WHAAAAAH!
Urethane kits = Stronger and less likely to break and crack. More expensive, but well worth the money
Fiberglass kits = cheap, and likely to crack. Not easy to fix, and who wants to roll around with a crackedy ass body kit until they get to the paint shop. Basically, buy the urethane kit. Buy the best, cry once.
Urethane may tear...and that's hard to fix. As far as fiberglass being cheap, that's not necessarily true. If you buy a cheap kit for like $600 for the entire thing , then yes, it will be a cheap kit and prone to cracking. 95% of the kits coming out of Japan are FRP (fiberglass reinforced plastic) and the quality is excellent and does not crack easily. Also, if you crack or break a fiberglass kit, it's pretty easy to repair.
Sorry.... just my $.02 .... BTW: I pulled the front bumper off my Lexus on a driveway (and it's fiberglass) and the sheet metal gave before the fiberglass did.
_____________________ mark@highsocietyVIP.com http://i16.photobucket.com/albums/b1...g?t=1164987466 |
I have a friend in an Integra club who has several bumpers for his car and is into the bodykit stuff. He says Urethane is the best until you hit or scrape, because you are basically screwed and have to buy new stuff. Fibreglass is very easy to repair even missing chunks apparently...
If you get a good brand the fibreglass can be very good and very stiff... I believe that Blue Class is the cheapo stuff that comes blue coated, but when I saw some of it at the local speed shops I was surprised by how thin the material was and how easily it flexed... Looked like it would blow off the car in high winds, let alone driving with it on there. I went "middle of the road" and got an Andys kit. Best quality have I seen in a fibre kit. PS: Finally got a NICE EAI air ride kit. If you go with the Andys kit you will have to more than likely. I could not pull into a single parking lot with the front bumper on. Literally 2 inches off the ground at STOCK RIDE HEIGHT!
-Sh0ck3d |
LeGeNdS NeVeR DiE!
From my experience, I'd say that if you can actually find a urathayne
Basically, fiberglass is much cheaper to make and produce. Unless you have a bad habit of hitting curbs and potholes on a regular, a fiberglass kit will last you the lifetime of your car (as long as you maintain your cars finish). The good thing about fiberglass is that it is very inexpensive to repair so in the event that you do accidentally crack it, it can be repaired very easily and cheaply. If you plan on driving your car with a fiberglass kit installed during the winter, this is when the kit is most likely to crack only due to the fact that fiberglass becomes extremely brittle in cold conditions. Keep in mind that although urathayne is more durable, it is next to impossible to repair since cracks are very difficult to bond back together. Hope this helps. SaGe69
SaGe69 - Reprezentin T.O. since 2000 |
Now = 94 L sedan
so urethane is pretty much kinda like plastic right ? and are flexible enough that it doesnt just crack and break in half ?
where can i order one of those evolution kit (i think thats what its called) for the sedan in urethane or fiberglass if urethane isnt available ? |
#10 (permalink) | |
1ofAknd
http://img43.photobucket.com/albums/...dnegel/sig.jpg |
