dealer-opted track pack
Your moonroof glass isn't aligned properly.
Unbolt the glass and realign it. Good Luck, k.h.
You don't have to remove the moonroof glass to do the tilt mod.
That's what got you into trouble in the first place. Now, you have to loosen the moonroof glass screws and align the glass because it's misaligned. k.h.
The Teach
you may need to adjust more forward, make sure the shimmy spacers are there and corectly installed. Eventhough it has an aligenment pin on each side you still want to center it correctly. Take your time for this type of diy, its simple but it takes time. Lube it too I lubeed mne also, considering that that mechinism hasnt moved that far at all in over ten years!!!
Let me know if that helps. Chris
same thing happened to me when i did it..didint noe you didnt have to remove the moonroof till i was drilling haha..i had to push it to make it tilt but after a while i didint have to push it anymore so i didint noe what the problem was..mayb you sould just keep pushin it up n down
http://i5.tinypic.com/15g4djp.jpg "Take a minute in your life, or take your life in a minute" |
K L E A N M O D™
I guess i'm the only one that hasen't done this yet. Didnt want to screw up my sunroof.
-1995 KA8 MODIFIED-R.I.P -1997 S14a-SOLD -2000 Millenia S -1995.8 S14a -Holy Rollerz CCC Member- -Inspiration™- My KA8's totaled and still greater than.... Imitatated. Never duplicated.™ |
nah, SB Wooder is right, just stick some shimmys in there then bolt downt he glass. It happend to me and that worked. Also, clean up the rubber really well with alcohal then clean it with wd-40, just to make sure it doens't dry out. it works well for me --=Keith
Some of the most beautiful things in nature have been shaped by the wind - The Acura Legend Coupe |
#14 (permalink) | |
Don't remove your glass. You won't have any fitment issues. It's that simple. ![]() Good Luck, k.h.
| DIY: Remote start/ Tilt steering | Roger | DIYs | 21 | 07-22-08 08:06 AM |
| Moonroof Tilt DIY | LegendGS | DIYs | 95 | 07-08-08 02:23 AM |
| Help with Sunroof Tilt | Danny | Second Generation Legend (1991-1995) | 17 | 11-13-04 08:55 AM |
| Is there a DIY for the tilt sunroof mod? | midwestlegend | Second Generation Legend (1991-1995) | 21 | 07-14-04 04:41 AM |
| Tilt Sunroof???? | danno69 | Second Generation Legend (1991-1995) | 3 | 05-15-02 06:10 PM |
