I am on the highway) At least, are they as good as OEM?
I will also be doing the ADDCO rear, why not..
-- Aaron
OBAMA
SUCKS
Herb is offline
Old 09-11-05, 03:51 PM   #2 (permalink)
UNCLEgend
go92Legend's Avatar
Car 1: '92 Vineyard Grey LS Sedan
Car 2: '05 TSX Gray auto
Car 3: '08 MDX Steel Blue/T
If you're really happy with the stock ride, I'd stick with OEMs. I got Konis on stock springs and love 'em, but the ride is slightly, but noticably more taught than stock.
--Gerry
"All opinions expressed above were left over after the good ones had been taken..."
go92Legend is offline
Old 09-11-05, 09:20 PM   #3 (permalink)
legend status
Car 1: 1995 6spd coupe
Thed difference in handling between oem and koni shocks is night and day. I say go with the Konis.
1990 Legend sedan - RIP
1995 6 spd coupe
acc-unit is offline
Old 09-11-05, 09:33 PM   #4 (permalink)
NY Member
Car 1: Type I, KA8, Auto
WHat is the difference? Please explain Acc-unit.
Thanks,
Eric
http://i37.photobucket.com/albums/e7...sigs/sig-1.jpg
TL-S wheels, Specific Remus, Koni Reds on low, Two-Tone Leather, EDM corners, PIAA fogs, more to come.......
frantinez63 is offline
Old 09-11-05, 10:08 PM   #5 (permalink)
UNCLEgend
go92Legend's Avatar
Eric, I'm not sure what acc-units experience is, but I switched from OEMs to Koni's at 184K miles. That means I had pretty soft OEMs at the switch. That being said, the cornering has been noticably crisper and the vertical response to ruts and minor potholes has been much more damped with the Koni's. I move to a neighborhood with significant "ruts" in the streets designed to drain snowmelt and it brought out the flaws in my old OEM shocks. When I switched, it was MUCH better in terms of damping response. The wonderful side benefit was cornering was more secure and I could occasionally swing the rear end out. If handling is your thing, Konis are really great. If stock ride is the goal, OEMs are the better choice in my opinion.
Gerry
--Gerry
Old 09-11-05, 10:30 PM   #6 (permalink)
dealer-opted track pack
mrkeith's Avatar
Car 1: ka8
Car 2: chevro-legs
Konis on soft felt 20%-30% more stiff than the factory struts to me.
To be honest, I did not think the handling benefited incredibly from the Konis alone.
Handling was much more improved with lateral reinforcement: strut tower and sway bars.
I would still buy the Konis, though.
Good Luck,
k.h.
P.S.
P.M. me if you have any in-depth questions.
I went from stock to Koni's on full soft, to Konis on full stiff and soon to JICs
mrkeith is offline
Old 09-11-05, 10:30 PM   #7 (permalink)
Hi
Konis from Tirerack it is. Any objections?
OBAMA
SUCKS
Herb is offline
Old 09-12-05, 05:40 AM   #8 (permalink)
legend status
Gerry
Thank you, lol. Yeah I mean that pretty much sums it up, the "drifty" feeling is less noticable upon installing the koni shocks. And unless you are hitting some serious pot holes the damping is hella good for performance shocks ( and I say this with confidence because I have 19'' wheels). However, I installed the shocks at the same time i installed the koni sport springs so maybe my observations are bias.
1995 6 spd coupe
acc-unit is offline
Old 09-12-05, 11:15 AM   #9 (permalink)
NY Member
Acc-Unit,
What settings have you had your kit on? I plan on keeping it on stock height for the winter, is that possible? And, then later dropping it an inch or two for the summer.....does that sound feasible to you?
LMK...thanks,
Eric
Old 10-06-05, 08:40 PM   #10 (permalink)
NY Member
BUMP! Can anyone answer my previous question?
Thanks,
Eric
Old 10-06-05, 08:43 PM   #11 (permalink)
Avarice's Avatar
Car 1: 2001 VW Jetta 1.8T WE
Car 2: 2002 Honda S2000
Thanks,
Eric
Unless you plan on getting Ground control adjustable shocks, you are pretty much stuck with whatever setting you choose during the install of your koni's unless you remove the entire strut assembly. Your best bet is to set them (perch settings) mid in the front and highest on the rear.
[img]
My 1991 Legend (SOLD)
Sedan Type-F floor mats
Driver Side seat (free)
OE + Denso Filters for cheap
Throttle Body
TL Engine Cover
Avarice is offline
Old 10-06-05, 09:34 PM   #12 (permalink)
Avarice's Avatar
Originally Posted by arnach
I need new shocks.
OEMs are $162
Konis are $133
-- Aaron
I would strongly advise against using Koni's and OEM springs. The ride isn't so great. Do a search and you'll see what other members have said.
If you are happy with the current setup, get a set of KYB's. If you want aggressive handling - get a set of Eibach or H&R springs. Seeing that you
[img]
Throttle Body
TL Engine Cover
Avarice is offline
OEM Cabin Air Filter Replacement with NON Oem Filter Mtnduey DIYs 23 12-17-07 11:41 AM
KYB vs OEM Shocks anthony415 Second Generation Legend (1991-1995) 6 03-02-05 01:59 PM
Pros and Cons of Eibach Prokit with OEM shocks Mckenzie93 Second Generation Legend (1991-1995) 6 07-16-04 01:16 PM
F/S front shocks OEM LEGENDARY 93 OEM Parts 1 05-01-04 05:01 PM
OEM shocks vs Konis info needed vrb747 Engine & Performance Modifications 8 05-12-02 11:42 PM
