Old 02-17-06, 02:34 AM   #1 (permalink)
Kia Killa
sr5guy's Avatar
Car 1: 91 L Sedan Rosewood
Car 2: 91 Coupe 3.5 *SOLD*
Car 3: 96 Legacy
A Quick & Easy Way To Spot a Bad Head Gasket BHG
Heres a quick and easy way to spot a BHG. If you see this gook under your radiator cap or in the reservoir you better start saving your money.
Stop asking me to compare my chip with Telion's damnit. Mines better .
sr5guy is offline
Old 02-17-06, 02:50 AM   #2 (permalink)
Dont Catch
bl420's Avatar
Car 1: 1991 Sedan
Bar's stop leak???
**Anti Alpine Type-R Thread**
bl420 is offline
Old 02-17-06, 03:04 AM   #3 (permalink)
Kia Killa
sr5guy's Avatar
Car 3: 96 Legacy
No way... that's not stop leak. That mess forms from exhaust fumes entering the coolant from a BHG. It smells like exhaust gas, too. If your shopping for a legend, first thing to check is the radiator cap and overflow hose. If the seal on the cap is swollen or the overflow hose is swollen and smells like exhaust fumes or if it has this gook on it, than you can bet that you have a BHG. Supposedly, the chemical reaction turns the coolant acidic which eventually eats out your radiator and heater core. I ran the car for quite awhile without a thermostat until I finally changed the head gaskets last month, that explains the amount of buildup.
P.S. If you've done a head gasket job on a Civic, you can do one on a Legend. Dont be scared, they are alot easier than you might think. Most pain in the ass part is taking off the EGR pipe on the back of the intake.
sr5guy is offline
Old 02-17-06, 12:07 PM   #4 (permalink)
FIXER
When I put the wrong type of antifreeze(Dexcool) in mine it developed a brown sludge in the cooling system. I don't know if it's the same as that.
Just for info, your cap, radiator and coolant can look normal and still have a BHG. If it does look like yours did it's a real bad sign.
Jetdoc is offline
Old 02-19-06, 11:00 AM   #5 (permalink)
Kia Killa
sr5guy's Avatar
Car 3: 96 Legacy
That brown sludge was probably from the exhaust gases mixing in with the coolant, same as my car. I have done headgasket jobs on newer GM 3300 motors which use dexcool from the factory. Dexcool forms CLEAR sludge, with round balls in it almost like hair gel. I think its from from the silicone content in it, the buildup seems similiar to he silica gel packets you get in a new box of sneakers.
I have been shopping for a new legend for about a month now. I went to look at one last week and first thing I saw was a mildly swollen reservoir hose that smelled foul. Took the car for a ride on the highway, when I got off, sure enough, the temp started to creep up. Nonetheless, the seller felt really stupid.
P.S. Were you running your car with the thermostat removed or stuck open?
sr5guy is offline
Old 02-19-06, 09:03 PM   #6 (permalink)
FIXER
The Dexcool mixed with the "green" coolant that I wasn't able to flush out when I changed the coolant. See My BHG Story
The sludge was from the Dexcool. It wasn't as dark and gritty as yours. Once I flushed it out, and put Prestone in it stayed normal. I drove for a few weeks with the BHG while troubleshooting and there was not a hint of any exaust gases but I knew they were there. No I never removed the thermostat, just replaced it with OEM.
Jetdoc is offline
Old 07-08-07, 01:29 AM   #7 (permalink)
Kia Killa
sr5guy's Avatar
Car 3: 96 Legacy
Bump for good info. This has been a pretty accurate indicator for me.
-Matt
sr5guy is offline
Old 07-08-07, 02:12 AM   #8 (permalink)
Forevralegend's Avatar
Car 1: 94 Legend gs type II
-Matt
that is good info, thats what my uncle told me like 5 years ago when i was first learning to work on cars and hes been working on cars all his life professionally
mods-
2.5" mandrel exhaust, deleted cat, cold air intake, web cam regrinds, comp cam valve springs, port & polish heads and manifold, tb bypass, egr block, five speed clutch/flywheel, 80a polyurethane mounts all around, type 1 pulley, headers,re-fabed y-pipe, SR5guy Custom Chip, 6speed swap, Apexi safc II, strut bar, F/R sway bars, FL tie bars, tune
Forevralegend is offline
Old 07-08-07, 09:00 AM   #9 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
Now that the entire world has had a chance to read this, there will be a "run" on Legend radiator caps. Let's see...I have a blown headgasket. I only have to clean out the reservoir and change the cap. Viola!
