SUSPENSION QUESTION PLEASE HELP - Page 2 - The Acura Legend & Acura RL Forum
Old 01-06-13, 10:28 PM   #16 (permalink)
Car 1: L Coupe and GS Sedan
Beautiful, thanks Guario!
94 Legend GS 6 spd. - Desert Mist Metallic - 140K
92 Legend L Coupe - Phantom Gray Pearl - 270K
91 Legend L Coupe - Frost White - 240K
sfearing is offline   Reply With Quote
Old 01-07-13, 10:19 AM   #17 (permalink)
For the replacement bushings, they are radius arm bushings" the following numbers will work:
1. 51391-SCV-A03, Element and Odyssey newer models
2. 51391-S5A-A24, Civic earlier 2000 models
The outer cylinder (OC) replacement bushing have the about same Outer Diameter as the existing ones and will snugly fit in the housing. Now, the height of the OC is less, but the existing bushings have enough overhang to spare. The real modification is in the inner cylinder (IC) of the bushings, for in the replacements the IC overhang at both ends. One of the ends has to be sawn-off, flush with the OC. I did this with a hand saw, gloves, and patience. Then, the same sawn end needs to be drilled in a conic shape to ensure a snug fit of the lower suspension plate. This operation will require drill bit sized well above the common household sizes and holding attachments.
Guario is offline   Reply With Quote
Old 01-07-13, 03:30 PM   #18 (permalink)
Gentlemen, I've been trying for over 45 minutes to post some digital images of the original bushings in the cross member housing and the replacement ones. However, I keep getting "Unable to move/copy file".
Any assistance is appreciated.
Old 01-07-13, 03:46 PM   #19 (permalink)
BIGBOY's Avatar
Car 1: 94 acura legend ls
You need to use a hosting site like photobucket.com. If that don't work PM me and I will post them for you.
Old 01-07-13, 03:51 PM   #20 (permalink)
Your picture resolution may be too high to load.
Old 01-11-13, 07:08 AM   #21 (permalink)
Gentlemen, I could use some help here. I am trying to upload some images of the radius arm bushings to this forum with no luck at all. The images won't upload from my computer. I established a Photobucket account and have tried to do many uploads with no success at all. The image size has been reduced too, with the same results.
Any guidance is appreciated.
Old 01-11-13, 11:08 AM   #22 (permalink)
AZpartsGuy
ari_one's Avatar
Car 1: 1991 Legend
Car 2: 1998 Civic EX
Car 3: 95 ZX-7
iTrader Score: 63 reviews
In photobucket, click on the green 'Upload' button at the top of the page, then on the next screen click on the 'Select photos and videos' and select what you want to upload. Once the upload is done, click on 'Save and continue to my album' and this will take you to your album. Now select a picture and click on the 'IMG code' and then do a paste on here.
Old 01-11-13, 02:03 PM   #23 (permalink)
I fail to follow how to accomplish this. And I've tried several different ways.
Old 01-11-13, 02:06 PM   #24 (permalink)
Old 01-11-13, 03:02 PM   #25 (permalink)
BIGBOY's Avatar
Once you get the option for the image codes, you wan to pick "direct link" iirc. They keep changing how you use photobucket. Stupid IMO.
Old 01-11-13, 04:09 PM   #26 (permalink)
Gentlemen,
a) "paste it here", but where? Do I attempt to paste it to the text area? Should I use the Image icon above? Or the Manage Attachments panel in the additional options below? I've used them all.
b) "direct link iirc" at Photobucket, what is that? The images in my Library keep changing numbers and the pages just "keep loading" to no end.
I guess no more images for me. Sorry.
Old 01-11-13, 05:01 PM   #27 (permalink)
BIGBOY's Avatar
you post the image in the same box you text in, or like I said before PM me the links and I would upload them for you.
Old 01-11-13, 07:56 PM   #28 (permalink)
DSCN1842_zps7159eac1 photo by EGP_1 | Photobucket
DSCN1844_zps45671d9f photo by EGP_1 | Photobucket
Well, I just dragged the Photobucket links of two image links to the text field.
Old 01-16-13, 07:34 PM   #29 (permalink)
Old 01-17-13, 03:31 PM   #30 (permalink)
Thanks Sfearing for posting the pictures. I want to add, the bushings I mentioned work well for a 93, Base, 4dr.
