#31 (permalink) | |
#32 (permalink) |
Overheating....once
Hey guys,
I just got a 95 Legend LS about a week ago. And today it started overheating. I have read most of the forum a lot of people have had this problem. Cold Air from the heat, and engine spiking. When i pressed the brakes, the heat went back down. That happened just this morning, and i drove around all day 2day. It did not happen any other time, just morning. Could it be a temporary problem? Looks like a "Large amount of air in cooling system" problem looking at JetDoc's post in this forum. But y did it happen jus once |
#33 (permalink) |
Hi! I'm Ryan.
If it happens once it will almost always happen again. Sounds like the beginning of a problem. Check your fluid level. If the anti-freeze isn't at the very top of the filler neck where the rubber seal of the filler cap presses on the rim, you are too low.
If its all the way to the top and there is no air in the system you may need a new thermostat. You have to diagnose it now before your potentially minor problem turns into an engine rebuild. |
#34 (permalink) |
FIXER
Car 1: 1992 Legend L 265k Black(sold) 1994 Legend LS 175K Green 1967 NOVA SS Bolero Red iTrader: (0)
Have you checked the coolant level at the radiator?
People are often reluctant to pay for good advice but rarely follow free advice. |
#35 (permalink) |
I tried to bleed the system but a steady stream of anti freeze never flowed out of bleeder. I took thermostat out cleaned it hen replaced it but erratic idle is still there . Im new to this site and to owning a legend so all help would be appreciated.
#36 (permalink) |
Location: On the left side of ya mom's inner thigh. Its warm here too!!
I'm thinking new radiator. the same happened to me.
1Dre Linn's Ramblings Parapaligic Walking 2Dre Linn Rambling. Who's First Da Champ!! Mr. 55:961 Coupes need to
#39 (permalink) |
i wish we had like an Ac forum rep in every state cuz im in NJ and i am a newb when it comes to cars period. What would you suggest JETDOC a complete and utter newb should do as i own a 95 Acura Legend GS and i dont know what to do, pretty much every symptom you wrote about has occured, and i was told to switch my thermostat so i did that and the mechanic says "Hey you never had a thermostat in there" i dont even know what that means, like is that possible if so why. I am so depressed right now, and i wish someone knowledgable on here lived in Jersey so i could bring my car to them.
#40 (permalink) |
FIXER
Sorry to say, somebody sold you a Legend with a BHG, and they new it. They removed the thermostat to hide the symptoms. The bhg got worse and now it can't be hidden. If it's too late to return the vehicle then all you can do is replace the headgaskets or replace the engine
#42 (permalink) |
im in newark, nj
oh and jetdoc thanks for the info yea its too late i had her since last spring and she was working beautifully but she always had a smoke problem never a temp problem, whats the science behind removing the thermostat, i hear ppl do that in the summer but not in the winter (remember im a total newb to cars period) |
#43 (permalink) |
BHG Motorsports
Shouldn't think have stickied by now?
.:JDM/EDM Non-Navi DIY:. .:JDM Navi Console DIY:. .:Cluster/Speedo Replacement DIY:. I think OEM is the best look. I just don't happen to think any of the various arrangements of OEM got it exactly right all at once ![]() |
#44 (permalink) |
well mi car startd over heating i dint know how or why .. so i cheked it out with a mac. and he bleed out the system and toke all the air out then the fans started to worrk and evrything . but b4 all that he sead its the thermostat so wen i went to go buy it he put it on then the car started to heat up fast and there was colant seeping truw the crack were the thermo gos in .. so he toke it out and told me run it like the till winter its okay .. but i dont want to run it like that can n-e one help me .. wat can it be !
#45 (permalink) |
overheating problem
hi, i know its not a legend or rl but i couldnt find much other info on overheating on my perticular model, the systems are simmilar enough i hope? I was driving when i noticed that the heat was damn near the red. so i pulled over waited a while then kept driving. stop and go till i got to a store, picked up some antifreeze premix stuff, opend the rad *it has a new cap and poured half the thing in there. then noticed that the other reservior thing was full with hot antifreeze. poured some out. the temperature went right down, and stayed there. so after it cooled down i poured more antifreeze in the rad, and had to empty some again from the reservior thingy. i repeat this proces every other day. so now the temperature goes up, maybe about 3/4 or a bit higher then drops down, even a little bit below normal temperature. so i guess i have some air in the system then, need to bleed... but why is it that that reservior thingy is gettin full but not empty, my exhaust seems ok, the antifreeze is a normal color, had some issues with the heat in the car from time to time but works fine lately. my worry is that its the headgasket, i just bought the car 4 months ago, took it to a mechanic before and it was in great shape. He spent 2 hours looking at it and found only a bit of oil in between the tranny and engine but said that it wanst a major deal and some people drive with that for years and years... so its a v6 3.2 and i have about 210k on it. any ideas? thanks
| Is your 91-95 Legend overheating? Got a coolant problem? Post all questions in here. | Mike Diaz | Second Generation Legend (1991-1995) | 1957 | 10-06-08 04:49 AM |
| colder cities = more overheating ?? | ka8legend | Second Generation Legend (1991-1995) | 0 | 01-20-04 01:47 PM |
| (Another) Overheating Problem- HELP! | HotHonda | Second Generation Legend (1991-1995) | 9 | 04-29-03 09:30 PM |
| Overheating | larryk | Second Generation Legend (1991-1995) | 14 | 04-23-03 08:59 PM |
| Overheating probelm UPDATE | Darkstar | Second Generation Legend (1991-1995) | 3 | 09-23-02 12:44 AM |
