Old 09-11-02, 04:10 PM   #1 (permalink)
When We Ryde
Car 1: '92 LS Sedan Black on Black
Car 2: '03 TL-S
Car 3: '89 Teg
Send a message via AIM to Bo Ku
Projector Mod
For any one who has done this mod on their G2 leg w/ stock USDM 2piece housings:
I'm planning to do this project on sunday so i had a few questions for all yall out there who have succesfully completed it. (I know there are a couple of you out there). I'm using the projectors out of an OBX Civic Projector Conversion.
- How long does it take / Can it be done in one day (I have work on monday.)
- Witch process is easier, a heat gun or the oven?
- how did you mount your projector/ lense?
- What type of calk did you use to seal the housing back together?
- Can i use my HID kit in cunjunction with the projectors?
By the way if any of you have any pics of the install or the finished product i would greatly appreciate it?
Also if you have any other suggestions feel free to post.
THANKS!!!
http://www.imagestation.com/picture/...0/fcf13020.jpg
'92 LS, SEDAN
Black-on-Black
------Mods------
- Kenwood KVT-910DVD
- Kenwood Music Keg
- Alpine TME760A
- MB Quart QM218
- MB Quart QM216
- PPI PC21400
- PPI PC2200
- PPI PC2100
- JL Audio 10w3 (x3)
- Catz HID kit w/ HID PLUS II Bulbs
Bo Ku is offline
Old 09-11-02, 09:11 PM   #2 (permalink)
Car 1: 94 Legend GS
Send a message via AIM to Mtnduey Send a message via Yahoo to Mtnduey
Re: Projector Mod
THANKS!!!
I havnt read up on the install your talking about so I dont know about the Heat gun or Oven, but it seems to me the Heat Gun would be easier to control dont ya think? But like I said I dunno the process for this idea, just saying if your looking to control the heat better I'd say Heat gun.
For Mounting it just remember of course to keep the car as level as you can and do the same thing with the projector. I'd almost be tempted to just make it adjustable if at all possible, to do fine tuning once its in there. If thats not an option then I'd say get a good flashlight that'll fit inside and a leveling device (bubble level, etc...), these are just ideas, like I said above I havnt read the full story on this, if you have a link can you post it so I can maybe give you more ideas?
I'd be tempted to use silicone rubber and apply it with a small brush. Its water proof, lasts 15 years, and bonds to pretty much anything. Just make sure to clean the area its applied to before you put it on, like with rubbing alcohol or something. Just be careful like always.
I'd really love to see the whole kit sale, idea, etc... somewhere online so I can read it and give you more/better/revised help. This sounds like a friggin SWEET thing to do.
Are you gonna put the Projection part in the High or Low beam area? If you put it in the High beam and keep the Low Beam setup with your HID's, then all you gotta do is make sure they both turn on when you turn your lights on, so tapping into the same turn on basicly. You may want to consider upgrading your wiring harness to a good quality harness with a Higher wattage load while your in there.
Good luck Bo Ku, this should be really darn sweet when your done. Just take your time and dont rush it, you dont want your job to look rushed anyway.
Live a little, buy a Suzuki GSXR 1000 today
94 Legend GS - Sherwood Green - Mostly Stock
Mtnduey is offline
Old 09-12-02, 12:01 AM   #3 (permalink)
WhiteLegend's Avatar
actually oven is much better, just bake at 250 for 10mins, then pull apart carefully. That's how I did my taillights, maybe headlights takes a little longer.
Oven is better because it gets all the glue hot and soft at the same time. With the heat gun, you can only heat small sections at a time, and pry open a little at a time, more chances for damage the lense
http://www.msu.edu/~weizhou/Mylegend/sig5.jpg
WhiteLegend is offline
Old 09-12-02, 01:58 AM   #4 (permalink)
When We Ryde
Car 2: '03 TL-S
Car 3: '89 Teg
Yeah, I got the projectors out of their housing with an oven, it was easy as hell and it only took about five minutes.
