#16 (permalink) |
Jetdoc's writeup should be a must read for all new Legend owners.
I think the key thing is to recognize the symptoms of a cooling system problem, and then to fis it *right away*. If you read this writeup, see the symptoms, and ignore them, you deserve an expensive repair!
92 LS Coupe 83,000 Miles & Counting Stock except -GS RIMS -Clear Bumpers |
#17 (permalink) | |
#18 (permalink) |
I dont know if these are the same symptons as a bhg, but i hope not. My heat gauge will go up to hot, but either go down by itself when i turn the heat on, or drop when i get over 3k rpms it seems. The heat will come on but it take a long time to warm up.
Any ideas what this may be thats causing the heat gauge to flux as well as my heat to take a very long time to heat up, usually like 20-25 minutes i think. Thanks |
#19 (permalink) |
FIXER
Car 1: 1992 Legend L 265k Black(sold) 1994 Legend LS 175K Green 1967 NOVA SS Bolero Red iTrader: (0)
Start by making sure the coolant is full at the radiator. (when it's cool of course)
People are often reluctant to pay for good advice but rarely follow free advice. |
#20 (permalink) | |
. http://www.914club.com/bbs2/uploads/acura-sig.jpg 04 Chevy Malibu Maxx - Wife Wagon 02 18' car hauler dual axle, brakes, diamond plate steel deck - For sale after I haul the 914/6 tub home from S.L. 93 White Legend L sedan, 5spd. - New DD Ride 88 Jeep Cherokee - Going to ASU next fall with my stepson and all my money 72 Chevy C10 Cheyenne - Parts runner 70 Porsche 914/6 - Tub stripped, rust repaired, paint almost finished 67 Chevy C20 - Rust Free! For sale |
#22 (permalink) | |
I put a new radiator in it last weekend and it's no longer losing coolant and running great.
#23 (permalink) |
I recently purchased a 1992 acura legend with a small amnount of smoke comming from the tailpipe. Well i figured it was no big deal, but now huge clouds come out and it is barely drivable, This BHG problem is very dissapointing. My car only lasted me 5,000 miles and now it will cost more than the price of the car to get it repaired. Well im gogin to fix it because the Legend is an awesome car, good luck too all the other Legend drivers out there! :p
Legend .. what!
#25 (permalink) |
great write up .
i must say im in the sec scenario. lots of air getting in to system and cooland getting pumped back to bottle. no smoke ,no leaks. it started overheating 2 times but i pulled over. since than i bleed air about twice a week by opening the bleeder bolt after coming home fron work. all the air get out ( aprox. 3 to 5 sec. of air comes out.) im preatty sure it HG, i got new pump hoses , termo radiator. it stated acurring since this winnter. also a interesting observatino i discovered. with car running rad. cup off and bleed bolt off with full cooland in ssytem there is no bobles coming and cooland stay level in radiator. as soon i turn heat on ,the cooland starts dripping from radiator like is geting pushed out from inside. when running heat my car proly will overheat in maters of 2 days , with no heat i till take aprx 2 to 3 weeks to overheat. tha'ts makes me thing was up with that . im planing to bypass the heater core and see what will be the resolts.
http://home.comcast.net/~nosferatu2xlc/94LS.jpg Sarasota FL 91 Gold Sedan L sold 94 Green Sedan LS sold 94 Milano Red Coupe LS sold WTB G2 6spd LS coupe |
#27 (permalink) |
after having the problems which are typical for having air in the cooling system, I filled it up today. The problems haven't accured again so far.
How serious is the fact that my engine got overheated a few times in the last days? Because I've read that the HG will definitely brake some day if the engine overheats once. |
#28 (permalink) |
FIXER
With these Legends you just don't know. But it is not "if" but "when" is the HG going to fail. Maybe you got lucky.
#29 (permalink) |
Hi, I am not an expert. My 91 coupe had temp problems that cascaded into: radiator.
hoses, thermostat, flush, refill with Honda fluids. etc. My personal belief is that I have a leaking head gasket; I manage it at unreasonalble levels by checking the coolant level, bleeding the system, monitoring the overflow/expansin tank. I have been doing this for 160,000 miles. It started at 90,000 miles. The dealer and the radiator people still say it might be just cooling, not head gasket. Right. What about the light blue smoke. Bottomline: I used the CRC "pass any emission test" stuff, I check my fluids about three times a week. Winter is worse (no heat.) I use Acura type 2 AF if I can get it. Finally, I purchased another 5 speed coupe with no symptoms and am committed to maintenance as a preventive. I still want a head gasket job or a JDM type ll for the original coupe. Two to four thousand dollars will not buy a comparable car these days. But, how many years can you drive a 14-15 year old car? That is the bottom line: cost benefit trade-off. The diagnosis becomes clearer when one checks the wallet. If you are in doubt about the BHG, a test is available from NAPA for about $50.00. I think the test is called Chemical blue; it identifies hydrocarbons at the radiator. a place they should not be. Your choices remain: deal with it, repair it, sell/trade it. When in doubt, get tested. Remember, my heater was cold at 90,000; I have about 240,000 miles at present. The car will die long after your patiance wears thin. It can be a real hassle in the interim; especially if family and friends are second quessing you. Try the NAPA test materials if you are in a quandry. Cooling system problems may initiate the "syndome" but I think that ongoing problems are BHG that then appear as possible cooling system problems. The "air" is coming from Cyl 3 and 6. The coolant in the expansion tank was pushed out by the air from 3&6. Fiddling with the Fluids is like taking aspirin for an appendicitis; symptom relief, not problem solving. Hey; meanwhile, enjoy the ride for a few more years. |
#30 (permalink) | |
| Is your 91-95 Legend overheating? Got a coolant problem? Post all questions in here. | Mike Diaz | Second Generation Legend (1991-1995) | 1940 | Today 06:45 PM |
| colder cities = more overheating ?? | ka8legend | Second Generation Legend (1991-1995) | 0 | 01-20-04 01:47 PM |
| (Another) Overheating Problem- HELP! | HotHonda | Second Generation Legend (1991-1995) | 9 | 04-29-03 09:30 PM |
| Overheating | larryk | Second Generation Legend (1991-1995) | 14 | 04-23-03 08:59 PM |
| Overheating probelm UPDATE | Darkstar | Second Generation Legend (1991-1995) | 3 | 09-23-02 12:44 AM |
