hi....
Optilux bulbs....
this is what i found from wikipedia...
Q: What bulbs are used in my car? A: This is a list of bulb types used in a 1994 legend LS model sedan. All G2 sedans should be the same, with only minor differences for a coupe. External: Low-beams: 9006 (HB4), 51W (x2) High-beams: 9005 (HB3), 60W (x2) Now i just bought the optilux 9006 hb4, 80w for my low beams.. will that be a problem cuz it says our stock ones are 51w... will it burn out the housing or something or am i good to install em? |
#3 (permalink) | |
1994 Acura Legend LS My Progress Thread Done: WeaponR Secret Weapon with K&N inverted cone filter, JDM headlights, inverted dash warning lights, mesh grille, RaceConcepts rotors, ceramic pads, Bondo'd rust(!), Pioneer DEH5800MP, JL Audio e1800D, 10" TC Sounds TC-1000 in custom birch box, MLS-copy front strut bar, Stromung cat-back. In Progress: OEM headgaskets. Soon: Looking for a mint GS to replace my LS for future plans. |
#4 (permalink) | |
Sherwood GS
OP...are these Hella optilux bulbs? If so I know they make them in both 55W and 80W versions. If you have a true 80W bulb (as opposed to a 55W which says it has 80W 'output') then you must upgrade yur wiring harness/connectors. The 80W will draw a lot of current and you may melt your wiring harness and connectors!!! So make sure you upgrade your wiring harness and for extra safety keep the OEM fuse. It will probably not be a problem till you start using the 80W bulbs on warm summer nights, te harnes will get very hot. First make sure your bulbs are actually 80W and not 80W 'output'. I had 80W bulbs in my old Audi's high beams (and HID for low beams) and used this info to do the wiring upgrade, not sure how easily it would translate for the Legend.
AudiWorld Forums: High beam headlight wiring upgrade info and write up. Graphics rich.
#7 (permalink) | |
hi....
Sherwood GS
Yea those actually draw 80W, and will eventually heat your harness to melting point. Unless you're familiar with the physics of electricity the difference between volts and watts can be tricky. Simple explanation:
Watts = Amps x Volts x Length (of wiring harness) Since these are 80W and the volts (12V) and the length/gauge of your (stock) harness is the same this means these bulbs will be drawing more power (amps) through the harness and this will cause a lot of heat to be generated through the harness. For now I would switch the 55W bulbs back in till you figure out how to upgrade the harness.
#9 (permalink) | |
hi....
#11 (permalink) | |
hi....
![]() nice price too.. installed already but its still day so i cant take pics yet... ill take some pics of the ballasts locations too... 10000k... if anyone interested i can get you guys some too... we'll figure out a price if theres enough interest... |
