Old 06-13-08, 12:44 PM   #1 (permalink)
Car 1: 91 acura legend
Unhappy service connector
hi,everyone newbie here. i just recently purchase a 91 legend for my 16 yr. old son. the problem i have is that my cel & anti-lock light stays illuminated. i read in this forum about jumping the service connector to pull the codes. when i did jumper this connector i could not get the cel & anti-lock lights to blink. i also pulled the #15 fuse that is under dash & ecu fuse with no help. does anyone knows how to get the lights to blink so i could find out the codes.
dnice112 is offline
Old 06-13-08, 05:44 PM   #2 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
Turn the car on and let it run. This is also to make sure the lights are still on and you didn't clear them out. If lights are on, jump the connector making sure you are jumping the two holes that have the wires going into them (mine has 4 holes and only two have wires ). Once you have it jumped turn the ignition to position II so that just the dash lights turn on, that is all it should take for the engine/ABS light to start blinking.
ari_one is offline
Old 06-14-08, 08:41 PM   #3 (permalink)
thxs. for your reply ari one. i did exactly as stated in your reply. lights did not blink but stayed illuminated. are there any other suggestion before dealer.
dnice112 is offline
Old 06-14-08, 09:36 PM   #4 (permalink)
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1991 Legend
Car 3: 95 ZX-7
If the lights stay illuminated it sounds like the jump connector is not getting jumped? What are you using to jump the connector?
ari_one is offline
Old 06-15-08, 01:09 PM   #5 (permalink)
Car 1: 1992 Legend L
Car 2: 1990 CRX HF DOHC ZC
Car 3: 2003 Element EX 4WD
IIRC, a 91 is OBD-0, which you would pull back the carpet, and with the ignition on look for a blinking light on the ECU itself. At least this is how it is with other cars, Civics, crxes integras...
djhankb is offline
Old 06-15-08, 02:07 PM   #6 (permalink)
ActionJackson's Avatar
Car 1: 1979 MGB
Car 2: 1991 Sedan LS
Car 3: 1993 Coupe LS 6MT
Ari One is correct. 91's had the dash blinking system. Make sure that you are jumping the correct two ports on the service connector with a suitable object. I would suspect that you are jumping the incorrect ports.
A paper clip bent in half works good.
Bring your Legend to Florida for Vacation!!! We need the tourists. Come on down, the weathers great. No snow tires needed.
ActionJackson is offline
Old 06-15-08, 07:21 PM   #7 (permalink)
Car 1: 91L 5spd blue cpe
Car 2: 92LS 5spd gray cpe
Ditto ^^ what Ari and Action stated. I have a '91 coupe and have done the
paper clip jumper. There are 4 slots on mine. When pulling my codes, I turn
the engine off, place the connector; then, I start the engine while looking
at the dash cluster. I believe that if one inserts a paper clip into the connector while the engine is running they will get an unpleasnt surprise.
I confess I have not confirmed that personally.
Boru is offline
Old 06-18-08, 12:43 AM   #8 (permalink)
thxs.,everyone for your advice. got feedup trying to figure this thing out. took car to mechanic. he haven't call me back yet, but when he does i'll let know what he did. anyway i did use a paperclip bent in half. my service connector is blue color with a two(2) pins connector. when jumper light still would not blink. thxs. for advice anyway. let everyone know how it come out.
dnice112 is offline
Old 07-20-08, 10:46 PM   #9 (permalink)
MarcD's Avatar
Car 1: 1995 Acura Legend LS coupe 6MT
Car 2: 94 Legend LS coupe
Car 3: 2005 GMC Yukon
Just curious how you made out with this?
MarcD is online now
