speed sensor question please answer....
my speedometer stopped and rpm is on and off. can i find the sensor and knock it or clean it our somehow to get it to work or does it need replacement for sure. how much and is it easy to do?
mark |
I didnt even bother with trying to locate it...I just bought a new one and paid to have it done.
Part was about $80 from Acura Of Agusta (800-815-5158) and labor was about $65. Well worth the money.
-Inferno http://www.logicis.net/300zx/300zxsig.jpg 92 300ZX TT JWT ECU JWT Intake Test pipes with high flow cats Sebring catback Short Throw shifter Jspec Taillights Stillen GTZR2 front fascia BBS RGII 18x10 rear 18x8.5 front 94 L Sedan - DEAD |
I believe I read one post where someone cleaned the unit and its function returned. Best to buy a new "gut" which will cost approx. $80 from Acura of Augusta. The repair can be a DIY, but you will need to get under the vehicle and buy a tamper-proof T-20 torx bit. The easiest method is to remove the entire unit (allowing sm amt of diff oil to seep) as sometimes the phillips screw at the top is difficult to remove. With the unit out of the vehicle, the repair takes less than 5 min.
#4 (permalink) | |
http://img.photobucket.com/albums/v6.../DSCN45691.jpg |
Lexus owner, dont hate me
The D4 blinking is a code to say that the VSS sensor is out. I dont know about resetting the ABS because the same thing happened to me 2 weeks ago, I was doing some very hard braking tests. About the VSS, I had it done 2 years ago not knowing anything about it back then. Got taken for just over 3 bills to get it fixed
what does vss stand for please. i assume its the speed sensor. how much is the price i should pay for this...lowest please.
so this will make my d4 stop blinking, rpm and speed will work again? does this part make the check engine light go on as well???? |
The VSS stands for Vehicle Speed Sensor.
Acura Of Agusta had the best price I could find when I replaced mine. This will fix your speedo, engine light, and D4 Blinking problems...not sure on the tach issue...that was never a problem for me when my VSS was bad. Speedometer sure was on crack though!
well you should always check your Blinking code with a manual, i think 17 is the code for the VSS, i just replaced mine and it is very easy to change, you will either just need to sensor itself, (about $60) or you will need the sensor housing that connects to the transaxle. (about $75 w/sensor) id just replace the whole thing if i were you... if you have any questions just ask, it really is about a 15 minute job......
As for your tach, that is another problem, i drove around for about 4 months with no Speedo and the tach worked perfectly..... -Brandon
lazyness is bliss.... -Brandon "ph33r the Legend!" http://memimage.cardomain.net/member.../163199_28.jpg 1992 Jeep Cherokee - (beater) 1991 Green Acura Legend LS Coupe - (beater) 1991 Black Acura Legend LS Coupe - (project) |
RPM NOT WORKIN
I JUS RECENTLY BOUGHT AN INSTRUMENT CLUSTER FROM EBAY AND THE RPM GAUGE ISN'T WORKIN. I TALKED TO THE GUY THAT I BOUGHT IT FROM AND HE SAID IT MIGHT BE THE SPEED SENSOR. I WAS WONDERING IF THIS CAN BE THE PROBLEM AND IF SO WHERE IS THE SPEED SENSOR LOCATED AT ON THE CAR??? AND IS IT HARD TO REPLACE????
#14 (permalink) |
A failing VSS will also cause erratic tach function. My symptom happened when cruise was engaged. For no apparent reason the cruise cut-out, and both the RPMs and Speedometer reading suddenly decreased. No blinking D4. Replaced VSS and symptom has never again occurred.
If you have a blinking D4 a code has been set. Retrieve the code.
