Old 08-05-03, 03:13 PM   #1 (permalink)
Symply Legendary
Car 1: 1994 LS Coupe (Modded)
Oil in spark plug holes?
Yesterday I went to have my Zex nitrous kit installed. I also had the shop replace my plugs with the Zex plugs. When they were removing the old plugs some of the hole had some oil in them. It ranged from just a drop or two to a pretty noticable amount in cyl #6. They refused to hook up the switch for the nitrous until I have this looked out. Sounds like a bad valve cover gasket to me...
I have 155K on the motor, run Amsoil 5w30, and have already been through the headgasket ordeal. I'm thinking the thinner synthetic oil is just very gradually seeping past the seals and is pooling up in these holes. The motor IS NOT burning oil though. Is this something I really have to worry about? The amount was very small and had built up over about 1.5 years since the HG work was done. Do I tell them to just finish hooking up the Zex?
Thanks!
- Remus Exhaust
- DV8 Y-Pipe and Cat
- WR CAB and Ram Intake
- Bayou II Chip
- Ported and Polished Heads
- Zex Dry Nitrous Kit "60" Shot
- Grounding Kit (Smoked)
- Eibachs & Rear Konis
- MLS Strut Tower Bar
- Brembo Cross Drilled \ Slotted & EBC Greenstuff
- 18" RacingHart GT5
- 225\40\18 Yokohama Parada Spec II
- Two-Tone Leather (Black on Tan)
- Kenwood MP3
- Phoenix Gold 2500 & 4600 & X-Over
- .5 Ferad Cap
- MB Quart & Infinity Interiors
- Custom Tweeters In Domelight
- 2 JL 12W6's in Custom Box
LegendC is offline
Old 08-05-03, 05:21 PM   #2 (permalink)
Car 1: 1994 GS Sedan
It's not the valve cover gasket itself. There are these 6 round rubber gaskets that go between the hole in the valve cover, and the hole in the head (where the spark plug is). Those seals are probably bad. It's not an easy job to replace them though... as you have to take the valve cover off. One of my buddies civics had the same problem... those seals were bad, and almost all of his spark holes were submerged in oil.Hope this helped.
Asanga
94 Legend GS... 6-Spd
Bayou Stage II chip
Custom "hot" air intake
2.25" Mandrel bent downpipes
2.5" Cat-back exhaust
H&R/Koni Suspension
MLS Strut Bar
Lankan is offline
Old 08-05-03, 06:27 PM   #3 (permalink)
Symply Legendary
Thanks, thats exactly what I was thinking, those O rings in the valve covers. With as slow as this leak as been I am tempted to do noting about it, but check on it every 6 months or so. Thanks!
- Remus Exhaust
- Bayou II Chip
- Kenwood MP3
- .5 Ferad Cap
LegendC is offline
Old 08-05-03, 10:40 PM   #4 (permalink)
Car 1: 1991 Legend LS Coupe
I had the same problem with one of the spark plugs. I was replacing the spark plugs and found that no 1 plug was submereged in oil ... well that freaked me out. I tried to remove as much oil as I could. Well then I replaced the plugs, used fuel injector cleaner and then BG 44K. Its been 6 months now and I just checked my sparkplugs last week and they are all dry.
I think having too much oil in the engine may contribute to that problem.
samtaher is offline
Old 08-05-03, 11:23 PM   #5 (permalink)
Car 1: '92 LS sedan
If this were to be my case, i would go ahead and get the plugs seals change out before hooking up to nitrous. The reason is the oil going to get on the top of them plugs and might cause a misfire to acour. I believe that when injecting nitrous, a misfire might lead to some major issue.
DrEemAr gUy is offline
Old 08-06-03, 03:23 AM   #6 (permalink)
Steveman09's Avatar
Car 1: 94 Legend LS Coupe Type-II
Car 2: 87 Subaru GL10 Turbo
Car 3: 91 Eagle Talon TSI
Send a message via AIM to Steveman09
If the Electrode of the Spark plug has oil on it then your Piston Rings are bad.
If the top of the plugs (where the wire connects) has oil then replace the O-Rings he talked about.
Dont run Nitrous with Oily plug electrodes as this is called a "Fouled Spark Plug" This will lead the misfires and under Nitrous will lead to Detonation and Engine Damage/Failure.
Not to mention if your Piston Rings are leaking oil it will get MUCH worse after you spray some ZEX a few times.
Steveman09 is offline
Old 08-06-03, 11:41 AM   #7 (permalink)
Car 1: 93 acura legend 6spd blk on blk coupe
Send a message via AIM to cbr900bikes
right on point steveman09
cbr900bikes is offline
Old 11-28-05, 05:55 PM   #8 (permalink)
Car 1: 91 Legend
Has anyone changed the O rings? How difficult is it? Is there any special tools needed?
414Toyz is offline
Old 11-28-05, 06:00 PM   #9 (permalink)
Looking for Blk/Bk GS6MT
mondonalds's Avatar
Car 1: 1999 TL - Blk/Blk
Send a message via AIM to mondonalds
I have done it on both sides. Its not too difficult, just takes some time. As for tools, if i remember right, you will need 8mm, 10mm, 12mm sockets with a ratcheting wrench. I have them for both 1/4 and 3/8" drive ratchets and found in some places it was easier with one of the two sizes. Also, make sure to get some silicone gasket sealer. The hardest part is just getting all the various things out of the way of the valve cover so you can pull it off. Just post here if you have more questions and I will try and answer.
1999 3.2TL - Black w/ Type A (01-07 - ____)
1996 Toyota 4Runner Limited (05-06 - _____)
1993 LS Sedan - Geneva Green Pearl w/ Type F (11/04 - 07/06)
mondonalds is offline
Old 11-28-05, 06:04 PM   #10 (permalink)
Factory Freak!
92drls's Avatar
Car 1: JDM KA8 5sp
Car 2: Lincoln LS8 RIP
Just take an hour or two depending on experience. Couple different size wrenches and random common tools and you should be set.
92drls is offline
Old 11-28-05, 06:05 PM   #11 (permalink)
Car 1: 91 Legend
Thanks ill keep yall posted
So whats the worst that could happen if there not changed? Besides loosing oil.
414Toyz is offline
Old 11-28-05, 07:51 PM   #12 (permalink)
mondonalds's Avatar
To my knowledge, your spark plugs will get "oil-fouled"
When you do this, replace all spark plug orings AND your valve cover gasket. I did mine not too long ago. I dont think it has been done on my car, so the gaskets and orings were probably from 93. They were brittle.
This is a relatively cheap and easy fix.