I firmly believe that anyone electing to buy a used Legend needs to have the engine tested. I still believe that the easiest is to have the radiator fill opening "wanded".
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Wings West Spoiler w/LED
Clear Corner Lens
Clear Bumper Lens
Clear Rear Side Markers
Brembo X-Drilled/Slotted
Stainless Braided Brake Hoses
Focus 2500 Driving Lamps
Gold Pkg
LPB is offline
Old 07-08-07, 11:56 AM   #10 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
Car 2: 1994 Civic EG Hatch
Car 3: 03 Honda TRX400EX
You might want to check the oil for coolant. That's typically a sign that oil has entered the cooling system. Exhaust gases wouldn't make it sludge up like that.
coolant in the oil probably means the crank bearings have been scored. Prepare for a future bottom end problem, I've already seen it twice. Both engines ended up with a rod through the side of the block months after the head gaskets were replaced.
Mike Diaz is offline
Old 07-08-07, 12:16 PM   #11 (permalink)
Beautiful backdrop!
blkonblkcpe's Avatar
Car 2: ,Red tails, Type 2
Car 3: 6 speed, EDM spoiler
Another "fairly quick" way, is pull the spark plugs. If one or two seem like they were washed clean, chances are that cylinder bank's where the HG is leaking.
DUAL REMUS IS PHOTOSHOP!
http://www.acura-legend.com/vbulletin/883766-post7.html
91 with type II engine, SR5GUY stage 3, hi flow cat, 6 speed tranny, 04 TL knob, EDM headlights, EDM spoiler, carbon fiber interior trim, type II cluster, OBX headers, 2 1/2" Catback to Remus Rev 3, CAI.
blkonblkcpe is offline
Old 07-08-07, 12:17 PM   #12 (permalink)
Kia Killa
sr5guy's Avatar
Car 3: 96 Legacy
Next time you get a legend in with a BHG take a peek at the overflow hose. I guarantee it will at the least be swollen and stink like exhaust. This car did not have oil in the cooling system or vice-versa, the head gasket was rotted out between the #6 cylinder and coolant passage. The exhaust gases mixing with the glycol coolant causes an acidic chemical reaction and that sludge buildup is most definetly a byproduct of that reaction.
-Matt
sr5guy is offline
Old 07-08-07, 03:05 PM   #13 (permalink)
WHAAAAAH!
Mike Diaz's Avatar
-Matt
Matt, I have to disagree. I've done 8 C32A head gaskets to date. 7 of them were perfectly clean with coolant being sucked into the rear cylinders. There were no hints of any brown residue in any of the reservoirs. I make sure I check this before putting the car back together. 1 of the cars that had the brown residue in the overflow came back with a hole in the side of the block. When I tore the block down, you could see where the crank bearings had been scored so bad that it heated up the end of the rod and allowed it to break.
My buddy also performed a head gasket job at his shop, it had the brown residue in the overflow. 7-8 months later, that engine came back too with a hole in the side of the block. Same exact scenario.
Old 07-08-07, 05:38 PM   #14 (permalink)
LPB
It begins to appear that when a seeping headgasket "rears its ugly head" that most prudent action would be a JDM engine and an R&R of new headgaskets prior to reinstall. Unless you perform the work yourself, for the early G2s it would be more cost-effective to just part it out or drive it to the recycler.
Eyebrows
KMS Strut Bar
Enkei 16" J-Lips
Clear Corner Lens
Clear Bumper Lens
Gold Pkg
LPB is offline
Old 07-09-07, 11:37 AM   #15 (permalink)
Kia Killa
sr5guy's Avatar
Car 3: 96 Legacy
Well at least we agree on one thing - and that is that the brown residue is an indication of a very BHG.
-Matt
sr5guy is offline
