Legend Lover
I have searched well and cannot find a diy on painting your taillights from the INSIDE. I just picked up 2 cans of testors candy red paint and have a spare set of taillights on hand. If im going to do this mod, im gonna do it right. Ha anyone pulled their tails apart and painted from the inside?????
94' Desert Mist Legend LS coupe 86,000mi and counting....... "Life moves pretty fast. If you don't stop and look around once in a while........you could miss it!" Ferris Buller |
Dont Catch
thats how i did my tailights the 2nd time around.
took off the tailights and stuff. baked them in the oven for 5 mins and pry'ed the lenses up slowly and re-heating it again in the oven for a couple more mins until it came off. then i used some painters tape to tape off the amber section. and i did light coats of the testors. i let it dry and put back the lenses onto the tailights. one thing you have to be careful is not to put too much pressure on the lenses when its hot... otherwise you may cause it to bend. |
#3 (permalink) | |
Legend Lover
Dont Catch
200-250 max
to put it together i just lined up the lenses and put it back in the oven. once the adhesive was gooey i pushed the lenses back into place. and like i said definitely dont push on the center of the tailights... (the turn signal part or else its going to bend) and you could use clear silicone... a thin layer on the seams where the lens meets the housings. |
Legend Lover
It's working!!!!!!!! How bout the paint process? any tips???
Legend Lover
Did you have to pull out the reverse clear plastic to paint the amber ? paint just the amber not the red right??
#8 (permalink) | |
Outta GT
Location: California/Central Valley (Blk/Blk L Sedan & Blk/Ivory GS)
Follow bl420 painting tips. Please save yourself some grief, do not attempt pulling out the clear reverse lenses. ![]()
RespEct A Legend Legendary styling lives on forever!!! http://i279.photobucket.com/albums/k...ndathome-1.jpg |
Legend Lover
I have a paint and body guy that says i should paint the entire lens, not the reverse, red then profesinaly clear coat the whole lense outside, including the reverse. says he can make it shine like OEM. what ya think, inside VS. pro outside?
#10 (permalink) | |
VIRGIN
Waste of monies! Don't even bother putting a clear coat on the outside. You aren't even applying paint to it--why bother to try and make it even more shiny? I'm sure they look fine as it is anyway. Are they especially dull for some reason? |
Thuggin' it since 1996!
any pix of the completed process (painting from the inside)
~Heath~ 95 Taffeta White Acura Legend L Sedan (130k) 95 Sherwood Green Legend LS Coupe (89k) "And on the 8th day, G-d created the Legend" "This ain't negotiation time. This is Scarface, final scene, fuckin' bazookas under each arm." -Christopher Moltisanti |
OP, wouldn't you mind using the easier simplier red vinyl film instead of going though all of these hard work painting process? The red vinyl film stayed very well on the clean lenses after it dried out, I had it on my tail lights for over 6 months now w/o any peelings at all.
#13 (permalink) | |
Legend Lover
