Q: Does ATF fluid go bad? How about motor oil/coolant? Shelf Life? - The Acura Legend & Acura RL Forum
Old 01-25-07, 05:32 PM   #1 (permalink)
S4gunn's Avatar
Car 1: 02 Audi S4
Car 2: 97 Honda Accord SE
I have half a bottle of Honda ATF left over from my last ATF drain & fill approx 14 months ago. The cap has been on the ATF and its been in my trunk for the past year.
Aside from the temp swings it's been exposed to (Tahoe winter through 85F on the hottest days in San Jose), does ATF fluid necessarily go bad if the bottle is kept closed and its out of direct sunlight?
What about oil?
and Coolant?
Summary:
* Brake Fluid (if opened):
- it's hydroscopic so it will absorb water from the atmosphere (This is bad because water doesn't compress like brake fluid)
- generally a bad idea to use an opened bottle. Chuck it within a few weeks.
* Oil
- 2 to 5 years (sealed in temp stable location)
http://forums.noria.com/eve/forums/a...5/m/2131028841
- 5 years max according to Mobil
http://www.mobiloil.com/USA-English/...helf_Life.aspx
* Coolant
- I had some sealed coolant for my Audi that i bought a few years ago. My mechanic said that it was no problem to use it as long as the bottle remained sealed.
- If you think about it, it really doesn't matter if water gets into the coolant since coolant should be a mix of 50% antifreeze and 50% water.
* ATF
-BobtheOilGuy.com recommends a shelf life of 3 years max under protected conditions. Does not apply to previously OPENED bottles
http://www.carbibles.com/engineoil_bible.html
- Dealership recommends 3-5 years because "it goes through a lot
worse inside the tranny.
* Gear Oil
-BobtheOilGuy.com recommends a shelf life of 2 years max under protected conditions. Does not apply to previously OPENED bottles.
Any other feedback?
-g
2002 Audi S4
S4gunn is offline   Reply With Quote
Old 01-25-07, 05:52 PM   #2 (permalink)
Prez of ACURA-HOLIKS
L3GDKANG/JDM-KANG's Avatar
Car 1: 91 Sedan sprite green
Car 2: 92 LS coupe
Car 3: 93&94 LS sedans
iTrader Score: 9 reviews
Send a message via Yahoo to L3GDKANG/JDM-KANG
What about oil?
and Coolant?
Summary:
- it's hydrophilic so it will absorb water if exposed to it.
* Oil
* Coolant
Any other feedback?
-g
yes 5 years max unopened! i use to be the service manager at a Jiffy Lube! try looking it up on shell.com
JDM MODS (Boxer from Brooklyn)Jdm navi console,power folding mirrors,rear reclining/heated seats,bumper pole but retro fitted,jdm twin storge bin rear deck, jdm one pieces(cat eye's) with tsx projectors retro fitted,jdm Legend floor mats,Alpha Touring grill,and Custom interior also!(TN brawler) thank you DA
L3GDKANG/JDM-KANG is offline   Reply With Quote
Old 01-25-07, 07:02 PM   #3 (permalink)
S4gunn's Avatar
Car 1: 02 Audi S4
And once the oil has been opened (but kept shut)?
-g
2002 Audi S4
Old 01-25-07, 09:05 PM   #4 (permalink)
Car 2: 92 LS coupe
-g
i'd give it a year tops!
Old 01-26-07, 01:58 PM   #5 (permalink)
S4gunn's Avatar
Car 1: 02 Audi S4
Thanks!
-g
Has a great section on different oils:
Base Oils, Process Oils 3 years
Hydraulic Oils, Compressor Oils, General Purpose Lubricating Oils 2 years
Engine Oils and Transmission Oils 3 years
Industrial and Automotive Gear Oils 2 years
Metal Working and Cutting Oils 1 year
2002 Audi S4
Old 01-26-07, 02:49 PM   #6 (permalink)
Car 1: 1992 Acura Legend
Oops...maybe explains my tranny issue?
drmonkey is offline   Reply With Quote
Old 01-26-07, 08:03 PM   #7 (permalink)
Car 2: 92 LS coupe
yes cause it brakes down and once it does it's not any good believe me on that! we had to dispose of soo much fliuds that we're open!
Symptoms Of A Bad Twc Sensor! KINGFABIAN Second Generation Legend (1991-1995) 7 04-03-06 10:25 AM
HONDA ATF Fluid Flush/Change aminus21 First Generation Legend (1986-1990) 7 09-18-04 08:59 AM
What are the symptoms of bad or old brake fluid? drewk2 Second Generation Legend (1991-1995) 2 07-24-03 12:04 PM
4X Tranny Flush Q for Gil OR anyone else pasha95GS Second Generation Legend (1991-1995) 28 12-16-02 12:37 PM
