#31 (permalink) |
a question
Mellow Hi. I have a set of injectors from Superstreet4life's 93 partout, and was planning on sending them in to witch hunter today. While checking your ^ post, am I gonna have to also send with the injectors a set of o-rings? and then have a new set for when they get back? do i need to order 2 sets? I am expecting to see a big difference with the clean injectors. thank you for bringing this service to my attention.
#32 (permalink) |
I cleaned up the injectors the best I could and bubble wrapped each of them. One injector I put the o-rings back on. Three rings if I remember right.
Warning!! There's a 4th ring. It serves as a heat shield between the injector and the intake manifold - looks like a thick plastic washer. Be careful when you remove each injector as it may stick to the bottom. I had one fall into the engine compartment and was a bitch to find it. Clean this one and reuse. |
#34 (permalink) |
ditto
1995 Legend GS (sherwood Green) 144,000 My ride http://www.cardomain.com/memberpage/608014 |
#35 (permalink) |
Swollen Member
Did the swap last week. Car does run smoother but haven't seen a noticeable increase in MPG. Could be because the fucking oil companies have started putting ethanol in the gas which drops your mileage about 10%.
#36 (permalink) |
i will update
I sent in a set out of a 93 on monday the 7th, but sent them fedex ground (cheapest way they i think they could go with fedex) i've not heard from witch hunter yet but sure seems like it'll be a big difference. i cant wait. but i'm also gonna put in the walbro 255 and new fuel fillter all at the same time
#38 (permalink) | |
go on his web site and look they do alot
#39 (permalink) |
FRISCO LEGEND BABY!!!!
Yup, they use ultrasonic vibration to remove any dirt or residue that is in the injectors. I'm about to send mines soon since I got extra injectors from the junkyard.
\18" Limited 341 Chrome Rims/\Matador Red Paint/\Weapon R - Secret Weapon Intake/\LED Bright White Dash Lights/Floor/\Kenwood KDC-X590 Excelon Mp3 Deck/\Ford Taurus Coin/Cup Holder/\2 12" Kickers/\1200 Watt Sony XM-2200GTX 2-Channel Xplod Amp/\2 Rockford Fosgate Capacitors/\Power Acoustic Capacitor/\Clear Rear Turn Signal/\Reverse Glow Gauges/\Swapped 88' Headlights to 89'-90'/\JDM Rear Chrome Trim/\Stromung Muffler/ Soon To Come: Rebuild Motor and 5-MT Swap
#40 (permalink) |
Well Wisher
hey are all injectors the same from '91-'95?
edit: they are the same injectors from '86-'95 p/n 06164-P0A-000 schweet
'94 GS 6MT Exterior: JDM headlights & rain visors <> paint job <> retro '91-'93 OEM fogs & bumper <> 17" Konigs Performance: tuned Apexi SAFCII <> Sr5Guy chipped ECU <> Blackend engine damper <> MLS strut bar <> sr79labrat pulleys <> OBX headers <> Custom Y-pipe, Magnaflow Cat & Resonator, Stromung B-pipe & Muffler (All 2.5") <> TB Bypass <> RJ CAI w/ AEM bypass valve <> cross drilled/slotted rotors <> RJ short shifter <> ground wires Interior: Kenwood DDX6019 w/ NAV & Ipod, 2-tone leather Last edited by GrtOutdoorsAZ : 04-24-08 at 09:03 AM. |
#41 (permalink) |
Getting ready to put them in tomorrow. They seem super clean. I wish I took before pics, but they did not look ...new. here:
7.2 to 1.4 balance. I'm now wondering how the set I pull out will clean out to. oh and I also read on the invoice that "it is advised that all cleaned injectors are to be installed within 30 days of servicing to prevent sticking". I'm going to try to get out and get the gaskets that I will need to swap in the walbro too. |
#42 (permalink) |
They look good. New or not really doesn't matter as long as they're jetting/fogging nicely in sync.
Heck, you have all the seals - all set to install. Just make sure you oil the green and the black one on the bottom. There should be another plastic washer where the black seal sits on. It's a heat shield. Clean that and reuse. Good luck! |
#43 (permalink) |
not to steal the thread, but i saw on ebay this guy is selling fully clean injector for the acura legend. but he wants us to send back the old one. heres the link. has anyone tired them?
eBay Motors: ACURA LEGEND INTEGRA FUEL INJECTORS TESTED & CLEANED (item 380019755080 end time Apr-27-08 11:11:26 PDT)
#44 (permalink) | |
I emailed him he doesnt have any legend ones now
