Old 02-22-05, 06:12 PM   #1 (permalink)
Car 1: 92 Silver Legend
Quick question about tire sizing, the speed sensor etc...
Well i posted this in another thread but it went unnoticed so i pose the question again:
What tire size would you recommend for 18 inch wheels in order to keep the spedometer correct and avoid bumping etc and looks... Speaking of which, does the total tire diameter even affect the spedometer on this car, I suspect it would given the speed sensor likely measures rotational velocity of the bar leading to the wheel and thus with a larger diameter the speed would read low due to the fact that now the true rotational velocity of the tire would be increased with respect to the rotational velocity of the speed sensor...
Theava is offline
Old 02-22-05, 06:25 PM   #2 (permalink)
TSX pupils
Car 1: 1995 Legend GS
Send a message via AIM to Daddymac117 Send a message via Yahoo to Daddymac117
well if youre getting 18's, any tire you put on it is still going to be bigger than the stock 15" tires and rims (or 16" in some cases), so the speedo is gonna be off no matter what. As for what size to get, i dunno...ill wait for someone else to chime in on that lol. But the larger the rim, the slower your speedo will read...
http://www.onlineconversion.com/bigger_tires.htm
when the speedo tells you that youre doing 55, youre really doing 66...when it tells you youre doing 65, youre really doing 78. Its just something youre gonna have to live with if you get a larger diameter wheel. I asked Ivan (B&O DK) the other day if there was something to be able to correct the speedo to compensate for larger diameter wheels, and he said no.
FS: Weapon R Secret Weapon intake (NON TCS/Type I) in box, never used. $140 shipped.
I'll make a thread once i figure out the best way to ship it, but PM if interested.
Daddymac117 is offline
Old 02-22-05, 06:26 PM   #3 (permalink)
Member
ArizonaLegend's Avatar
Car 1: 93 Legend LS Sedan
Car 2: 93 LS Coupe 6spd
Car 3: 03 Honda VTX 1300
Discount Tire has good reference info....
http://www.discounttiredirect.com/di...992&vid=000009
18's shows:
215/40/18 or
225/40/18
and
1993 Legend LS Coupe 6spd-Sirius White Pearl-22K (12/04-?)
1993 Legend LS Sedan-Sirius White Pearl 75K- (8/00-?)
1988 Legend L Coupe-Noble Silver Metallic (8/04-10/05)
1988 Legend L-Olympia White (2/04-12/04)
1987 Legend L-Ascot Grey Metallic (12/89-2/04)
ArizonaLegend is offline
Old 02-22-05, 06:42 PM   #4 (permalink)
So there is no way to adjust the spedometer to compensate eh?
Theava is offline
Old 02-22-05, 06:43 PM   #5 (permalink)
Hell that will drive me fricken crazy there has to be a way to correct it... Like so much so it would make me not want to get new wheels, i wonder how much 17's would mess it up.
Theava is offline
Old 02-22-05, 07:13 PM   #6 (permalink)
TSX pupils
use the conversion thing that i linked you to...you can enter in the diameter of the stock rim, and new rim, and plug in diff values for the speedo reading to show you what your actual speed will be...then i guess its just a matter of memorization...know that to stay within the 65mph speed limit, remember that your speedo will say like 54-55...
Old 02-22-05, 07:15 PM   #7 (permalink)
Yeah i saw that, seems nice. Im just thinking there has to be someone somewhere that can edit the value of the speed sensor output or something.
Theava is offline
Old 02-22-05, 09:17 PM   #8 (permalink)
0000$$$$0000####0000
Car 1: Acura
Running larger rims like 18" rims doesn't mean you will hvae an over all diamter too much larger than the stock 15" rim/tire combo. For example. I went to check the specs on certain tires. For a typical stock size 205/60/15 Legend tire, the over all diameter is about 24.7" according to various manufacturers. Checking the same for 18" tires, the typical 225/40/18 tire that is normally used on 18" rims have an over all diamter of 25.1". Now, using that link you provided above and plugging those numbers into the calculator, you see that a stock 205/60/15 Legend tire running at 60MPH will still be very close to an 18" rims running 225/40/18 which will read 60.97MPH according to that links calculations. This is a non issue and you probably can't feel any difference within1-2 MPH anyway.
Going down the list of other typical tire choices compared to the stock size running a 60 MPH we have"
215/50/17=61.94 MPH
215/45/17=59.75 MPH
225/45/17=60.72 MPH
Anyway, the mistake you made when entering numbers in that calculator is you inputed the rim diameter of 15" for stock and 18" for aftermarket. You forgot about the tire diamter. Notice they ask for orginal tire diameter and new tire diamter? Your computations would be accurate if you drove on the rims only
ChrisK is offline
Old 02-22-05, 09:26 PM   #9 (permalink)
TSX pupils
ahhh...touché :p
Old 02-22-05, 09:36 PM   #10 (permalink)
L E G E N D
FutureX 2001's Avatar
Car 1: '95 Coupe
Car 2: '94 Sedan GS
Car 3: '90 Coupe
*smacks Daddymac117* how many times have I told you? Do not mess with the Legend Gods!
haha sorry couldn't resist, i would've made the same mistake :p
FutureX 2001 is offline
Old 02-22-05, 09:42 PM   #11 (permalink)
TSX pupils
LOL!
Old 02-22-05, 09:47 PM   #12 (permalink)
Car 1: Acura
At first I couldn't understand how you got a 10MPH difference. To get about 10MPH apart I had to enter sizes for a 305/40/22 SUV application Anyway, I finially figured out how you came up with your numbers when I put in the 15" and 18" sizes
ChrisK is offline
Old 02-22-05, 10:00 PM   #13 (permalink)
TSX pupils
yea, i thought a 10mph diff was a bit extreme too...i started learning about all this stuff about last week or so, and when i found that converter and plugged in those values, i thought something had to be up so i asked Ivan while we were talking on AIM, and he didnt really say anything about it...(probably busy lookin at pr0n, and didnt really care anyway )
*writes on post-it note*
"note to self...never...ask....Ivan...a question....while...hes...watching....pr0n..."
*spells it out loud while writing* "pee..arr...zero....enn"
:p
Old 02-23-05, 11:47 AM   #14 (permalink)
Thats what I though from reading on discounttire.com but then I got all confused and flustered thanks for clearing that up!
Theava is offline
Old 02-24-05, 06:29 PM   #15 (permalink)
B+O
The Mac vs. The Mack
B+O's Avatar
Car 1: why?
Send a message via AIM to B+O
:p
LMAO...
i dont care what anyone says...breasteses are 1000000000x more interesting the tire diameters
B+O is offline
Quick Question Re: Minimum drop on car Mckenzie93 Second Generation Legend (1991-1995) 15 04-07-04 03:45 PM
another quick question on the 94-95 L and LS sound system again 91LegendCoupe Audio, Video, & Electronics 3 03-27-04 02:27 PM
