Old 06-23-08, 11:46 AM   #16 (permalink)
TonyTheBullet's Avatar
Car 1: 1992 Legend LS Sedan
Car 2: 1993 Legend LS Coupe
In these times of ever incresing gas prices, anything that improves fuel economy goes a long way. I am now averaging 25mpg based on the below:
- New NGK V-power Plugs
- New OEM-style paper air filter
- Engine service using Seafoam (intake and crank-case)
- Mobile 1 Synthetic (5W30)
- Grounding kit
- Tires inflated to 33psi
- Shell V-Power gas
I saw the biggest increase in fuel economy after installing the grounding kit; it went up by 1mpg.
Note: I live in the suburbs so most of my "city" driving is in the 50-80 km/h range and I try to use cruise control as often as I can.
____________________________________________
PM me if you got 'em!
TonyTheBullet is offline
Old 06-25-08, 03:57 PM   #17 (permalink)
Matthew is THE USER!
mktng's Avatar
Car 1: 91 KA7
Car 2: soon2b GIXXER 750!!!
I use Sunoco 89 fuel
i noticed that its alot better than Shell 91 V power. (seriously!!)
i fill up less. get more km's and the throttle response is the exact same..
and not to mention the money i f*king save!
grounding kit.. does it matter what brand i get? or can i just get those ebay ones >.< ?
KA7 & Inspire
mktng is offline
Old 06-26-08, 08:54 AM   #18 (permalink)
I made my own, cost me $30 and is much better quality than what is available online or on eBay.
Old 07-13-08, 05:10 AM   #19 (permalink)
L E G E N D
FutureX 2001's Avatar
Car 1: '95 Coupe
Car 2: '94 Sedan GS
Car 3: '90 Coupe
What it basically comes down to, on G2 Legends where Premium Fuel is what is required (Premium Fuel Only). No you won't damage the car by running lower octane. The dual konck sensors will compensate and retard the timing to prevent harm to the engine. The result however will be less power... The computer is designed to accept lower octane fuel in case you need to run it...but it wont run to its' full potential.
FutureX 2001 is offline
Old 07-15-08, 10:04 PM   #20 (permalink)
BBS
Car 1: 1994 Legend GS 6spd
Crowling, you seem to know a lot about fuel. What do you know about fuel catalysts such as fitch.
Fitch Fuel Catalyst - Home
BBS is offline
Old 07-16-08, 03:10 AM   #21 (permalink)
Legend Anti-Christ
The Crowing's Avatar
Car 1: 1991 Legend Coupe LS
Car 2: 1968 Jaguar XK-E
Car 3: 1990 L Sedan
Hmm, I'm not sure on that one. My immediate instinct is another monkey pee product, but again, I really dont know.
As I see it, if you take care of your engine, give it a Seafoam and maybe off-car fuel system clean every now and then, then you don't need anything in a bottle. Another point, if you buy these products for oh, $20 a bottle, and squeeze up your MPG from 22 to 24, on an 18 gallon tank, thats 36 extra miles, or about 1.3 extra gallons. Lasts for what? 5 tanks? 6.5 gallons = $24. This is, of course, assuming it actually works. Consider also, the time and/or labor charge all these methods may take.
Me? I take care of my car, change oil every 2,000 miles (I work at a dealership, so I get them whenever I want) I regularily check all fluids and components of the engine, and occasionally use Seafoam. My beast of a 1990 G1 Sedan with two seeping headgaskets and half a Napa store in the back seats and trunk gets 20 mpg and I beat the piss out of it.
Take it as you will.
$80 to make a 3.5 mount for 91-92 Legends. PM me. For 93-95, PM jkurl.
Wishlist:
6-speed ECU?
Passenger front wheel bearing
Clutch hydraulic lines/hoses
Power steering rack
Passenger seat release cable
Gold JDM grille
Manual coupe 160 cluster
Type II fuel pressure regulator
91-92 front passenger engine mount
Catalytic converter
Mod-Express kit for sale - Cheaper than GB price. PM me.
The Crowing is offline
Old 07-16-08, 03:26 AM   #22 (permalink)
GSG737
RedLegend92's Avatar
Car 1: 1992 Acura Legend Sedan
Car 2: 01 Suzuki RM125
Car 3: soon Suzuki GSX750
Send a message via AIM to RedLegend92
how long should you run sea foam in the crank b4 a change...sorry is this is a repeating question..didn't even bother to look
http://www.cardomain.com/ride/777926
CHICAGO LEGENDS!
