Old 09-23-03, 10:35 AM   #1 (permalink)
"the Don"
theGodfather's Avatar
Recharging 134 system... no pressure when system running..
Hope someone can help me out here.
My A/C system was re-charged by a mechanic last summer and it took about 8 months for it to lose its charge (meaning I got a small leak).
Decided to get a self-recharge kit from Autozone and follow the steps on LEGENDTuner. Here is my problem:
I am running the engine and the A/C.. of course initially the compressor isn't running as there isn't enough pressure to set off the triple pressure sensor to engage the compressor clutch.
I attach the gauge to the low side and see there is a slight pressure, but below the minimal 25psi mark.
I then atach the can of R-134 to the hose (the gauge is connected with a T-connector so you can recharge with the gauge on) and start releasing the R-134. I see the pressure start to rise and once it's over the 25psi mark I hear the compressor engage and the system is running.
Here's where it gets wierd.... immediately the pressure drops down to ZERO! I let the whole can into the system and the pressure still is at zero. I then put in a second can and still the same thing. Leaving the gauge on the system, I turn OFF the A/C... immediatley the pressure rises to like 50 - 55psi. I then run the A/C again and pressure drops to ZERO. Car is blowing colder air though.
I evacuate the system a bit on the LOW side to let out some pressure so I'm just a tad below 45psi (when the A/C is off). System seems to work fine.
Two days later my A/C not working again... compressor not engaging. Probalby means I get some leak somewhere big. I put in another bottle just to check... same thing.. no pressure when running A/C.
Here is where I goofed.... I put the whole can in and when turning off the A/C... pressure rises into the 60-70psi zone. I turn on the A/C and the compressor engages but no cold air. I let out pressure from the LOW side again to drop it within spec (of course I can only see pressure when the system is OFF). Even though pressure is within spec.. I get no cold air even though the compressor is running.
What could be causing this? Did I damage anything? Why would I have no pressure reading when the system is running?
At the same time we did my buddy's MKIV Supra and his was behaving normal! During re-charge when hte system engaged, there was still a pressure reading and recharged it into normal reading... no problems.
Help anyone!
G
1995 Legend Coupe 6-speed
208 WHP @ 6250 RPM
189 FT/LB @ 5250 RPM
MUSTANG Dyno
260,000mi and counting
theGodfather is offline
Old 09-23-03, 05:29 PM   #2 (permalink)
"the Don"
bump
208 WHP @ 6250 RPM
MUSTANG Dyno
Old 09-24-03, 12:42 AM   #3 (permalink)
"the Don"
bump
208 WHP @ 6250 RPM
MUSTANG Dyno
Old 09-25-03, 10:31 AM   #4 (permalink)
"the Don"
c'mon.. someone has to know something about A/C systems
208 WHP @ 6250 RPM
MUSTANG Dyno
