Old 03-26-08, 04:57 PM   #1 (permalink)
hi....
chinoxl37's Avatar
Car 1: 1993 Acura Legend Sedan
Car 2: Nissan Sentra 1993
Car 3: 2002 Eclipse
Optilux bulbs....
this is what i found from wikipedia...
Q: What bulbs are used in my car?
A: This is a list of bulb types used in a 1994 legend LS model sedan. All G2 sedans should be the same, with only minor differences for a coupe.
External:
Low-beams: 9006 (HB4), 51W (x2)
High-beams: 9005 (HB3), 60W (x2)
Now i just bought the optilux 9006 hb4, 80w for my low beams.. will that be a problem cuz it says our stock ones are 51w... will it burn out the housing or something or am i good to install em?
chinoxl37 is offline
Old 03-26-08, 09:56 PM   #2 (permalink)
hi....
chinoxl37's Avatar
Car 3: 2002 Eclipse
well i installed em anyway.. hopefullly it wont do no damage...
Photobucket
Photobucket
now question is... what kinda bulb can i use for my corner light so that they do not appear yellowish? i hate that yellowish color.. kinda negates my clear corner lights i bought... i have clear bulbs in it but its still yellow tinged
Old 03-26-08, 10:04 PM   #3 (permalink)
Quaraxkad's Avatar
Car 1: '94 Legend LS sedan, 202k
Car 2: '92 Cutlass Supreme
External:
The bulbs you bought probably are 51W. Manufacturers like to put a fake "output wattage" number on the bulbs to make you think they're that much brighter than your stocks. That's probably the number you are looking at. There are still bulbs that use higher wattage, I don't know if Optilux is one of them though.
1994 Acura Legend LS
My Progress Thread
Done: WeaponR Secret Weapon with K&N inverted cone filter, JDM headlights, inverted dash warning lights, mesh grille, RaceConcepts rotors, ceramic pads, Bondo'd rust(!), Pioneer DEH5800MP, JL Audio e1800D, 10" TC Sounds TC-1000 in custom birch box, MLS-copy front strut bar.
Soon: Stromung cat-back.
Future: Looking for a mint GS to replace my LS for future mods.
Quaraxkad is offline
Old 03-26-08, 10:10 PM   #4 (permalink)
Quaraxkad's Avatar
If you have a clear lens and a regular bulb in there, it's still going to look yellow. If you want them to be white, you need either LEDs or a quality blue-tinted halogen bulb. The blue tint filters out the yellow and leaves only white light. There are two of these in the corners on each side (1 per side in JDMs): Autodynamic.com
My Progress Thread
Old 03-26-08, 10:59 PM   #5 (permalink)
Sherwood GS
samblaze's Avatar
OP...are these Hella optilux bulbs? If so I know they make them in both 55W and 80W versions. If you have a true 80W bulb (as opposed to a 55W which says it has 80W 'output') then you must upgrade yur wiring harness/connectors. The 80W will draw a lot of current and you may melt your wiring harness and connectors!!! So make sure you upgrade your wiring harness and for extra safety keep the OEM fuse. It will probably not be a problem till you start using the 80W bulbs on warm summer nights, te harnes will get very hot. First make sure your bulbs are actually 80W and not 80W 'output'. I had 80W bulbs in my old Audi's high beams (and HID for low beams) and used this info to do the wiring upgrade, not sure how easily it would translate for the Legend.
AudiWorld Forums: High beam headlight wiring upgrade info and write up. Graphics rich.
86 Saab 900S Coupe 5MT
94 Acura Legend GS 6MT
04 Subaru Forester XS A/T
samblaze is offline
Old 03-26-08, 11:49 PM   #6 (permalink)
hi....
chinoxl37's Avatar
Car 3: 2002 Eclipse
does anyone know a DIY for upgrading our wireing harness? the audi one seems real difficult... thanks
Old 03-26-08, 11:59 PM   #7 (permalink)
hi....
chinoxl37's Avatar
Car 3: 2002 Eclipse
Originally Posted by samblaze View Post
OP...are these Hella optilux bulbs? First make sure your bulbs are actually 80W and not 80W 'output'. I had 80W bulbs in my old Audi's high beams (and HID for low beams) and used this info to do the wiring upgrade, not sure how easily it would translate for the Legend.
Hella Optilux XB 9006 Xenon Bulbs these are the exact ones i got.... but the thing is is it the wattage that burns the harness or the voltage... cuz its still 12v...
Old 03-27-08, 12:29 AM   #8 (permalink)
Sherwood GS
samblaze's Avatar
Yea those actually draw 80W, and will eventually heat your harness to melting point. Unless you're familiar with the physics of electricity the difference between volts and watts can be tricky. Simple explanation:
Watts = Amps x Volts x Length (of wiring harness)
Since these are 80W and the volts (12V) and the length/gauge of your (stock) harness is the same this means these bulbs will be drawing more power (amps) through the harness and this will cause a lot of heat to be generated through the harness. For now I would switch the 55W bulbs back in till you figure out how to upgrade the harness.
samblaze is offline
Old 03-27-08, 12:32 AM   #9 (permalink)
hi....
chinoxl37's Avatar
Car 3: 2002 Eclipse
thanks for your quick response... i found a harness Autodynamic.com but question is... how hard is it to install cuz when i was installing the bulbs theres really not that much room in there to play with.. and another thing im thinkin now is should i just say F it and get an hid kit
Old 03-27-08, 01:30 AM   #10 (permalink)
Sherwood GS
samblaze's Avatar
I would go HID personally. But that is the correct harness upgrade.
samblaze is offline
Old 03-29-08, 07:07 PM   #11 (permalink)
hi....
chinoxl37's Avatar
Car 3: 2002 Eclipse
well i got the harness today and was gonna install it but it was way too messy and too many wires... drove 10 min to my spot and picked these up.
nice price too.. installed already but its still day so i cant take pics yet... ill take some pics of the ballasts locations too... 10000k... if anyone interested i can get you guys some too... we'll figure out a price if theres enough interest...
Old 03-30-08, 01:49 AM   #12 (permalink)
Old School's Avatar
Car 1: 1995 Acura Legend Ls coupe type II
Car 2: 1988 Acura Legend co
Car 3: 1998 Volvo v70 AWD
Post some PIC's, I may be interested... How much did it cost you?
Old School is offline
Old 03-30-08, 06:05 AM   #13 (permalink)
hi....
chinoxl37's Avatar
Car 3: 2002 Eclipse
optilux.....
HID 10000k
and
