remove the front seat - The Acura Legend & Acura RL Forum
Old 05-01-11, 09:55 PM   #1 (permalink)
Car 1: acura legend 1991
I need to remove my front seat i can remove the 2 front bolts but i can't see the 2 rear bolt because i can't forward the seat maybe a coins stuck on the rail... anyone can help me?
manu1900 is offline   Reply With Quote
Old 05-01-11, 11:05 PM   #2 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
Car 3: 93LS 6spd gray cpe
There are several threads about this topic. Search will find them. I am able to overcome
locked seat by using a wrench at rear of track. Does motor work but no movement?
Does motor not work. Different problems.
link to thread http:Moving a Power Seat w/no power
Old 05-02-11, 06:29 AM   #3 (permalink)
EDM Honda Legend Coupe
MikeD's Avatar
Car 1: '95 EDM Legend Coupe
Both 15mm bolts are located under the rear covers on each side
EDM '95 TCS Coupe with USDM Mod's (Trunk Lid/Taillights/Cupholder/Audio Switch/Bose EQ) rolling on 225/45/17 Tires
Acura | Honda V6 Forum / Photo Gallery
English isn't my 1st language. So please consider it by way of apology of my bad grammars! Thank you.
To my Friend FUT who I unfortunately never met in person. Rest in peace, you will not be forgotten.
Old 12-23-12, 01:56 AM   #4 (permalink)
In my 2002 RL I figured out how to move the seat manually even if the motor is broken. The seat motor moves the seat back and forth with worm drives on each side of the seat. The motor is bolted to one side directly and to the other side via a drive cable. This cable can be unscrewed/removed, providing access on each side to a female square drive connection. Use a power driver with a small square drive socket to move the each side of the seat into the position you need.
sdubose99 is offline   Reply With Quote
