overflow back up
running out of options on what the hell is going on with my car. everyday i have to pour the coolant from the overflow back into the radiator. i just put a new radiator in it about 2 months ago,i have no leaks,my thermostat is opening at the right temp. Any suggestions?
Im in the same boat my 93 is doing the exact same thing and Im starting to think its a head gasket.....
I have bled the hell out the system the rad is new the t-stat is new NO oil in coolant, no coolant in oil My car does have white smoke the odd time so id guess it could be your head gasket |
My bet is the BHG. Although I think it is more in the seeping head gasket stage right now. Mine started out the same way. When I first got it the car was only using up maybe a half a pint of coolant a day. 8000 miles later it was using the better part of a gallon a day. I never saw oil in the coolant, never saw coolant in the oil, and the heater worked fine. The only clue was the coolant loss and overflow. Look at it this way. If you have pressure tested the system and it still pushes coolant out even after bleeding the hell out of it then overpressure has to be coming from somewhere right? If the system is tight the only place left is through the headgasket. Have you done a hydrocarbon test on the radiator yet? That should be your next step IMO
Regards |
Welcome to my head
You guys could spend $40 on a hydrocarbon test or you could just take my word that it's a seeping head gasket. Overflow not being sucked back up and no leaks is a classic sign of a seeping head gasket.
seeping/blown head gasket. damn...makes me sad. all i can say is stop driving now while its not too bad, get it fixed when u get the money, and only use OEM gaskets!!! mine was doing the same thing even after the new radiator was in and all of that... blah, blah, blah. good luck.
WHAAAAAH!
How many miles? If it's over 150k, I'm going to bet you have a blown head gasket. I don't know who to send you to in Washington to have them done. It's probably going to cost you about $1500+. I do them for $1200-$1300.
Do you know the service history of the car?
From my cold dead hands!
Car 1: 91 LS Black window trim EDM/Hids Remus 2 1/2 cat back Headers stage 3 ecu Car 2: ,Red tails, Type 2 Car 3: 6 speed, EDM spoiler iTrader: (35)
I'm just gonna offer up this tidbit:
Is your 91-95 Legend overheating? Got a coolant problem? Post all questions in here.
300,000miles and climbing!
it`s definitely not sucking it back out when cooled off. i really just need to to get the hydro test and go from there. it has 190k,so in all reality,BHG....dammit.
thanks Mike Diaz, i`ll probably end up taking it to Gregs Japenese( a pretty good shop around here),gonna cost me an arm and a leg,but i love my car so i`ll pay it. |
WHAAAAAH!
Unfortunately, at 190k, you can't expect anything better out of an engine. Most other cars would have bit the dust long before that. As long as the rest of the car is worth it, spend the money and get her fixed.
| Getting Legend Back | 89HondaLegend | First Generation Legend (1986-1990) | 1 | 02-11-05 01:14 AM |
| back to my last page - Merged | SLICK40 | Feature Requests | 12 | 01-26-05 08:24 PM |
| Should I get my gs back? | 94AcuraLegendGSAuto | Engine & Performance Modifications | 13 | 12-14-04 03:22 PM |
| WTB:the wire clip for the back of my pioneer radio,deh-48 super tuner III | PETEROCK29 | Aftermarket Parts | 0 | 10-02-04 05:19 AM |
| The car is back and like new. | RenoG | Second Generation Legend (1991-1995) | 2 | 07-11-02 10:17 AM |
