#31 (permalink) | |
For some reason, the sedans seems to have the fronts stick out more than the rear, so I had to make the rears poke more, and it still seems the front poke more than the rear. Hmm.. |
#32 (permalink) | |
dealer-opted track pack
What are you asking for the barrels? Any curb rash, dings, or bends? k.
#33 (permalink) | |
I still have to get the tires removed, so I'll have to install the brand new higher disk spokes to have the shop remove the old tires. |
#34 (permalink) | ||
33mpg 6spd Coupe
#35 (permalink) |
The JIC spring rates are 14/8, and the dampeners are much stiffer than the Ksports, even compared to the Ksports dialed all the way to stiff. Do the Ksports have a progressive-rate spring?
My car definitely oversteers and Brian's understeers like a typical Legend. Since our tires aren't staggered, the difference should be suspension-related. Daft Punk tonight! k.
#36 (permalink) |
Blackend Motorsports
I think my tires are the major reason for my understeer, even though I do oversteer quite a bit, the first reaction of my car is to push through the turn like a semi on ice at full lock.
Keith was running BFG's against my Kuhmo's and I'd warrant a bet that had we switched rims/tires we'd have switched handling characteristics as well.
NALM NAZI We Brought Them We Broke Them We WILL Rebuild Them Better! G2 Legend Engine Dampers NOW IN STOCK! Click Here! |
#37 (permalink) | |
k.
#38 (permalink) | |
The fact that cheaper coilovers systems have one or all the features of a higher end system usually means there are compromises made somewhere to achieve the price target, I would think this would reflect in certain R&D and construction elements. I hear a lot of complaints about the JICs from other car owners about reliability and price/value considerations but many of these people don't understand that coilovers, like brake pads, is an example where performance targets can render a product completely or ill suited to daily driving. Just like you can't use race pads on the street because they won't perform in their optimal range, with coilovers, specifically the JIC's their performance target is highly track biased which means perceived compromises in reliability and comfort. I would agree with Keith in his statement that the JICs are probably more stiff than the Ksports at their highest setting because the JICs were tuned specifically for track use. I would also conclude that this particular notion should make the Ksports more reliable for street use all things being equal.
#39 (permalink) |
Well written, misdeismo
The JICs are _not_ reliable, especially being driven over public roads; they're designed to be used on the track, and have wicked high compression dampeners that are known to start leaking through the seals. I've got ~2 years on mine and don't expect them to last another two. Road turbulence and potholes murder the JICs.Look at these: http://www.evasivemotorsports.com/me...de=KA7FLTA2VIP The more comfortable JICs... (comfortable is relative) I might look into those once I bust the dampeners on mine, but will most likely just get the Ksports. k.
The performance handling machine... ![]() If you've got coil-overs, corner-balance them! Please protect our environment: use a high-flow. Last edited by mrkeith : 07-22-07 at 03:49 PM. |
#40 (permalink) |
just contacted Darren at this alignment place. There is a 1-2 week wait time to make an appt. WOW. anyways, i think im going soon. right after i change my rear shocks
'01 3.5l rl engine- 6 speed swap done!, type2- cams, valve springs/retainers, and intake manifold. ground control, koni, addco-front & rear, mls copy, 18" volk III rm racing intake, gasket match ported exhaust manifold, light weight pulleys, telion chip, tranny cooler and a bunch of door dings ~from haters |
#42 (permalink) |
It's stock, really.
The engine is already pretty centrally mounted for a FWD...?
So Aaron, any other track experiences you'll be looking for soon? =)
#43 (permalink) | |
33mpg 6spd Coupe
as a matter of fact, yes...
![]() AUTOCROSS @ California Speedway December 1, 2007 AUTOCROSS (CCW) December 2, 2007 AUTOCROSS (CCW) $80.00 /day $140.00 Saturday & Sunday (save $20.00)
#44 (permalink) |
just came back from west end alignment.
This guy is good. if youre in the area and need to get an alignment/cornerbalance. check him out... dont be surprised if he doesnt use those computerized alignment machines.. all manual( if you know what you are doing.. its just as good or better.)
#45 (permalink) |
Glad to see some other Legend owners getting their cars corner-balanced. When I had my Legend with Ksports, I too got it corner-balanced. Really felt even better afterwards.
If anyone in the Atlanta area is looking for a place to get their cars aligned/cornerbalanced by people who actually care and know what they're doing, go to Gran Turismo East or an independent german/euro repair shop called RWL. I'm friends with one of the guys over at RWL and he cornerbalanced my old Legend. And GTE is top notch, we take all our cars from work there to get aligned. |
