Replacing side view mirror - The Acura Legend & Acura RL Forum
Old 04-01-04, 02:00 AM   #1 (permalink)
DVS
Car 1: 07 TL
Car 2: 94 LEGEND COUPE LS
Send a message via Yahoo to DVS
Question Replacing side view mirror
Guys, I need to replace my side view mirror (just mirror) on my coupe. Do any of you have a diagram or instructions on how to remove the mirror?
DVS is offline   Reply With Quote
Old 04-01-04, 02:39 AM   #2 (permalink)
Car 1: 1995 GS, Pearl White
just look in here:
http://www.acuraautomotiveparts.org/...prddisplay.jsp
9legand1sed is offline   Reply With Quote
Old 04-01-04, 03:56 AM   #3 (permalink)
Car 1: 1995 Legend Coupe - Sherwood Green
Its easy. I just took both of mine off to paint the plastic bases (piece between the door and mirror base) since they were weathered. Just remove your inner door panel, disconnect the wiring harness and route through the door so its free. There are 3 10mm nuts (I believe they are 10). You will need a socket extension to get to the one furthest up. Once you have these off grab the mirror and use a small screwdriver to depress the plastic clip that holds it on and keeps the mirror from falling off once the nuts are removed.
95 Legend L Coupe - original owner
Total loss on 7/13/04. Gone but not forgotten...
95G2_lastofthegreatones is offline   Reply With Quote
Old 04-03-04, 01:22 AM   #4 (permalink)
DVS
Car 1: 07 TL
Thanks for the replys, but do I really have to remove the whole mirror housing/harness to just take the mirror off?
Old 04-03-04, 01:58 AM   #5 (permalink)
Mr. Sh*f*er
Car 1: 1991 Legend LS
Car 2: 2004 RSX Type S
I am not sure how it works on the coupe mirrors but on the sedans you just loosen the phillips screw at the bottem of the housing (near middle). and the Mirror can easily be pulled out and you can unplug the power and heater plugs.
5spdLegend is offline   Reply With Quote
