Where do I shim?
Hi all I've just lowered my ride and I need to correct the REAR camber. I've read several members(ChrisK, and a few others) about using washers and longer bolts but they never mentioned which part of the rear suspension member that needs it. Does anyone have any pictures/diagrams to assist me in this install? TIA
-Jim Last edited by 大LO : 02-09-06 at 03:17 PM. |
#3 (permalink) | |
dealer-opted track pack
Keep me posted on how well this works out for you!
#5 (permalink) | |
Blackend Motorsports
Any update on this? Did the GM Camber Shims work out?
G2 Legend Engine Dampers NOW IN STOCK! Click Here! Quote:
#7 (permalink) | ||
0000$$$$0000####0000
I now recomend the shims because it is a PITA to remove and reinstall the bolts. Sometimes it goes back in real easy, and sometimes it is a bitch to realign since there is still tension on the arms. With the shims you don't have to fully remove the bolts so you wont have that problem. Fortunately for me it was a 1 time job so since I had the washers in there was no reason to change to the shims. If we do my friends new 94 Legend Coupe (He had my old 91 before) we will definately use shims this time around.
#9 (permalink) | |
Ryan Burnett www.spooled.org Weapon R Intakes Below Cost, Turbo Parts, Shirts.... http://www.spooled.org/43400054.jpg |
| Wilwood Brake Kit Group Buy | mrkeith | Group Buys | 69 | 03-24-08 02:57 PM |
| Audio bracket part needed. | MarkyD | Audio, Video, & Electronics | 2 | 02-18-05 02:50 PM |
| switch part number | Merlin the Wrench | Second Generation Legend (1991-1995) | 10 | 05-18-04 09:44 AM |
| Obtaining Honda Part Numbers? | 2LegendMan | First Generation Legend (1986-1990) | 2 | 04-03-03 03:40 PM |
| my car got PRY OUT, can someone pls identify this part for me & provide instruction ? | gAmEs0n | Second Generation Legend (1991-1995) | 6 | 06-10-02 06:33 AM |
