Old 06-21-02, 03:48 PM   #1 (permalink)
Car 1: 1995 Acura Legend GS
Rear Tranny Mount and Helms
would someone with a helms be willing to scan and post the section in the Helms book for changing the rear transmission mount?? this would be a good thing to have in the DIY section sense its such a common problem and i really want to change mine but dont want to pay someone to do it.
144,000
My ride
Roger is offline
Old 06-21-02, 08:16 PM   #2 (permalink)
bump
144,000
My ride
Roger is offline
Old 06-21-02, 08:30 PM   #3 (permalink)
shahavchik's Avatar
Car 1: 1994 Granada Black Acura Legend GS Sedan
Car 2: 2007 Subaru Forester
Send a message via MSN to shahavchik
What are the symptoms of the rear tranny mount going bad?
shahavchik is offline
Old 06-21-02, 08:41 PM   #4 (permalink)
well alot of things like harsh shifts but this thread has just about all the symptoms Replaced My Tranny Mount Today
p.s. how do u get a picture in your signature??
144,000
My ride
Roger is offline
Old 06-21-02, 08:48 PM   #5 (permalink)
shahavchik's Avatar
Thanks. I have the book but I don't have a scanner, otherwise I would help you out.
To put a picture in the sig you need to use image tags around the picture URL. - (IMG) http://yourpic (/IMG) (replace "("and ")" with "[" and "]" )
Old 06-22-02, 04:10 AM   #6 (permalink)
**** someone should have a helms and be willing to do this
144,000
My ride
Roger is offline
Old 06-22-02, 02:37 PM   #7 (permalink)
i will send someone like 5 bucks to do this
144,000
My ride
Roger is offline
Old 06-23-02, 03:11 PM   #8 (permalink)
bump
144,000
My ride
Roger is offline
Old 06-25-02, 07:40 AM   #9 (permalink)
LPB
Car 2: 2007 Toyota Corolla
Car 3: 1981 Corvette
Roger: The HELM in this instance will not provide any more than an illustration and torque specs for the bolts.
You will need to disconnect the exhaust at the CAT so you should at a minimum order two new self-locking nuts. When I did mine, I also replaced the two bolts and the two springs as well as the sealing gasket. When you disconnect the exhaust have your exhaust tips covered (I used an old towel) so it will not scratch the underside of the rear bumper. The rest you can determine after you remove the heat shield. You will have to remove the entire mount (two pieces) as a horizontal bolt cannot be removed with the mount remaining in place. If you have a vise it will be of benefit. To install, you need to install the new rubber mount to the bracket with the horizontal bolt installed, but loose. Then remount the entire mount/bracket and retighten all bolts. It is a very easy DIY repair.
LPB is offline
Old 06-25-02, 08:03 AM   #10 (permalink)
Member
Ackvigend's Avatar
Car 1: 1994 Acura Legend GS (Auto)
Car 2: 1993 Acura Vigor GS
Car 3: 2005 Toyo Sienna XLE
Roger,
I just got a question from u? Is ur car automatic? If yes, I just want to ask you if you hear something(like a buzz sound) on the front right side of your car everytime you move ur car (like drive it). 'cause I ask the dealer and they said that's normal I just want to verify it from you.
Thanks,
Anthony
'94 Acura Legend GS (Gold)
'93 Acura Vigor GS (White)
Ackvigend is offline
