I was changing the spark plugs today and noticed that #s 3 and 5 have oil on the ceramic insluation. I am assuming leaking spark plug seals!? Are these pretty straightforward to replace as on other Hondas or are there any tricks on the Legend i need to know before i tare down the valve cover?
Also do you guys have to remove the strutbar to change the two plugs closest to the firewall? It seems like you wouldn't have to but i cannot get the coils to clear. N. |
i dunno wat causes the oil to be on the spark plug, i have the same problem on my 90 ls cpe. i was changed plugs every few months untill i started using valvoline max life products into the cpe and noticed that there wasnt oil on the plugs anymore. i guessed in my case that the seals or gaskets was pretty warn.
for the strutbar question. yes we all have to unbolt the bar and push it out of the way to pull out the coil pack. well as far as i know with my 91 cpe and my bro 94GS |
#4 (permalink) | |
It sounds like you have leaking valve seals, allowing oil to seep into your combustion chamber when it has been sitting for awhile~ you will have oil on the plugs. Do you have smoke coming out your exhaust when you first start the car? Does your car use alot of oil?
99 Mitsubishi 3000GT VR4... 1 of 263 produced TT/AWD/6 spd/ 5Zigen FN01RC, roller bearing SS, Passport SR1, HIDs, LEDs, custom berber mats, Alpine IVA-D300, MP3 changer, 2000 watts custom plexi & neon Alpine rack /2x Brahma 10's, Seas Lotus, SQL setup, 20% F1 Tint, Tein Flex, Maximal Adj C arms, Greddy BOV, 3SX poly mounts, Carbotech/Hawk/SS lines, DR-650 turbos, next... 19x10 RH J5 Pro |
#5 (permalink) | |
yup its the seals just get new ones and at the same time change your valve cover gasket Easy thing to do it takes me maybe and 40 min per cover
http://home.comcast.net/~nosferatu2xlc/94LS.jpg Sarasota FL 91 Gold Sedan L sold 94 Green Sedan LS sold 94 Milano Red Coupe LS sold WTB G2 6spd LS coupe |
Type I King
why woudl it not be the rings that are causing this? why is everyone thinking its the valve seal? also dont the spark plugs have "pockets" (this is what the dealer told me) which might have a leak and thus are causing oil ont he plugs?
#8 (permalink) | ||
EDM Honda Legend
Outside: If the oil on the removed spark plug was on the outside top of the plug, you probably have a leaky valve cover gasket. If your car has not been tuned up recently, you may be ready for a major tune-up and compression check Inside: It would appear from what you described that the rings and/or valve stem seals have failed in the cylinder with the spark plug that was covered in oil. Quote:
BTW: Here a link with useful info... [Spark Plug Diagnosis] Good luck! -Mike |
#9 (permalink) | |
The oil is on the top of his plugs, and it leaks into the "well" that the plugs sit in in the valve cover.
92 LS Coupe 83,000 Miles & Counting Stock except -GS RIMS -Clear Bumpers |
FIXER
Car 1: 1992 Legend L 265k Black(sold) 1994 Legend LS 175K Green 1967 NOVA SS Bolero Red iTrader: (0)
Autozone sells a Felpro gasket set that includes the valve cover gasket and spark plug tube seals. p/n VS50448R. $35.99. I used this set to correct the same problem.
#12 (permalink) | |
| Oil in spark plug holes? | LegendC | Second Generation Legend (1991-1995) | 11 | 11-28-05 06:51 PM |
| Oil change for both sexes | 1truluv | First Generation Legend (1986-1990) | 25 | 05-28-04 08:03 AM |
| Denso Iridium spark plugs? | akuma | Second Generation Legend (1991-1995) | 5 | 04-30-03 01:48 AM |
| ...found some oil on my spark plug | K3RRY | Second Generation Legend (1991-1995) | 8 | 02-24-03 12:18 PM |
| Oil Pressure drop big time | flashdragoon | First Generation Legend (1986-1990) | 7 | 05-11-02 01:38 PM |
