B anned (SIKE!!!)
OEM suspension Question...
Ive noticed that 91-93 Legends sit a bit higher than 94-95 Legends.
Is there anything different in those years that would change that? I thought they all shared the same setup...
Check out my new wheels..... http://www.acura-legend.com/vbulleti...9/#post1243334 |
B anned (SIKE!!!)
Cummon... Anyone? Where are the suspension guys at??? Take a look at my sig and this photo of Tysons coupe enxt to mine.
B anned (SIKE!!!)
Um... I think it would also include my SE. It sits a bit lower than my Coupe... Even before the rims. I guess Ill just drop the coupe and call it a day.
Don't know if this will help, but the part numbers aren't the same for the shocks and it's questionable for the springs seeing as they share one number and not the other.
Here are the links: HONDA PARTS UNLIMITED... YOUR SOURCE FOR OEM HONDA AND ACURA PARTS AND ACCESSORIES!!! Acura Parts @ AcuraOEMparts.com - Genuine Acura OEM Parts from Delray Acura edit: Stabilizer bar has diff part numbers also rear suspension: 52550-SP0-A10 ARM B, R. RR. (LOWER) 1995 52550-SP0-A00 ARM B, R. RR. (LOWER) 1991 Prob more small suspension diff. I didn't think there was going to by much but looks like a sure but prob suttle diff. More reason for me to end up putting my powertrain in the 95' chasis when I'm able to. You learn something new everyday. Thanks Last edited by manxdr21 : 04-01-08 at 01:42 PM. |
#6 (permalink) | |
Welcome to my head
This is what I was talking about (I made the key points in case someone doesn't want to read the whole thing):
This is a major reason I believe in starting with a TYPE II chassis when buying a Coupe project; its simply more refined. |
Just looked up in the Acura archives:
The 95' uses 215/55R16 tires (20.66" total) and the 91' uses 205/60R15 tires (19.84") that's a diff of .82". If i'm not mistaken it's affecting ride height by only .41" The height of the car are: 95' 53.7" and 91' 53.5", the diff is .02" Also minimum ground clearance for the 91' 6.0" and 95' 4.5", the diff is 1.5" So if the 95' has a height which is .02" greater than the 91', but also has 1.5" less of ground clearance, and then the change in rims increases the ride height (technically) by .41". All this info leads me to believe that the 95' springs are somewhat lower. Anyone know anything about htis for sure? |
B anned (SIKE!!!)
Woah... Just when I was giving up, more people chime in. Thanks... I guess the "try it out year" for the coupe included a suspension upgrade.
Well I had posted on your thread previously and kept this in mind but just always have too much to do. I have both a 91' coupe(dd) and a95'coupe(not running right now), so the little diff always interests me. I think I will eventually put the 95' front springs on the 91' and leave the original rear springs on the 91', just want to see how it sits before I go and buy some lowering springs. I figured since the the 95' springs should be a bit lower that it would kinda help a bit with how high the front sits vs the rear. All this and I'm gonna eventually put everything I like/want about both cars back in the 95'. All the things we do for love. LOL
B anned (SIKE!!!)
My buddy just swapped out his on his 93 coupe. Ill see if I can acquire those from him for some dough.
#11 (permalink) | |
Btw I had recently removed a rear springs from both cars and noticed that the tension on the 95' was a bit more than on the 91'. Could be that the 91' spring has gone bad or could be that the 95' spring indeed is stiffer(have to remove both to inspect more carefully). Don't know about height though, didn't have anything to measure accurately |
the more tension thing.. sorry to jump in in the middle.. anyway. the higher tension on the later spring. while removing. maybe the strut itself is shorter as well.. i think we just need someone with a set of oem springs and struts from both options to actually just measure them ( off the car)
#13 (permalink) | |
