Old 11-15-02, 10:41 AM   #1 (permalink)
Legends are Remembered
Black 91 LS Coupe's Avatar
Car 1: Black 91 LS Coupe
Removing Headlights??
How hard is it to remove the bumper and headlights on a 91 Coupe? About how long should it take?
Acura Legend
LS Coupe
Black 91 LS Coupe is offline
Old 11-15-02, 11:18 AM   #2 (permalink)
Car 1: 1993 L Sedan
Send a message via AIM to Darkstar
Its not really that hard, probably a couple hours and your done. The headlights are pretty easy, I think theres 3 or 4 bolts and thats it. Heres a diagram on how to remove the bumper on a 91-93 Legend
Hope this helps.
-Brandon
Darkstar is offline
Old 11-15-02, 01:41 PM   #3 (permalink)
Thanks, I have a Helms Manual
I have the Helms manual for a Coupe, just wanted someone who had done this to let me know of any problems I might run in to.
Acura Legend
LS Coupe
Old 11-15-02, 01:41 PM   #4 (permalink)
EDM Honda Legend
MikeD's Avatar
Re: Removing Headlights??
You need to remove a total of 14 screws and bolts. You need to remove the phillips screws holding the foglight cover in place. One on each cover (total two). Then you remove the bumper turn signal by loosening the two phillips screws holding it it in. One for each light (two total, running total of 4). Then you remove the 4x 10mm bolts from the under side plastic shield. Two on each side (total 4, running total 8).
Then you unscrew the two plastic screws toward the center part of that plastic shield. Two total, running total 10). Now, you remove the 4x 12mm bolts holding the bumper in place. These are accessed through the hole left from the bumper turn signal. (4x total, running total=12) For the Coupe, there is only 2x 12mm bolts holding up the bumper, so the total would be =12 bolts.
The whole removing procedure takes approx. 1 hour, depending of, if you know, where to find the screws and bolts.
To remove your headlights, it´s no problem. You can see the 2 upper and the 2 lower screws. Like Darkstar said, no problem.
Mike / Cologne
MikeD is offline
Old 11-15-02, 07:58 PM   #5 (permalink)
Posts: n/a
Re: Re: Removing Headlights??
thank you Mike
maybe i can finish my angel eyes!
Old 11-17-02, 06:21 AM   #6 (permalink)
EDM Honda Legend
MikeD's Avatar
Re: Re: Re: Removing Headlights??
Originally posted by Stratoknight
thank you Mike
Stratoknight,
are you plan to finish Angel Eyes ? Take care about your headlamps. It´s a very hard work. Keep us guys inform, ja ? Tell us your experience about that and also... How long you need it! Because I´ll get very soon my US headlamps, I´m very interested about your reconstruction to "Angel Eyes"
Mike / Cologne
MikeD is offline
Old 11-17-02, 10:57 AM   #7 (permalink)
Posts: n/a
Re: Re: Re: Re: Removing Headlights??
Originally posted by MikeD
Stratoknight,
Mike / Cologne
yeah i will keep you updated
last night i was starting to take off the bumper but didnt have time so iput everything back on to find out that my left bumper signal wasnt secure and a lady was like "interesting turn signal"
everytime i start i never have time......
Old 11-17-02, 11:54 AM   #8 (permalink)
Car 1: 93 Black L Coupe
Car 2: 91 Red LS Coupe(RIP)
should only take an hour or two. i had to take my headlight and bumper off because it came loose somehow and so i just reattached it and it was pretty easy
JTJohnny102 is offline
Old 11-17-02, 11:55 AM   #9 (permalink)
Posts: n/a
i had like 30 minutes at the most
Old 11-17-02, 03:06 PM   #10 (permalink)
EDM Honda Legend
MikeD's Avatar
Re: Re: Re: Re: Re: Removing Headlights??
Really strong ! Last night... ... a lady was like "interesting turn signal" Na, na, na, ts ts ts. Flirting and working together ? Super!!
Like you write: "Every time I start, I never have time"
Mike / Cologne
MikeD is offline
Old 11-18-02, 01:02 AM   #11 (permalink)
Posts: n/a
haha it was almost draggin
i am glad she told me:p
Old 07-22-08, 02:33 PM   #12 (permalink)
stsupple's Avatar
Car 1: 1992 Acura Legend LS
My bumper was ripped off a few months ago and I'm trying to re-mount it. Since downloading the manual, I understand how to do it, and last night I got under the bumper and was unpleasantly surprised to find not only that there are no screws holding the bumper turn signal lights in but they wouldn't budge either. Where are the screws supposed to be?
stsupple is offline
Old 07-22-08, 11:15 PM   #13 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
stsupple; The online service manual (Helms) shows the approach.
1. remove the fog cover (lower bumper.) 2. with a 6-8" screw driver
engage the retaining screw on the midline side of the "bumper light"/
turn signal; loosen without removing. Once the screw is loosened, the
bumper lamp/turn signal can be rotated out from the midline side toward the
adjacent fender. First time is a mystery. I will post a link; good luck.
Acura Legend Online Service Manual (Page: 0821)
Boru is offline
Old 07-23-08, 03:41 AM   #14 (permalink)
KA8 Legend Killer
91sedan's Avatar
Car 1: 91 Acura Legend BHG
Car 2: 88 LS Sedan-SOLD
Car 3: 93 Ranger R.I.P
I can get my driver side headlight out but I can't get my passenger side one out. it's rather frustrating
Mods: Short Ram Intake with K&N Air Filter, Custom Exhaust, Telion Chipped ECU, Type II Manifold (added 12 peak hp and cracked on 7-30-08), Type II Cluster,Throttle Body Coolant Bypass 15.35@91.6mph
Future Mods: OBX Headers,Custom Y-Pipe,Magnaflow hi-flow cat,Stromung B-Pipe,Remus Exhaust,Ported and polished heads and manifold,Web Cam regrinds, 6spd swap All after I Do the 3.5 Swap!! Hoping for a healthy 200whp N/A beast
91sedan is offline
Old 07-23-08, 01:00 PM   #15 (permalink)
stsupple's Avatar
Thanks, ironically that's the very page I was using, lol.
stsupple is offline