Custom CAI
magnaflow catback exhaust
2 12" kicker cvr12's with a 2253 watt (751 rms)rockford amp w/ Cap
Pioneer head unit w/ pioneer ipod adapter
Rial 16" rims w/ goodyear triple tread tires
3 gauge pillar w/ autometer cobalt gauges.oil pressure, water temp, and air/fuel
GTS Smoke headlight covers
Venom 400 performance chip
Clear Corners
Mod Express 6000k HID kit
Addco rear sway bar
Blackened Engine Damper
20% tint
RedLegend92 is online now
Old 07-16-08, 03:38 AM   #23 (permalink)
Legend Anti-Christ
Car 3: 1990 L Sedan
Thats ok, I didn't even bother to answer.
Wishlist:
6-speed ECU?
Power steering rack
Gold JDM grille
Catalytic converter
Old 07-16-08, 04:07 AM   #24 (permalink)
GSG737
Ok I read your thread of diy and through all the bs no one has a straight answer on how long you leave the seafoam in your oil before a change...wanna answer this one?
CHICAGO LEGENDS!
Custom CAI
Clear Corners
Addco rear sway bar
20% tint
Old 07-16-08, 04:15 AM   #25 (permalink)
Legend Anti-Christ
Car 3: 1990 L Sedan
Heh, sorry to come off as a dick. I just wanted to see what you'd say. Sorry man.
Anyway, instead of seafoam, I'd say put transmission fluid in your crankcase, about a pop-bottle full, 500 miles before you do your oil change. That will work much better.
Wishlist:
6-speed ECU?
Power steering rack
Gold JDM grille
Catalytic converter
Old 07-16-08, 05:24 AM   #26 (permalink)
GSG737
lol its cool..thanks for the info
CHICAGO LEGENDS!
Custom CAI
Clear Corners
Addco rear sway bar
20% tint
Old 07-16-08, 12:11 PM   #27 (permalink)
33mpg 6spd Coupe
kotetu's Avatar
Car 1: 95 LS Coupe 6spd
Car 2: 94 L Cpe 6spd - sold
Car 3: 98 Prelude - sold
hmm monkeys are primates, humans are primates... I think I will just pee into my gas myself! That should save me some money!
Originally Posted by kotetu
3 out of 4 Legend owners recommend buying a second Legend.
Welcome to the Game. Enjoy your time here.
kotetu is offline
Old 07-16-08, 10:06 PM   #28 (permalink)
Find Em Fuck Em Forget Em
GrumpySteelMan's Avatar
Car 1: 2004 Nighthawk RL
Car 2: 2005 Nighthawk TL
Car 3: 2002 525i Sport Wag
I just saw this. I love you, man.
GrumpySteelMan is offline
Old 07-17-08, 12:55 AM   #29 (permalink)
Legend Anti-Christ
Car 3: 1990 L Sedan
^From you, thats quite an honor.
...sig'd
Wishlist:
6-speed ECU?
Power steering rack
Gold JDM grille
Catalytic converter
Old 07-18-08, 11:54 AM   #30 (permalink)
33mpg 6spd Coupe
kotetu's Avatar
I thought this was an interesting read:
High Octane
The swami has been hearing a lot of nonsense around the gas pumps these days. People are tanking up with the "good" stuff because the commercials imply that it's better for their engine. When the oil companies use superlatives like "Super", "Extra" and "High"...well it must be better, right? And of course they wouldn't be charging $0.10 - $0.20 more unless they were putting some really good stuff in there, right? Sorry...NOT!
"High Octane" is not synonymous with "good" or "better", and does not mean that it is better for your engine! And the chances are pretty good you don’t need high octane fuel in your scooter.
High-octane fuels only become necessary when your engine has a high compression ratio. It’s a very long and complicated story…that the swami will make short.
First important fact that you must accept:
All gasoline, regardless of its’ octane rating, have pretty much the same amount of energy per gallon. What!!! "Sacrilege" you say? Well, actually, some higher-octane fuels have a few LESS percent energy per gallon…so as not to argue over this small point, for the sake of this discussion we will all agree that the automotive gasoline that you buy at the pump, regardless of octane rating, has the same amount of potential energy.