By the way what did you do to your taillights?
thanks guys
'92 LS, SEDAN
Black-on-Black
------Mods------
- Kenwood Music Keg
- Alpine TME760A
- MB Quart QM218
- MB Quart QM216
- PPI PC21400
- PPI PC2200
- PPI PC2100
Bo Ku is offline
Old 09-20-02, 10:18 AM   #5 (permalink)
Old S*hool Member
he opennd up his tail lights so that he could paint the amber turn signal section of the lense red instead of stock orange. just open them up with the oven method he mentioned, then mask of the amber and spray the inside of the lense with 3-4 coats of testers candy apple red transparent spray paint (this is model paint and can be bought at any hobby store - I got it at Micheals). Once its painted and dried seal the tailight back up with some silicone caulking.
Worked great for me!
Octane is offline
Old 10-02-02, 04:00 PM   #6 (permalink)
BxLeGEnD
aiznpride's Avatar
Car 1: 95 red coupe
Send a message via AIM to aiznpride
how did you keep the plastic from melting. i'm sure the metal shelf in the oven will do some damage.
-j
aiznpride is offline
Old 10-02-02, 04:02 PM   #7 (permalink)
502MotorSports.com
502 MotorSports's Avatar
Car 1: e39 540i
Car 2: e46 325xi | e46 330i
Car 3: S430
Jae, I used a flat pizza pan...about a 14-16 incher
502 MotorSports is offline
Old 10-02-02, 04:04 PM   #8 (permalink)
BxLeGEnD
aiznpride's Avatar
Car 1: 95 red coupe
ic. and the pan didn't melt whatever it was touching?
-j
Old 10-02-02, 04:06 PM   #9 (permalink)
502MotorSports.com
Car 1: e39 540i
Car 3: S430
-j
no,
if you preheat the oven for 10 minutes, and then place the item and pan in the oven together, it will be just fine. I had mine on at 250. That is the advantage of using a flat pan vs a 16 x 2 or something like that. It really isn't resting on the pan in a concentrated manner so it kind of just recures itself, if that makes any sense.
I was surprised myself, and pleased with the results. Haird ryer/heat gun takes TOOO long, plus uneven heating.
Old 10-02-02, 08:42 PM   #10 (permalink)
Old S*hool Member
just place it right on the oven rack - nothing will melt. I've done it.
Octane is offline
Old 10-23-02, 01:57 AM   #11 (permalink)
Posts: n/a
ok when i take apart mine i just need to put it in an oven for 10 minutes at 250?
then how do i seal it back up
ok thanks
Old 10-23-02, 08:44 AM   #12 (permalink)
Limited Quantities
Car 1: 2004 Acura TL 6-sp
Car 2: GONE-95 Legend L 2dr
Send a message via ICQ to Crazy Cuban Send a message via AIM to Crazy Cuban Send a message via Yahoo to Crazy Cuban
Originally posted by Octane
he opennd up his tail lights .... Once its painted and dried seal the tailight back up with some silicone caulking.
I'll just repost this for the guy who can't read j/k
<form action="https://www.paypal.com/cgi-bin/webscr" method="post"><input type="hidden" name="cmd" value="_xclick"><input type="hidden" name="business" value="debbiewhelan@bellsouth.net"><input type="hidden" name="item_name" value="Help Pay For Forum"><input type="hidden" name="item_number" value="forum1234"><input type="hidden" name="no_note" value="1"><input type="hidden" name="currency_code" value="USD"><input type="hidden" name="tax" value="0"><input type="image" src="https://www.paypal.com/images/x-click-but21.gif" border="0" name="I1" alt="Make payments with PayPal - it's fast, free and secure!" width="110" height="23"></form>
There is only one LEGEND! We may never see another one like it!
Crazy Cuban is offline
Old 10-23-02, 09:01 AM   #13 (permalink)
Avarice's Avatar
Car 1: 2001 VW Jetta 1.8T WE
Car 2: 2002 Honda S2000
Do you guys put stuffing inside too?
[img]
My 1991 Legend (SOLD)
Sedan Type-F floor mats
Driver Side seat
Yakima Roof Mount and Bike Rack Set
Avarice is offline
Old 10-23-02, 02:55 PM   #14 (permalink)
B+O
G2BMC
B+O's Avatar
Car 1: why?
Send a message via AIM to B+O
heheheheh he's got jokes lol
B+O is offline
Old 11-07-02, 10:57 PM   #15 (permalink)
R*de *n s*yle:91 L
Car 1: 91 sedan
Send a message via ICQ to some legend Send a message via AIM to some legend
thanks giving is almost here
some legend is offline
