Old 08-20-08, 03:20 PM   #16 (permalink)
Nashracing24's Avatar
Car 1: 1991 Acura Legend Coupe
ok, i have replace the control box so i dont think its anything inside there, because
it did it when i first started the car, til present. a few months, can i take that box off the top and clean it?? the valve lift or w/e??
Thanks
Nashracing24 is offline
Old 08-20-08, 04:15 PM   #17 (permalink)
Quaraxkad's Avatar
Car 1: '94 Legend LS sedan, 203k
Car 2: '92 Cutlass Supreme
Thanks
You said that you failed your emissions test, but have you cleared the ECU code yet to see if it comes back? You may have already fixed the EGR problem and need to look somewhere else.
1994 Acura Legend LS
Done: WeaponR Secret Weapon with K&N inverted cone filter, JDM headlights, inverted dash warning lights, mesh grille, RaceConcepts rotors, ceramic pads, Bondo'd rust(!), Pioneer DEH5800MP, JL Audio e1800D, 10" TC Sounds TC-1000 in custom birch box, MLS-copy front strut bar, Stromung cat-back.
In Progress: OEM headgaskets.
Soon: Looking for a mint GS to replace my LS for future plans.
1992 Oldsmobile Cutlass Supreme S coupe
Quaraxkad is offline
Old 08-21-08, 01:12 AM   #18 (permalink)
Yes i cleared the code
what copuld be the problem.and yea i failed emissions
Old 08-21-08, 01:26 AM   #19 (permalink)
Quaraxkad's Avatar
Get a vacuum gauge/hand pump and do the tests I posted. You could replace the valve and solenoid 100 times each with other used parts and never fix the problem.
EDIT: You can rent a vacuum pump for free from Autozone.
Old 08-22-08, 06:55 PM   #20 (permalink)
Really,
i work at autozone and i didnt know that. i knew we rented tools but dang free?
idk lol
ill ask tomorrow
Thanks man.
ill try those tests when i can and let you know
Thanks
Old 08-22-08, 08:08 PM   #21 (permalink)
Smalltalk's Avatar
Car 1: 1995 Acura Legend
Did you clean EGR "Pipe"?
You said you cleaned the Intake Manifold. Did you clean the EGR Pipe that runs from the EGR Valve to the back of the Intake Manifold, as described in this thread:
egr valve
Smalltalk is offline
Old 08-25-08, 01:47 AM   #22 (permalink)
yes
I cleaned it the best i could, how do i make sure its really really clean inside of the pipe, i cant see inside of it???
Thanks
Old 08-28-08, 12:31 AM   #23 (permalink)
Hey
I heard that the nox emissions have to do with the temp inside the chambers.would water or anitfreeze be cooler?? and i heard if i retard the timing or turn it down really low ill pass nox w/ flying colors.
Help
is this true??
Thanks
Old 08-28-08, 01:03 AM   #24 (permalink)
sap
burning dinosaur bones
sap's Avatar
Car 1: 93 L Coupe 6MT
Car 2: 86 Camaro IROC Z
Car 3: 05 Grand Caravan
Help
is this true??
Thanks
Yes, NOx production is stunted when you're burning cool, it's the entire point of EGR. You're asking for trouble if you try using water instead of antifreeze.
sap is offline
Old 08-28-08, 02:05 PM   #25 (permalink)
DrDave's Avatar
Car 1: 94 LS Coupe'
Car 2: 91 NSX
Car 3: various cars & bikes
How about that lift sensor?
Dave
DrDave is offline
Old 08-28-08, 03:45 PM   #26 (permalink)
ok. i performed the vacuum test
i did the egr vacuum test and the car did stall. so it said it is an electrical problem with the egr not vacuum now right
my car actually cut off lol.my egr valve is good.its an electrical problem right??
Thanks
Old 08-28-08, 08:13 PM   #27 (permalink)
Car 1: Honda Legend KA7
Check voltage between + and GND terminal oft lift sensor. Should be 5V. Check voltage between the out terminal and GND and apply variable vacuum to the AGR valve. The OUT voltage should change together with the vacuum in the range 1.2V...4V.
If the lift sensor does not supply correct voltage to the ECU, the AGR control loop will not work correctly.
Daniel_S is offline
Old 08-30-08, 07:08 PM   #28 (permalink)
Smalltalk's Avatar
Diagnostic Procedure in Service Manual
Did you follow the diagnostic procedure in the service manual? I saw someone already provided a similar description - so maybe you already have.
The manual is online (per sticky):
Acura Legend Online Service Manual Thread (G1/G2/G2-TCS)
In my copy, it's on page 11-132.
Old 08-31-08, 08:09 PM   #29 (permalink)
ah i did.
alright i will see bout it thanks
Old 09-16-08, 05:52 AM   #30 (permalink)
Factory Freak!
92drls's Avatar
Car 1: JDM KA8 5sp
Car 2: Lincoln LS8 RIP
Reading through this post makes me so thankful to have such a knowledgable crowd watching each others back!! You guys rock!!
92drls is offline