Second important fact that you must accept:
Octane is NOT a measure of power but of the fuels’ resistance to ignition from heat. A higher-octane fuel, under identical combustion chamber conditions, will burn slower.
How can this be? If all of the above is true, how do we get more power out of high octane gasoline? We do, don’t we?
Well…yes we do. Here’s how:
But first you must understand "heat of compression". There is a 2,000 year old fire starting device that still amazes the swami. A length of bamboo was hollowed out leaving one end capped. A stick, about the same length as the bamboo, was whittled down until it fit snugly into the bamboo cylinder. A bit of dried grass or wood shavings were placed in the bottom of the bamboo cylinder and the snugly fitting stick was violently rammed down the bamboo tube. The heat generated from rapidly compressing the air in the tube was sufficient to ignite the tinder.
The same thing can happen in the cylinder of an engine. The piston, quickly squeezing the fuel/air mixture into a small space, can generate enough heat of compression to ignite the fuel well before the spark plug fires, with unpleasant results. If the fuel prematurely ignites while the piston is on its way up, the burning of the fuel, in conjunction with the rising piston, creates even more pressure, resulting in a violent explosion. This explosion is equivalent to hitting the top of the piston with a very large hammer. If you want to be able to see through the top of your piston, ignore those sounds that are usually called: "pre-ignition", "ping" or "engine knock". Trust me on this one; in his reckless youth, using this method, the swami turned a few pistons into paper weights.
What we really want is a very rapid burn of the fuel, not an explosion. And we want the burning of the fuel to take place while the piston is in a better position to convert this pressure into productive work, like on its way down. Think of this burning as a very fast "push" on the top of the piston. Despite the violent noises you hear from some exhaust systems, it really is a rapid push on the top of the piston making the crankshaft go around, not explosions.
So that we can ignite the fuel at exactly the right time with the spark plug, instead of from the heat of compression, they put stuff into gasoline to keep it from igniting prematurely. The more resistant the fuel is to ignition from the heat of compression, the higher its octane rating.
Are you with me so far?
Higher compression ratios = higher combustion chamber pressures = higher heat… and it is with these higher combustion chamber temperatures that the magic happens.
At higher temperatures the fuel is burned more efficiently. So, while it’s true that the higher-octane fuel does not posses any more energy than low octane fuel, the increased octane allows the extraction of more of the potential energy that has always been there. Conversely, lower compression ration engines utilize a little less of the fuel energy potential (2-4% reduction) but there is also less heat generated in the combustion process.
So how do you know if you need high-octane fuel? The swami suggests you look in the owners’ manual! Manufacturers really do want you to get the maximum efficiency out of your engine. They do their best to give a good balance between horsepower and engine life. It’s in their best interests to do so.
There is ABSOLUTELY NO BENEFIT to using a higher octane than your engine needs. The only benefit is increased profits to the oil companies that have cleverly convinced some of the public that their new "Super-Duper, Premium-High-Test, Clean-Burning, Used-By-Famous-Racing-Types-All-Around-The-World, Extra-Detergent-Laden-Keep-Your-Pipes-Clean, Extra-High-Octane" fuel is your engines’ best friend. The swami is telling you the truth, don’t listen to that talking cartoon car.
The swami hears people insisting that they got better mileage, better acceleration, and less dental plaque by switching to a high-octane fuel. The swami reminds these people that in every pharmacy is a special miracle pill that is often prescribed by doctors, it works wonders because people believe that it works wonders; it’s called a "placebo". The swami warns: never confuse faith with physics!
If you are getting pinging or knocking with what should be the correct octane for your engine, start by checking the ignition timing, also check that the spark plug is the correct heat range. For 2-strokes, check for excessive carbon build-up on the top of the piston, the carbon takes up space and increases the compression ratio.
If all is well and correct, and you still are getting knocking, then try the next higher octane. You won’t go faster, you won’t go farther, but you will prevent an unsightly hole in your piston.
This subject is a whole lot more complicated than the swami wants to bother with. If you are curious to know more, put some of these words into your search engine and enjoy the education:
Antiknock Index
Octane
Stoichiometric Combustion
Thermal Efficiency
Flame Front
Highest Useful Compression Ratio
Compression Ratio
Placebo
kotetu is offline
