Old 08-16-08, 11:26 PM   #1 (permalink)
Nashracing24's Avatar
Car 1: 1991 Acura Legend Coupe
PLease HeLP. EGR question
ok, my egr engine code 12, still comes on after i replaced the unit with another one and cleaned out EVERYTHING spot shiny inside out, intake man and all, the dang lite still comes on after i go about 200 yards. PLEASE tell me WHY my light wont go away.
JDM type 1
Type 2 maniold.
Thanks
Nashracing24 is offline
Old 08-17-08, 12:06 PM   #2 (permalink)
Quaraxkad's Avatar
Car 1: '94 Legend LS sedan, 203k
Car 2: '92 Cutlass Supreme
Did you clear the code after cleaning the EGR? Did you replace the valve with a new one or used? Did you test it with a vacuum gauge?
1994 Acura Legend LS
Done: WeaponR Secret Weapon with K&N inverted cone filter, JDM headlights, inverted dash warning lights, mesh grille, RaceConcepts rotors, ceramic pads, Bondo'd rust(!), Pioneer DEH5800MP, JL Audio e1800D, 10" TC Sounds TC-1000 in custom birch box, MLS-copy front strut bar, Stromung cat-back.
In Progress: OEM headgaskets.
Soon: Looking for a mint GS to replace my LS for future plans.
1992 Oldsmobile Cutlass Supreme S coupe
Quaraxkad is offline
Old 08-17-08, 03:52 PM   #3 (permalink)
the code
goes away everytime i turn off the car. and no vacuum test, and used
Old 08-17-08, 05:22 PM   #4 (permalink)
Of the Telion Chip
Telion's Avatar
Car 2: White 91 KA8 JDM TII
You still need to reset the code to clear it out of the ECU, and double check your vacuum lines not sure if I saw where you said you did this, you may also wanna check hoses 3, 5, and 21,sometimes those are easy to mix up with the EGR hose at the MAP box.
Telion is offline
Old 08-17-08, 05:30 PM   #5 (permalink)
Quaraxkad's Avatar
Turning off the car doesn't clear the ECU memory. Remove the ACG fuse from the fuse box under the dash for 15-20 seconds. If the code comes back, you still have a problem.
Old 08-18-08, 09:51 AM   #6 (permalink)
RALPHS HANDS ARE CLEAN!
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
OR disconnect battery!
blkonblkcpe is offline
Old 08-18-08, 10:53 AM   #7 (permalink)
Quaraxkad's Avatar
But then you loose your radio presets.
Old 08-18-08, 11:53 AM   #8 (permalink)
Yeah, but it's still easier than crawling under the dash, at least, for my old ass it is!
Old 08-18-08, 06:58 PM   #9 (permalink)
ok
alright, i took my im off and cleaned it to shiny again. no more crud at all. it was disgusting. i put some gauranteed to pass emissions in and rode around for a bit then went back, i passed everything with flying colors EXCEPT nox emissions. i have a magnaflow catalytic converter on there. what else could this be please help, im tired of spending money on things i dont need.
please help, allowed 879 nox and had 1378 please whats the issue
and where is the thermo valve and hoses.
thanks
ill double check all vacuum lines again for cuts or tears along with making sure they are all rightly put on.
thanks
Old 08-18-08, 07:11 PM   #10 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
My NOx wasn't quite over the limit here in AZ (my CO was over though) but here are my numbers and how they changed to after each step:
AZ allowed 2.50
1st test 2.30 --> cleaned EGR tube and valve, changed to new plugs
2nd test 1.42 --> changed O2 sensors
3rd test 0.64
ari_one is offline
Old 08-18-08, 09:20 PM   #11 (permalink)
DrDave's Avatar
Car 1: 94 LS Coupe'
Car 2: 91 NSX
Car 3: various cars & bikes
Code 12 is the EGR lift sensor. Could simply be a bad sensor.
Dave
DrDave is offline
Old 08-19-08, 01:13 AM   #12 (permalink)
where is that located???
the egr lift sensor
Thanks
Old 08-19-08, 02:05 PM   #13 (permalink)
Quaraxkad's Avatar
The lift sensor is connected to the valve, which is what you already replaced. Correct? You need to get a vacuum gauge and a vacuum pump to properly test the system.
Old 08-19-08, 02:53 PM   #14 (permalink)
correct,
and yeah i do
Old 08-19-08, 03:02 PM   #15 (permalink)
Car 1: Honda Legend KA7
On Honda (UK) you may download the workshop manuals for free:
cars->Honda owner->Parts and servicing->workshop manual
The sensor for the AGR valve lift is sitting on top of the AGR valve. It is a small box made of thin, silver sheet metal. Possible reasons for wrong sensor signal:
-vacuum does not built up on the AGR. If the AGR valve is supplied with vacuum at mid-load, check the diaphragm in the AGR valve for leaks. If no vacuum is present, check the hoses and the modulation valve in the control box
-AGR valve is stuck, clean with oil and move it manually
-defective lift sensor or missing supply voltage.
Daniel_S is offline
