Paint experts i need your help
ok here is the deal.
i order paint from paintscrath. and i got clear also from them . i prep my bumper , prime it. Paint with a base coat. the match is clouse to 100% . Let it dry for over 30 hours. now here is a problem, i mix clear with paint thiner about 1:1. after sprying the clear , the paint got darker and you can tell a diffirance now. is there anything to prewent from making the paint darker . will using more paint thinner wiht a basecoat make my paint lighter ?
http://home.comcast.net/~nosferatu2xlc/94LS.jpg Sarasota FL 91 Gold Sedan L sold 94 Green Sedan LS sold 94 Milano Red Coupe LS sold WTB G2 6spd LS coupe |
isn't the clear sprayed last?
http://www.safetygears.net |
you have to thin the base and clear. yes i apply the clear last.
Car 1: 95 Legend GS (Main Baby in Garage) & 94 LS Cpe 6 Speed (Main Driver & Fun) Car 2: 93 Legend LS 2dr 6sp iTrader: (2)
You haven't got the paint experts to reply yet?
I know that the more you thin, the less you put on at a time. You might want to look into tinting the clear so that you get a lighter color. If you also thin it down more and put less on, you might get the color you want with multiple coats and it will not get too thick.
I'm the one with the Limited Slip Differentials (LSD). We can build what you need!Users of LSDs: Newest Customer - sr79labrat Third - Me!! Second Customer - Kenso First Customer - LEgEnD4LiFe 95 Legend GS w/Koni shocks, all else stock 94 Legend LS Cpe 6-Speed w/Konis, Race Brakes, braided lines, AND the 3rd LSD built by us but the first to be installed!!!!! *New* - 86 CRX w/D16A Conversion Now with TURBO!! |
thanx i try putting light clear coat let it dry and than put wet coat on top of that
Are you going to restart with new base paint?
If not, sand the clear down to the base with 1500 and then 2000 grit sandpaper. Then reshoot with thinner clear. I would strip and start over, but I am not a professional.
will sanding the clear make it lighter ?
It should.
thickness vs layering
Cut that thickness down and you should get clearer. The thing is, the clearcoat may be a dark clear and not help the more you layer. Make sure you compare the color as you go.
I am unfamiliar with the paintscratch product. As a rule, a clear will darken the paint. You are never going to achieve a perfect match with a spraybomb. Too many variables: paint mix, clear mix, age of old paint, pressure, and particular paint formula. You also do not want to overreduce the clear.
| Painting Back Lights | NDEMAND | Second Generation Legend (1991-1995) | 34 | 07-20-06 04:41 AM |
| Body repair - Paint questions! | lorenzo | Second Generation Legend (1991-1995) | 3 | 11-27-05 10:51 AM |
| Help! Insurance Claim, Paint Problems... | FutureX 2001 | Second Generation Legend (1991-1995) | 6 | 06-16-04 04:34 PM |
| Paint specs... | Second Generation Legend (1991-1995) | 2 | 04-03-03 07:07 AM | |
| Paint your windshield wipern arm. | mocca | Second Generation Legend (1991-1995) | 6 | 09-23-02 12:33 AM |
