Old 06-15-03, 04:30 PM   #1 (permalink)
OG Member
DSCLegend94's Avatar
Car 1: 1994 Acura Legend L Sedan
Car 2: 2006 Honda S2K
Send a message via AIM to DSCLegend94
Angry Shaking while accelerating
ok guys this problem has been happening for about a week.
It seems like the front of my car shakes only when I accelerate and have it on drive (auto). If I have it on cruise control and don't accelerate, it won't vibrate. It won't vibrate either if I throw it in neutral. I thought my tires were low but that wasn't the problem. and I haven't hit any curves or potholes so my alignment is ok. Any ideas before I take it in?
BHG @ 208K original miles
Temporarily Disabled
Phillips HID Kit
JDM One-Piece Headlights
Trenz Billet Grill
OEM Foglights-PIIA ion yellow bulbs
Brembos Cross-drilled/slotted rotors
Axxis Metalmasters brake pads
Red-painted calipers
17X7 Acura TSX OEM Wheels
Pics in Gallery
DSCLegend94 is offline
Old 06-15-03, 05:55 PM   #2 (permalink)
Car 1: 1992 Seattle Silver LS
Having the same issue also. Most noticable between 60-70 mph....anyone know what's up?
Formerly "Civic2Legend"
http://www.geocities.com/bigballer_78250/sig.txt
Phil B is offline
Old 06-15-03, 05:57 PM   #3 (permalink)
OG Member
I actually getting from take off (0-70mph+)
Phillips HID Kit
Trenz Billet Grill
Pics in Gallery
Old 06-15-03, 08:07 PM   #4 (permalink)
93QBLeGend
Car 1: 2001 VR6 , 93' Legend Sedan
Send a message via AIM to bklynstunna
im having the same problem started about 2 days ago i notice a small vibration around the front, i dunno if it may be a tune up or something, if its not i hope that the problem isnt to costly....
"BIG TYMERS is a state of mind... If you gonna do something, do it big time."
Mannie Fresh
1993 Acura Legend L
2001 Jetta VR6
http://img.photobucket.com/albums/v9...813_3300_1.jpg
bklynstunna is offline
Old 06-16-03, 02:02 AM   #5 (permalink)
Mine is from 0-whenever I stop accelerating....but actually much more noticeable from 60-70.....
Phil B is offline
Old 06-16-03, 03:04 AM   #6 (permalink)
OG Member
anybody?
Phillips HID Kit
Trenz Billet Grill
Pics in Gallery
Old 06-16-03, 03:08 AM   #7 (permalink)
It's stock, really.
FF Drifter's Avatar
Vibration between a set range of speeds is usually an off-balance wheel. Try balancing your wheels.
FF Drifter is offline
Old 06-16-03, 09:02 AM   #8 (permalink)
This would have been the simplest fix. Believe me it isn't it.....differernt type of vibration, and whels have been balanced 3 times since I noticed....
Phil B is offline
Old 06-16-03, 10:13 AM   #9 (permalink)
CV joints
1995 Sherwood Green LS Coupe
jcbmrtn is offline
Old 06-16-03, 12:06 PM   #10 (permalink)
Originally posted by jcbmrtn
CV joints
Damn....I was afraid of that.....cost?
Phil B is offline
Old 06-16-03, 01:56 PM   #11 (permalink)
Well you can get a rebuilt one for about $45-60 with a trade in of your old one. A new one is about $150, I believe. I would buy a new one though, because I went through THREE remanufactured units, before I bought a new one that finally worked.
These prices are for the part only. I'm guessing labor would be $100-150??
jcbmrtn is offline
Old 06-16-03, 02:21 PM   #12 (permalink)
Car 1: 98 RL
Important lesson learned about changing CV joints.
I had a vibration, not while accelerating, that turned out not to be a CV joint problem. I had heard it was easy to get a bad rebuild CV joint, so I took my car to the dealer for analysis and repair.
The dealer told me that their analysis indicated that I had two bad CV joints and the cost for repair was $730. They replaced the CV joints – both sides with a rebuilt set, but the car then vibrated worse. The dealer installed a second set of CV joints and the car was even worse. So they put my original CV joints back in and charged me $400 for fixing the vibration. The vibration is gone, but they wouldn’t tell me what they did to fix it. Obviously they had planned to replace my good CV joints knowing they were good.
The lesson is that it is very easy to get bad “rebuilt” CV joints.
jime
04 TL 6MT/Navi/HPT Anthricite/Ebony (my toy)
98 RL (ours)
00 Lexus RX-300 (hers)
jime is offline
Old 06-16-03, 02:37 PM   #13 (permalink)
Car 1: 1991 Black Acura Legend LS Coupe
Send a message via AIM to Gimpy21
Oh man..... Don't get me started on this subject again...
I went through the same problem you guys are experiancing about 2 months ago. A bad vibration comeing from the front of the car, usually at higher speeds and only under moderate to heavy acceleration. It is your CV joints I am about 98% sure of this.
By the time I figured the whole mess out I replaced the CV joint twice, a wheel hub bearing, upper and lower ball joints. Costly to say the least.
And if you do decided to replace it with a re-manufactured unit, be carefull, like I said the first re-manufactured unit I got was crap, it did the same thing as my bad CV on my car and thats when I decided to replace the other things that most likely had nothing wrong with them in the first place.....
My advice is this....... Try to determine which CV it is first. (so you don't replace a good CV) Then buy a new CV from your local Acura dealer. If you can't afford a new one, get a re-manufactured unit and make sure that it works and works properly when you put it in. If it still has that vibration after you put in the re-manufactured unit, Replace that with another re-manufactured one untill the problem is solved.
Hope this helps you guys out!!
-Brandon
lazyness is bliss....
-Brandon
"ph33r the Legend!"
http://memimage.cardomain.net/member.../163199_28.jpg
1992 Jeep Cherokee - (beater)
1991 Green Acura Legend LS Coupe - (beater)
1991 Black Acura Legend LS Coupe - (project)
Gimpy21 is offline
Old 06-16-03, 02:39 PM   #14 (permalink)
OG Member
CV joint? is that the same as CV boot? My friend that had his CV boot replaced said it was a diferent kind of problem
Phillips HID Kit
Trenz Billet Grill
Pics in Gallery
Old 06-16-03, 05:50 PM   #15 (permalink)
L E G E N D
FutureX 2001's Avatar
Car 1: '95 Coupe
Car 2: '94 Sedan GS
Car 3: '90 Coupe
The CV Boot is the rubber around the CV joints. There is grease inside the boot that helps the CV joint stay lubricated. Many times the CV Boot will rip, some tear completely into two. Then air (as you drive) and dirt get passed the boot because it's torn and into the CV Joint. Grease will also leak out of the boot as you drive. The end result is a drying/dirty CV Joint over time, which will eventually cause it to fail.
FutureX 2001 is offline
